Old 03-21-2015, 08:10 PM   #155
Bobblehead
Bobblehead's Avatar
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
Originally Posted by Bobblehead View Post
This will most likely sound very dumb, and possibly "squady/squidy," but I'd like to know the answer.
With the stage 1 tune, the FA20 makes an induction/valve tick noise at around 4K RPM. What is it exactly? I understand its "normal" but what is making the noise? Could it be something with the cams or sprockets? And lastly, the dumb question, is it a healthy noise? Will there be any kind of damage in the long run from running with this noise?
Thanks!
Still never got an answer to this. Anyone?
Bobblehead is offline   Reply With Quote
Old 03-21-2015, 08:53 PM   #156
steve99
Drives: FT86
yes that noise happens with a lot of NA tunes especially for EL header, heaps of threads on it.
appears to be due to intake or exhaust resonance due agressive vvt setting to reduce torque dip.
not heard of motors exploding as a result and heaps of people running tune that do it from perrin fa20club oft ect. see @ztans post in vvt noise thread for possible reduction in noise
The Following 2 Users Say Thank You to steve99 For This Useful Post:
Bobblehead (03-21-2015), TofuJoe (08-28-2016)
Old 03-21-2015, 09:38 PM   #157
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
check out the Tune Tweaks link below has links to fan adjustments and thread on adjusting fan settings.
Thanks Steve
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 03-22-2015, 01:55 AM   #158
s2d4
s2d4's Avatar
Originally Posted by tonystewart View Post
Thank you
Your car looks fantastic, those wheels, very nice!
What were the reasons? What values were used?
Thanks again
Thanks, it was for oil and coolant temp.
Iirc values were dropped by 20F to 30F.
Old 03-28-2015, 11:41 PM   #159
Krazy
Krazy's Avatar
Drives: FR-s
Does anyone know what the current oft off the shelf map version currently is. I googled it a few times came up with different results in the download section of the website, some were older version like 1.42 and I think the current one is 1.59. The one I currently have, if I can remember correctly is 1.6 beta.
Krazy is offline   Reply With Quote
Old 03-29-2015, 01:40 AM   #160
steve99
Drives: FT86
version 2.063
clear you browser cache or use control\refresh think your getting chached pages from openflash.com web site.
Krazy (03-29-2015)
Old 03-29-2015, 05:08 AM   #161
Krazy
Krazy's Avatar
Drives: FR-s
version 2.063
Still unable to find version 2.063 still showing up as 1.59.
Old 03-29-2015, 05:15 AM   #162
steve99
Drives: FT86
http://openflashtablet.com/Automotiv...S%20v2.063.zip
make sure you use the definitions that come in that download pack for editing and not the v1 defs.
Old 03-29-2015, 05:21 AM   #163
Krazy
Krazy's Avatar
Drives: FR-s
Thank you! not sure what you mean but ill figure it out in 2 seconds.
Old 03-29-2015, 06:22 AM   #164
Krazy
Krazy's Avatar
Drives: FR-s
Ok, so everything just flew over my head. I am using OFM and the files you sent me are in XML, to convert to bin do I need to use romraider or how do I upload this to ofm. I am going to read this whole thread in the morning to learn how to edit maps, as this this sounds interesting!
Old 03-29-2015, 06:26 AM   #165
elBarto
elBarto's Avatar
Drives: Toyota GT86
This is the correct download page: FRS Downloads
There are 3 or 4 different pages you can find through google.
But that's the only one being updated.
The guys at openflash should really clean up those old pages, it's confusing for the new users.
edit:
Read all of the links posted in Steve99 signature, those will explain alot.
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
The Following 3 Users Say Thank You to elBarto For This Useful Post:
Chimera (04-10-2015), Krazy (03-29-2015), tracerit (04-13-2015)
Old 03-29-2015, 06:28 AM   #166
tracerit
Drives: '13 SSM BRZ Limited 6MT
i did some WOT after mixing my E85 but the logs seem to be cut short or something, not seeing the WOT numbers. Would using the older template file (before the 3/27 update) be a cause? I'm going to update the template now and test again in a bit but just curious.
EDIT: I see there's also a new version of OFManager as well, I thought this was supposed to be automatically updated when plugged in?
EDIT 2: Everything's working again after updating template and OFM
tracerit is offline   Reply With Quote
Old 03-29-2015, 06:32 AM   #167
Krazy
Krazy's Avatar
Drives: FR-s
edit:
It's still showing current OTS is 1.59. Should it be 2.06?
Old 03-29-2015, 07:15 AM   #168
Bader
Drives: 2013 WRB BRZ
Go here : http://www.openflashtablet.com/Autom...ads/index.html
You'll need the first three files for the manager and then scroll all the way down and you'll see the 2.063 ots pack.
I would suggest that you download one file at a time and make sure that it downloaded correctly. Sometimes the files only partially download to your pc.
Bader is offline   Reply With Quote
The Following User Says Thank You to Bader For This Useful Post:
Krazy (03-29-2015)
WTB: Open Flash Tablet TOZER Canada Classifieds 3 07-05-2015 07:13 PM
Open Flash Header & Open Flash Tablet Calavera Engine, Exhaust, Bolt-Ons 9 05-11-2015 08:27 PM
FS: open flash headers / open flash tablet - SOLD alanhung85 Canada Classifieds 12 02-10-2015 02:08 PM
FS: Open Flash Tablet (OFT) mex2309 Engine, Exhaust, Bolt-Ons 1 10-29-2014 02:49 PM
Open flash tablet. cooldandani Scion FR-S / Toyota 86 GT86 General Forum 1 02-22-2014 07:14 PM
