Old 03-19-2015, 10:34 PM   #141
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Yep, code due to plugging in, in transit.
Old 03-19-2015, 10:41 PM   #142
steve99
Drives: FT86
If it was U0155 you can disable that in ROM so plugging in oft or other obd device does not trigger that code.
Shiv usually does this but maybe missed A01I roms
Old 03-21-2015, 09:13 AM   #143
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
Hummmm
OFT Remote, OFH, Motiv OP & FP, Perrin 3' CB & 3' IT, Setrab/MoCal cooler, STI motor mounts, Wilwood 6/4 plot F&R 12.8 kits, Brake ducts, complete Whiteline catalog, complete bushing replacement, OSGiken clutch & Diff, 4.556 FD, Stance W/Spec valving 8/9 Swift.
TouchMyHonda is offline   Reply With Quote
Old 03-21-2015, 10:34 AM   #144
cdq85
cdq85's Avatar
Drives: 2013 Raven FR-S
what's up guys. i'm a newbie here and just bought the oft a few days ago. I read my stock file just fine but the "write" function is still grayed out. I skimmed through this whole section but couldn't find anything that too helpful for it. any ideas? and I did email shiv and also tried the sales@openflashperformance email as well but have had no response.
cdq85 is offline   Reply With Quote
Old 03-21-2015, 10:40 AM   #145
kevin.nguyen
Drives: Ultramarine FRS
Is it used?
kevin.nguyen is offline   Reply With Quote
Old 03-21-2015, 10:43 AM   #146
Bader
Drives: 2013 WRB BRZ
Go to the Openflash gt86 section and download the ots maps and openflash manager. Install the manager and apply the windows 8 patch if you're running win8.
Start openflash manager then connect the oft through usb to your pc. After it updates everything you can upload the OTS maps corresponding to your original ecu tune to OFT.
Once you've finished all that you can hook up the OFT to your car and flash the OTS tune.
Bader is offline   Reply With Quote
Old 03-21-2015, 10:55 AM   #147
cdq85
cdq85's Avatar
Yes, it is used. I just bought it off of someone on the forum and it was definitely unmarried if that was the next question. Bader, that was going to be my next step but won't be able to until later today as I only have a Mac at work and will have to wait until I get home to try out the openflash manager. Thanks for your quick responses guys I appreciate it!
Old 03-21-2015, 01:30 PM   #148
Aztec
Lost in the twisties
Aztec's Avatar
Drives: 2014 BRZ Dark Gray Metallic
https://www.parallels.com/
Time to use windows on a mac
Aztec is offline   Reply With Quote
Old 03-21-2015, 05:22 PM   #149
cdq85
cdq85's Avatar
I just figured that out too so i downloaded it at work but then realized i forgot the oft at home. damnit. i can't win today lol
Old 03-21-2015, 06:15 PM   #150
steve99
Drives: FT86
@Bader is correct, when oft is unmarried its completly erased, so has no prestored maps like a new one.
once you load up maps from oft downloads site use the v 2.063 maps you will be good to go, use the ecu info button to read you calid.
read button will be grey if oft has read stock rom correctly
Old 03-21-2015, 07:57 PM   #151
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Good day
Under Miscellaneous Thresholds, Radiator Fan Thresholds
has anyone lowered this in order to prevent the IAT's from climbing too quickly in hot climates?
Thank you for the help and advice!
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 03-21-2015, 08:03 PM   #152
s2d4
s2d4's Avatar
Originally Posted by tonystewart View Post
Good day
Yes, lowered but not for the same reason.
Old 03-21-2015, 08:12 PM   #153
tonystewart
Thank you
Your car looks fantastic, those wheels, very nice!
What were the reasons? What values were used?
Thanks again
Old 03-21-2015, 08:57 PM   #154
steve99
Drives: FT86
Thank you
Thanks again
check out the Tune Tweaks link below has links to fan adjustments and thread on adjusting fan settings.
WTB: Open Flash Tablet TOZER Canada Classifieds 3 07-05-2015 08:13 PM
Open Flash Header & Open Flash Tablet Calavera Engine, Exhaust, Bolt-Ons 9 05-11-2015 09:27 PM
FS: open flash headers / open flash tablet - SOLD alanhung85 Canada Classifieds 12 02-10-2015 03:08 PM
FS: Open Flash Tablet (OFT) mex2309 Engine, Exhaust, Bolt-Ons 1 10-29-2014 03:49 PM
Open flash tablet. cooldandani Scion FR-S / Toyota 86 GT86 General Forum 1 02-22-2014 08:14 PM
