Old 02-05-2015, 03:41 PM   #127
Ross
Drives: 85 corolla gts
The intercooler will get sorted after we mount the ac condenser. Finishing up the base mounts for the radiator now. After the the top sports need to be sorted out. Then we will get the a/c condenser figured out.
Ross is offline   Reply With Quote
Old 02-06-2015, 05:30 PM   #128
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
Update:
Radiator fully mounted.
It's a pretty tight fight but it needs to be! Fitting the A/C condenser as well as an intercooler able to support the power I need and want is the reasoning.
Also, ordered the Sound Performance SuckerPunch short shifter and new v160 tripod.
slicktop is offline   Reply With Quote
Old 02-17-2015, 11:23 PM   #129
slicktop
Can't make up my mind on tire compound for the street.
275/40R17 rear
MT ET Streets
Nitto 555R
Continental ExtremeContact DW
245/45R17 fronts
Nitto 555
We get rain here in VA but work is ~5 miles from home which is why the Nitto/Continental's are in there but at this point I'm totally indecisive. Anyone want to toss their opinion in the mix? I'm keeping my stock wheels with all-season/winter tires for predictable weather (incoming storms/snow) being that the car will be my DD when it's completed. I don't drive like an asshole on the street, either.
Pic for update - condenser mounted.
The Following User Says Thank You to slicktop For This Useful Post:
inertia (02-18-2015)
Old 02-18-2015, 01:17 AM   #130
inertia
inertia's Avatar
inertia is offline   Reply With Quote
Old 02-19-2015, 04:39 AM   #131
RRBS
Drives: 2013 Raven FR-S
Very nice build thread. About your tire dilemma my hubby ran M&H Radials on his Supra and 04 Cobra both making north of 1100whp. They drove much better on the street and 60ft better than MTs. Just something to look into
RRBS is offline   Reply With Quote
The Following User Says Thank You to RRBS For This Useful Post:
slicktop (02-19-2015)
Old 02-19-2015, 09:49 AM   #132
slicktop
I have a few weeks before I need to buy tires but I know for sure that I need something that can be daily driven without issue. I'll take a look into them, though! Thanks for the insight
Old 02-19-2015, 04:41 PM   #133
TWMPerformance
Drives: Manual Transmission, All the Way!
This is exactly the type of 2JZ build I've been wanting to see in one of these chassis
Renato
Team TWM Performance
TWMPerformance is offline   Reply With Quote
Old 03-04-2015, 08:35 PM   #134
slicktop
Intercooler came in (no pics until later) and wiring has started. Although I have a Chase Bays harness to integrate, the factory wiring is entirely too messy and presents a fire hazard without proper precautions taken. The build was started to be done the right way or never done at all. There's still a lot left but I'm confident in the guys building the car. They're on point and consistently keep me in the loop.
Driveshaft is on order and exhaust components should be in very soon.
-slicktop
2013 Scion FRS
2JZ-GTE/V160 Swap Build Thread
Jrryjms07 (03-04-2015)
Old 03-19-2015, 10:02 AM   #135
slicktop
Wiring coming along.
Intercooler getting made. Going to be a tight fit!
-slicktop
2013 Scion FRS
Old 03-21-2015, 05:33 AM   #136
Kwoodrow3
Drives: SRT4
You wouldn't happen to have any pics of the wiring harness before it was modified would you?
And what exactly was done with the heater core? It appears to have been pulled back into the dash so that the lines could bend at the firewall?
Kwoodrow3 is offline   Reply With Quote
Old 03-21-2015, 10:57 PM   #137
Ross
No, we did not take any pictures of that. As well that is the harness pre / during modification.
Old 03-24-2015, 04:41 PM   #138
slicktop
Driveshaft came in
-slicktop
2013 Scion FRS
Old 03-24-2015, 08:22 PM   #139
slicktop
Harness is looking great!
@Ross is really putting in work and I can't wait to get back in the car.
-slicktop
2013 Scion FRS
Old 03-29-2015, 05:13 AM   #140
slicktop
This will be my last update until motor start. The current focus to have motor start-up in the next 2 weeks, with driving before May.
Clutchmasters FX850
Motor, trans, driveshaft all in for the final time.
Driveshaft
M85 Differential
-8 AN fuel feed / -6 AN return
Peek into clutch inspection window, hello little guy. You can also see the engine was notched for clearance.
Can see the notch better in this pic
Final placement of the large parts.
Intercooler has since been mounted. It's being painted because of dimensional limitations and as little visual pop as possible.
-slicktop
2013 Scion FRS
The Following 5 Users Say Thank You to slicktop For This Useful Post:
Drift&Drag (03-30-2015), Guff (03-29-2015), Jrryjms07 (03-29-2015), Kuzuri (03-29-2015), rusty959 (03-31-2015)
2jz, 2jz brz gt86 frs swap, 2jz frs, 2jz frs swap, 2jz swap
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 08:52 PM
Mr and Mrs FR-S Build jaydee_do_work Member's Car Journals 2 12-04-2013 10:51 AM
86 BUILD, AUS JS86JS Member's Car Journals 9 05-31-2013 09:59 AM
My build... well some of it cruzinbill Electronics | Audio | NAV | Infotainment 41 04-01-2013 05:02 PM
STX build Evil86 Tracking / Autocross / HPDE / Drifting 2 01-08-2013 04:40 PM
