Old 03-20-2015, 09:02 AM   #211
mad_sb
Drives: 2013 Asphalt FR-S
[Edit: deleted responses to off topic question]
Do you guys have an eta for the first round of dyno testing yet?
mad_sb is offline
Old 03-20-2015, 12:12 PM   #212
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
We're trying to have a working prototype by the end of March.
VerusEric is offline
The Following User Says Thank You to VerusEric For This Useful Post:
8R6 (03-20-2015)
Old 03-20-2015, 12:14 PM   #213
zooki
Drives: waiting on a 2021...
I'm really not liking the math here.
Stock=unique.
Velox=unique.
∴ Velox=stock.
Welcome to the "sensitive era". Everybody is special is their own way. Nobody is better than anybody else, the score is "fun" to "fun". Wouldn't want anybody to feel inadequate now, do we?
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline
The Following User Says Thank You to zooki For This Useful Post:
Captain Snooze (03-20-2015)
Old 03-20-2015, 12:45 PM   #214
gramicci101
Off Topic
That's what happens when you start handing out ribbons for participating instead of winning.
gramicci101 is offline
The Following 4 Users Say Thank You to gramicci101 For This Useful Post:
8R6 (03-20-2015), Captain Snooze (03-20-2015), Koa (03-20-2015), zooki (03-21-2015)
Old 03-20-2015, 01:11 PM   #215
8R6
8R6's Avatar
Drives: FRS
Originally Posted by NotEric6 View Post
If you guys want to start a thread related to cooling the intake charge, I will happily weigh in my thoughts in that thread. I have experience modifying and calibrating on my 500rwhp MR2 Turbo. I have used pump alone, e85 alone, pump with water, pump with meth, and E85 with meth.
Trying to keep this one dedicated to the intake manifold and construction of it .
Thanks guys,
Eric
lol @ username
8R6 is offline
Old 03-20-2015, 01:35 PM   #216
2much
I wanna go fast
Drives: 2013 FR-S 6MT
Originally Posted by BRGT86 View Post
lol @ username
ssssshhhhhhhh!
2much is offline
The Following 2 Users Say Thank You to 2much For This Useful Post:
civicdrivr (03-20-2015), Thedishdoc (03-15-2019)
Old 03-20-2015, 04:15 PM   #217
arghx7
Drives: car
I'm a couple days late to this...
Originally Posted by Calum View Post
To the best of my knowledge, not that has been found so far. Carbed engines, and port injected engines that move the injector to the beginning of the manifold port, make measurably more power than a traditional port injected motor because of the way the fuel will collect along the runner and then evaporate.
Carbs and throttle body injection/distantly placed multiport have more cylinder to cylinder variations in combustion, because now you need to balance airflow and fuel distribution. That's one of the reasons why a conventional port injected engine can make more power - intake manifold design isn't constrained by fuel distribution, unless you count evaporate purge vapors. That's why you see crappy short runner downdraft manifolds on every carb and throttlebody injected engine from the 80s, while you had much more elaborate intake systems with variable intake runners etc on higher end engines.
A few years ago I came across a video showing this effect. In the video an engine running at full power on an engine dyno would develop a layer of frost on its intake manifold. If the engine builder moved the injectors closer to the head it wouldn't cool the intake manifold and thus the intake air, and they lost some power.
You've probably never tuned on an engine dyno before, but this dude's humidity control system was jacked up, or he didn't spend the money on a humidity control system at all. SAE standard power conditions are 25C at the airbox @ 100 kPa air supply pressure, relative humidity under 70%. You don't get frost in those conditions if you set the engine up on the dyno right.
I haven't seen the video but I really question this guy's testing methods or equipment. It goes against common sense - how could direct injection cool an intake charge better than port injection if the coolest charge air comes from having a carb or throttlebody injected engine?
I guess if it gets to a point that the density of the air and thus the larger amount of oxygen available is overshadowed by the heat required to burn that oxygen then cooling the intake charge would be less beneficial. I'd love to hear from @arghx7 on the subject though. Also I wonder if there's a point that the air density could increase cylinder pressures to the point that it wouldn't be possible to maintain MBT?
When it comes to manifold air temperature, the colder the better until you run into some kind of frosting problem (depends on humidity) or thermal shock issues that could break parts. Turbo engines are more prone to knocking so they benefit more.
Really when you are trying to cool an intake manifold, it only makes sense if you have a turbo engine with integrated air-water intercooler inside the manifold like a Ford 1.5L Ecoboost and some of the 1.4L VW turbo engines. Then you might have 30C water flowing through cooling 120C+ hot air coming from the turbo.
arghx7 is offline
The Following 2 Users Say Thank You to arghx7 For This Useful Post:
BRZGM3 (03-26-2015), Dimman (03-23-2015)
Old 03-20-2015, 06:55 PM   #218
Calum
That Guy
Drives: 2013 asphalt FRS MT
The engine was a distantly placed multiport (thanks for the correct terminology) not direct injection.
Thanks for chiming in. Good to see you're still here.
Calum is offline
Old 03-23-2015, 08:36 PM   #219
VerusEric
VerusEric's Avatar
Originally Posted by cdrazic93 View Post
Not to mention it makes tuning that much more complicated.
Originally Posted by s2d4 View Post
It's retarded if one has access to E85.
If not, I still wouldn't run it unless I have to.
Originally Posted by abraxis View Post
Why not just do water/meth injection?
http://www.ft86club.com/forums/showt...74#post2181874
Started a thread dedicated to cooling the charge air.
Their will be updates this week regarding the intake manifold. Some of the pieces are running behind but for the most part we're getting closer and closer.
The Following 4 Users Say Thank You to VerusEric For This Useful Post:
Captain Snooze (03-23-2015), civicdrivr (03-23-2015), ISDriven (03-24-2015), raven1231 (03-23-2015)
Old 03-25-2015, 10:13 AM   #220
VerusEric
VerusEric's Avatar
Guess it's time for an update.
Center section has been welded. Waiting for the o-rings to arrive so that I can pressure test it.
Side note: I am an engineer, not a welder! These are not indicative of the welds a production manifold would see. Our production units will be nicer as they will be professionally tig welded, but due to costs and time, I did the first one.
The Following 16 Users Say Thank You to VerusEric For This Useful Post:
2much (03-25-2015), Calum (03-25-2015), Captain Snooze (03-25-2015), CatDaddysBBQ (04-03-2015), Cop (03-25-2015), DocWalt (03-25-2015), flippy (04-02-2015), Guff (03-25-2015), HatchetBurial (03-29-2015), Jonsey (03-25-2015), Kostamojen (03-25-2015), raven1231 (03-25-2015), slava (03-25-2015), Valentino (05-31-2015), wootwoot (03-25-2015), yo joshman (03-26-2015)
Old 03-25-2015, 01:34 PM   #221
*KID*
86-er
*KID*'s Avatar
Drives: BRZ tS
Winkle black for finishing products
2018 Subaru BRZ ts 020/500 - My Daily, work car, and track car
*KID* is offline
Old 03-25-2015, 04:22 PM   #222
Calum
That Guy
I've seen a lot worse welds from professionals.
Calum is offline
The Following 2 Users Say Thank You to Calum For This Useful Post:
killboy (03-26-2015), Sypher (03-25-2015)
Old 03-25-2015, 05:04 PM   #223
wootwoot
Drives: FRS
From professionals on production units no less. Well done.
wootwoot is offline
Old 03-25-2015, 05:42 PM   #224
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
Was a design with the injectors out of the air stream and positioned directly above the velocity stack ever considered?
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline
The Following User Says Thank You to Hyper4mance2k For This Useful Post:
Turdinator (03-27-2015)
FT-86 SpeedFactory LCA by Verus - Lightest LCA for the Twins - Development Thread FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 236 06-20-2019 02:42 PM
Intake Manifold Bu-Tang Engine, Exhaust, Transmission 29 12-06-2014 02:43 PM
Intake manifold viking Engine, Exhaust, Transmission 6 09-24-2014 12:08 AM
Oil on/around Intake Manifold Wepeel Issues | Warranty | Recalls / TSB 2 05-13-2014 12:40 AM
WTB: intake manifold carlitosway6891 Engine, Exhaust, Bolt-Ons 0 06-22-2013 03:24 PM
