Old 03-13-2015, 04:09 PM   #1
Raven604
Best Engine Bay oil cleanup products
Hi I double sealed my filter, I know, rookie mistake, and got oil all over the Bay. What products are recommended to clean this mess up.
Raven604 is offline   Reply With Quote
Old 03-13-2015, 05:01 PM   #2
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
I like this product:
Extreme Simple Green® Aircraft & Precision Cleaner
It does the job and doesn't harm aluminum or plastics. Regular Simple Green can contribute to aluminum corrosion.
My cars always dress formally. They all wear black tires.
Black Tire is offline   Reply With Quote
Old 03-13-2015, 06:47 PM   #3
Poodles
Drives: 2015 Series.Blue
That stuff isn't easy to find though.
Use a real engine degreaser as it's made to not harm the various materials under the hood, and it's easy to find.
Don't use:
- Normal Simple Green
- Super Clean
- Purple Power
All of them will attack aluminum, paint, and rubber.
Old 03-13-2015, 07:51 PM   #4
orangeblue
Drives: Whiteout
Steam.
orangeblue is offline   Reply With Quote
Old 03-14-2015, 01:25 AM   #5
Back in the day ...... we just used gasoline and an old paint brush .......
Not that I ever did anything stupid like that ......
Tcoat (03-14-2015), Teseo (03-14-2015)
Old 03-14-2015, 04:45 AM   #6
Yep!
If you have never half destroyed your parents asphalt laneway you have never truly cleaned your engine!
Old 03-15-2015, 02:33 PM   #7
M12Power
M12Power's Avatar
Drives: 2015 Firestorm Scion FR-S 6MT
I would wipe off the excesses first and then probably just use WD-40 to clean it off...
M12Power is offline   Reply With Quote
Old 03-16-2015, 10:49 PM   #8
Raven604
Thanks guys
DIY GrimmSpeed/Perrin Front Plate Mount Cleanup zohaib DIY (Do-It-Yourself) Guides 19 09-15-2019 04:00 PM
FS thread cleanup Hyper4mance2k Southern California 48 05-07-2015 03:58 PM
Engine Dress-Up, Heat Shielding & Motor Oil products @ OAKOS.com OAKOS Automotive Engine, Exhaust, Bolt-Ons 192 02-13-2015 02:38 PM
Check Engine light on @5.7k miles and engine stalling at 4,000 rpms? djdrugga24 Issues | Warranty | Recalls / TSB 3 06-25-2014 07:06 AM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 07:50 AM
