Old 07-24-2013, 07:40 PM   #1
zohaib
Wrong Wheel Drive :(
zohaib's Avatar
Drives: FiST
Cool DIY GrimmSpeed/Perrin Front Plate Mount Cleanup
So I installed the GrimmSpeed Front License Plate Mount today, and was very unsatisfied with the messy opening left behind by removing the tow hook cover:
I mean, who wants to see styrofoam on their car? So I did what any man of action would do and decided to do a little cleanup. You're gonna need:
  • Drill with 1" Drill Bit (I used a spade bit since it's plastic, leaves a cleaner hole)
  • A nice cold drink
First, pop the cover off the bumper and bring it to your base. On the back there is an embossed "SUBARU" logo. Line up the center of the drill bit to this spot:
Then drill baby drill:
I actually started with a 3/4" bit, but quickly realized that it was to small. Lucky for you I've already made that mistake so you don't have to. Go out to the car and pop it on:
Install your plate bracket and you're done! Take a few steps back and pat yourself on the back!
Now go open up your beverage of choice and chillax, cuz you're 31337 h4x0r!
*I did not check this on the Perrin mount, but by the looks of it you may need a larger bit, the tow hook bolt seems larger. If someone is daring enough to try and post feedback, please don't hesitate!
Ford Fiesta STmountune
wrong wheel drive club of america
zohaib is offline   Reply With Quote
Old 07-24-2013, 07:52 PM   #2
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
Nice! We did this with our front and rear tow hooks, so much cleaner than an open hole in the bumper lol.
Thanks,
Rick
RallySport Direct is offline   Reply With Quote
Old 07-25-2013, 02:03 AM   #3
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Drives: 13 BRZ, Galaxy Blue Silica
Thank you for identifying the center drill point, I've been meaning to do this but I have been too lazy to pull it off.
:happy0180:
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα
Cjymiller is offline   Reply With Quote
Old 07-26-2013, 09:31 PM   #4
br_z1Lch
br_z1Lch's Avatar
Drives: 2013 BRZ(swp) Limited
I can't believe I just found this. I was just about to step out to do some measurements for where to drill and figured I'd see if anyone had found a good spot.
Thank you so much for pointing it out and saving me a little time!
br_z1Lch is offline   Reply With Quote
Old 07-29-2013, 10:54 AM   #5
Fett4Real
AKA Mugen Dom
Fett4Real's Avatar
Drives: 2013 FR-S, 2007 FJ Voodoo Blue
not a bad idea...
Fett4Real is offline   Reply With Quote
Old 07-29-2013, 01:42 PM   #6
mush
mush's Avatar
i ordered the tow hook mount for my frs... was going to install it but noticed that there was Styrofoam exposed so i just mounted the plates to the black grill
Old 07-29-2013, 03:46 PM   #7
iketeru
Drives: Whiteout 6MT FR-S
would be nice if someone did this for the FR-S as well...
iketeru is offline   Reply With Quote
Old 07-29-2013, 04:11 PM   #8
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
People have done this with the frs.... just buy a tow hook cover (about $20 I believe) then mark it and drill. Now you got one with hole for front plates and another to revert.
Old 07-29-2013, 04:40 PM   #9
iketeru
yeah, I've seen those posts before. it just seems convenient to know the exact point to drill, like shown in this DIY...instead of having to make a paper template, which seems less accurate.
Old 07-29-2013, 04:47 PM   #10
Wes
Wes's Avatar
Thats true, maybe you can be the founder to this exact location haha
Old 07-29-2013, 07:18 PM   #11
MadFRS
MadFRS's Avatar
Drives: UltraMarine FR-S
Just went to the home improvement store to buy a 1" spade bit and try this on my frs. Installed the grimmspeed this weekend.
I had to shave mine a bit as I was a bit low on my eye check, but on the frs the center point is closer to the left middle of the 'S'. There's maybe an 1/8" gap on the bottom and tight all the other sides. The frs is much more in the 1 o'clock position.
Def worth a shot. Even if you are slightly off, you can shave it cleanly with a sharp utility knife
She's Gone....
Flickr Page
MadFRS is offline   Reply With Quote
Old 07-29-2013, 09:21 PM   #12
mush
mush's Avatar
another thing is when u wash ur car... u need to remove it to clean that area or just spray it
Old 08-06-2013, 09:48 AM   #13
zohaib
zohaib's Avatar
Drives: FiST
You can mount it so there is a wee little gap between the back of the plate and the bumper, and let the wash take care of it. Or in my case, just sneak a wet rag behind the plate :p
Old 08-06-2013, 09:48 AM   #14
zohaib
zohaib's Avatar
Drives: FiST
Also, all y'alls are awesome.
FS: Grimmspeed Side plate mount kit. Flawless22 Canada Classifieds 0 06-24-2013 03:49 PM
DIY: Making a GoPro camera mount with a GrimmSpeed front plate mount PMok DIY (Do-It-Yourself) Guides 2 06-11-2013 10:58 AM
license plate mount by grimmspeed ft86me Cosmetic Modification (Interior/Exterior/Lighting) 2 02-11-2013 10:48 AM
How do you mount the front plate? sa1126 Scion FR-S / Toyota 86 GT86 General Forum 71 11-06-2012 08:24 PM
For those of you with grimmspeed or perrin license plate relocator Brimford Cosmetic Modification (Interior/Exterior/Lighting) 24 10-16-2012 08:57 PM
