Old 03-03-2015, 09:09 AM   #337
MacOverSteer
MacOverSteer's Avatar
Drives: 2013 GT86
16's look good even when not lowered/slammed, IMO.
MacOverSteer is offline   Reply With Quote
The Following 4 Users Say Thank You to MacOverSteer For This Useful Post:
chaoskaze (09-08-2015), M23 (03-03-2015), stevesnj (03-03-2015), Trettiosjuan (04-12-2015)
Old 03-05-2015, 07:55 AM   #338
Shit Luck
Drives: red frs
wheels should arrive today.
I need to get my brake template out and get my hub conversion done so I can test fit.
Shit Luck is offline   Reply With Quote
Old 03-05-2015, 09:00 AM   #339
troek
troek's Avatar
Drives: 2012 Toyota 86
Originally Posted by DustinS View Post
It's a kit designed to fit the wilwood forged super light onto a STI rotor. Not sure what clearance the wilwood kit would have. Though I do believe the 4 piston kit uses a smaller rotor(304mm compared to STI 326mm) so you should have no issues. You just might have to use spacers to get them out far enough.
you fit a 326mm rotor in a 16" wheel?
troek is offline   Reply With Quote
Old 03-08-2015, 06:48 PM   #340
yo joshman
yo joshman's Avatar
Drives: ae86/frs
Originally Posted by GuerillaRacing View Post
No prob. That's my personal car!
It is 225/50/16 tires and Megan Racing track series coilovers (not slammed down).
More pics
How did the car handle on the corners with this setup? Did you feel a lot more body roll on initial entry as oppose to 17inch setup. Ive been thinking about a 16 inch setup for a while. Your input will be appreciated. Thanks!
yo joshman is offline   Reply With Quote
Old 03-09-2015, 04:33 AM   #341
MacOverSteer
Drives: 2013 GT86
Nissan's new GT-R LM is running 16's. More sidewall more contact patch....
The Following User Says Thank You to MacOverSteer For This Useful Post:
NissanGuy (04-12-2015)
Old 03-09-2015, 10:46 AM   #342
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Yes
The Following User Says Thank You to DustinS For This Useful Post:
troek (03-09-2015)
Old 03-09-2015, 03:47 PM   #343
GuerillaRacing
GuerillaRacing's Avatar
Drives: Scion FR-S
I haven't tracked it on the 16" setup so really couldn't give a straight answer. It seems like the rear end is easier to kick out on the 16's though, coming from the 18's.
GuerillaRacing is offline   Reply With Quote
The Following User Says Thank You to GuerillaRacing For This Useful Post:
yo joshman (03-10-2015)
Old 03-09-2015, 04:51 PM   #344
stevesnj
stevesnj's Avatar
I am really liking these XXR 551 wheels in 16x8 I just gotta figure out the offsets up front and back. I'm liking the Chromium Black , not black, not grey. I think they will look good with a blue FR-S
http://www.xxrwheels.com/wheels/xxr-551
My 2016 Build thread
Old 03-09-2015, 05:14 PM   #345
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Just picked up a set of barely used Motegi Traklites in 16x7 ET40 (12.5 lbs each), wrapped in Kumho Ecsta XS 225/50-16. Can't wait for April to get here!
The Following User Says Thank You to venturaII For This Useful Post:
Trettiosjuan (03-09-2015)
Old 03-09-2015, 11:29 PM   #346
Shit Luck
Drives: red frs
So my wheels appear to clear the brakes...
The Following 2 Users Say Thank You to Shit Luck For This Useful Post:
chaoskaze (03-10-2015), DustinS (03-10-2015)
Old 03-10-2015, 08:19 PM   #347
yo joshman
yo joshman's Avatar
Drives: ae86/frs
Im really curious to see how much more roll will result because of the taller sidewall. The back end coming out easier could be both positive and negative depending on the intended purpose. Interesting.....
Old 03-13-2015, 01:18 PM   #348
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
A comparison between 16inch and 17inch stock wheels and tires:
Circuit is Suzuka.
The Following 4 Users Say Thank You to nikitopo For This Useful Post:
flippy (04-13-2015), GuerillaRacing (03-13-2015), Trettiosjuan (03-14-2015), yo joshman (10-08-2015)
Old 03-14-2015, 12:26 PM   #349
AllStar0419
AllStar0419's Avatar
Drives: 2013 FR-S Asphalt
I posted a while back but didn't have a good pic. Currently lowered 1" with Enkei EDR9 as my winter setup.
AllStar0419 is offline   Reply With Quote
The Following User Says Thank You to AllStar0419 For This Useful Post:
Old 03-14-2015, 12:45 PM   #350
Shit Luck
Drives: red frs
mine are getting coated and rebuilt right now.
I need to get some 11mm conversion spacers yet.
Wheel Directory: Styluz S006 18x7.5 +40 Pavel Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 23 01-22-2014 04:16 PM
FS [SYD] 16 inch GT wheels and tires! luv85 Australia Classifieds 3 11-04-2012 06:15 AM
Help! Two 10 inch vs One 10 (or 12) inch cyntage Electronics | Audio | NAV | Infotainment 7 09-27-2012 11:20 PM
I need 19 inch wheels today! benqld7 AUSTRALIA 16 08-07-2012 08:33 AM
16 inch wheels for the base model!!! Blokatos Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 12-07-2011 11:17 AM
