Old 03-04-2015, 05:33 PM   #2703
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Originally Posted by HGaudio View Post
Will enkei rpf1's 18x9.5's fit if my car is on eibach sport line springs? I can't find rpf1's in 18x8.5 for the front
Start here and look through this thread:
http://www.ft86club.com/forums/showthread.php?t=60112
and see what setups these guys are running.
In my experience, you won't be able to fit these wheels without going to coilovers.
That said, sometimes one can make things work but that would mean having some poke and no more than 2 deg of camber. You likely already have more due to the drop on Sportlines. That would mean adding a spacer which is even more poke.
Slick is offline   Reply With Quote
Old 03-04-2015, 09:41 PM   #2704
FT_86_SM_GP
FT_86_SM_GP's Avatar
Drives: Lawn moweR
Hi (To the Wheel Guru's)
I need some of your guys advice.
I am trying to decide on the following set ups:
1) XXR 527 18x8.75 +35mm offset (225/40/18 Tyre)
-With BC BR Coilovers
Or
2) XXR 527 18x8.75 +20mm offset (225/40/18 Tyre)
-SPC LCA (For a -2 Degree Camber adjustment)
-Rolled fenders
Has anyone tried the second option? I have been looking far and wide, and could not find much on the XXR 527 18x8.75 +20mm
Everyone that went for the +20mm offset rim chose the 9.5J ....
Reason for that being ? Go Big or Go Home?(STANCE) Or is the 8.75J 20mm offset not appealing?
I am trying to figure out if it will be a little more practical than the 9.5J 20mm
(I am not after stance, but I am after an aggressive look, I need to find out if the +20mm Offset will be reasonably practical for daily driving)
(I think I need to learn more about wheel set up)
Your help is appreciated.
FT_86_SM_GP is offline   Reply With Quote
Old 03-10-2015, 03:10 PM   #2705
thunderlights
hi i have gram lights 57xtremes 18x9.5 et 40's all around, im sitting on a 235 tire, and i dont like the stretch fitment. I want to go to a 255 section all around, will it hit the spring perch? im all stock suspension, i do want to lower the car 1'' but without going to coilovers. thanks!
thunderlights is offline   Reply With Quote
Old 03-11-2015, 02:31 AM   #2706
corry29
corry29's Avatar
Okay, Hi guys, I'm back. This time I'm set and know what exactly what I want.
My FRS is on TRD springs.
Apparently the only rims I can really settle on are TE37SL
So I want to know will this clear my TRD springs + stock strut,
TE37SL: 17x 8.5 +45
Tires: Yokohama Advan Neova AD08 245/40
I'm trying to get a -1.4 camber all around.
Will I be able to clear this without spacers? So far I only have front camber bolts and adjustable lower control arms on it's way (not yet installed)
corry29 is offline   Reply With Quote
Old 03-11-2015, 09:33 AM   #2707
jshadeck
jshadeck's Avatar
I would also like to hear from people running 8.5 +44(or close) fronts, on springs not coilovers, and how much camber you are able to run in the front, thanks
jshadeck is offline   Reply With Quote
Old 03-12-2015, 09:55 PM   #2708
Beachnuttz
Beachnuttz's Avatar
Drives: '13 Firestorm
Hey there, I used to live in Mechanicsburg. I am on TRD springs, 8.5 45 with a 235 tire square set up. The dealer installed the springs, and set camber to spec. No issues
TRD Lowering Springs
TRD Front and rear sway bars
Perrin 3 inch Cat Back Exhaust
Beachnuttz is offline   Reply With Quote
Old 03-13-2015, 02:11 AM   #2709
jshadeck
jshadeck's Avatar
Yea me too, im actually trying to get -1.8 or so but even with 5mm spacers the shop only felt comfortable going to -0.5 😕
Old 03-14-2015, 03:00 AM   #2710
Rice Plz
Rice Plz's Avatar
Drives: 2015 FR-S Halo
Fast FC04 18x9.0 +40 or +30 (Which is going to get it more flush?) on stock or possibly TRD lowering springs, doable, with what size wheels? Not knowledgeable on this stuff. =/
Rice Plz is offline   Reply With Quote
Old 03-14-2015, 03:23 AM   #2711
Belzak
Drives: White 2015
Hi guys. I'm new here and have been doing a lot of trolling around but I haven't found a conclusive answer. I hope you can help me out.
I'm looking to run a 9.5" wheel with as minimal amount of poke as possible. It seems like the most common offset for 18x9.5" is +38mm. The problem is, I want to stay on stock suspension, and, at least from my estimations, a wheel that size will need at least a 12mm spacer to fit without hitting the suspension. I'm not willing to do that, so these will have to hold off until I get coilovers if true.
My fallback plan was to get RPF1's in 17x9" +35mm. It seems like these should *just barely* fit without any issues, but I would like some confirmation before I pull the trigger on these. Has anyone had firsthand experience with this setup?
Another question, in case the 17x9's actually don't fit, how big of a slide-on spacer can I safely use without replacing the wheel studs? I wouldn't think I would need anything more than 3mm.
Thanks for the help and pardon my noobishness hahah.
Belzak is offline   Reply With Quote
Old 03-14-2015, 12:14 PM   #2712
HGaudio
Drives: 13' Scion FRS
Originally Posted by Killerbee View Post
Depends on the offset, and the tires you want to run. However they will most probably stick out of the fenders, but if the offset is not to low they should fit (but again, they will stick out). If you post the offset and tires you want to run I can help you more.
The offset of them is +35
HGaudio is offline   Reply With Quote
Old 03-14-2015, 07:26 PM   #2713
Eseigs
Eseigs's Avatar
Drives: 2015 FRS RS1
Sitting on TRD springs (1.125 inches lowered) and stock struts:
Looking at getting ZE40's deciding between staggered 18x8.5, 9.5 or 18x9 squared.
Leaning towards 18x9 +40 (with 245/35/18) squared right now and was wondering if I'd have any problems with rubbing or hitting the struts (especially in the front).
Eseigs is offline   Reply With Quote
Old 03-15-2015, 01:23 PM   #2714
jshadeck
jshadeck's Avatar
Will this fit? (width, offset and tire size Qs)
18 9.5 et38 will not hit suspension, i ran those for a year both stock and lowered on eibach springs w zero issues. But they poke, theres no way to fit a 9.5 wide front wheel w out poke unless you get coilovers. 17 9 et35 would also fit, and poke less no spacer needed. Where are you seeing info that these sizes will hit suspension?
Attachment 104563
Top pics are 9.5 et38 bottom pics are 8.5 et44
Old 03-17-2015, 11:18 AM   #2715
FRSPhil
Nobody Epic
FRSPhil's Avatar
Drives: 2014 WRX SWP
I need a recommended tire size and brand for my enkie raijin 18x8 +45 and 18x8.5 +45. I had seen a post on another thread that had mentioned 225/40 for the 18x8 and 245/35 for the 18x8.5. Need something good in the wet and dry I live in the east coast.
FRSPhil is offline   Reply With Quote
Old 03-17-2015, 01:34 PM   #2716
thunderlights
Attachment 104563
sorry to jump in here but how wide of a tire would fit front and rear on a 18X9.5 et38? im running 18X9.5 et 40's, is that a big difference?
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
