Old 03-12-2015, 07:34 PM   #15
extrashaky
Drives: 2014 BRZ Limited
Originally Posted by jblmr2 View Post
They worked well for reducing heat in the car, but were a PITA when came to cleaning the window.
Which is probably why they died.
I remember all the otherwise cool cars that looked like shit because the louvers trapped all kind of crap against the windows. Your car would need a wash that much faster because of the gunk caught around the edges that would slide right off other cars. The pics on here never show you that part.
Old 03-12-2015, 09:12 PM   #16
NemesisPrime909
NemesisPrime909's Avatar
Drives: 91 Toyota Supra 16 Nissan Versa
well here's a question, how difficult are they the remove when you need to clean the back window?
The FRS/BRZ was not meant to be a world beating car, it was not meant to be an extremely fast car, nor a powerful car, but a well balanced fun car.
NemesisPrime909 is offline   Reply With Quote
Old 03-12-2015, 09:20 PM   #17
In the DIY link above. Pull 8 countersunk bolts and lift it off. They say is really easy.
Dadhawk (03-23-2015), NemesisPrime909 (03-13-2015)
Old 03-13-2015, 12:18 PM   #18
fitcious
ive seen it in real life and its really really nice. The quality on it is great. But i did do some research online and it seems pretty pricey...over a $1k
fitcious is offline   Reply With Quote
Old 03-13-2015, 02:44 PM   #19
Ebay had some knock offs for about $250 but too lazy to go see if they still do.
Now...this is likely the perfect example of "you get what you pay for" and I can imagine the $250 ones are worth every reduced cent as they will probably either fly off your car on the highway or never come off again to be able to wash the window!
Old 03-13-2015, 04:11 PM   #20
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Looking at this thread again I'm really sad the first response isn't "A fence"
ineedyourdiddly
Old 03-13-2015, 04:16 PM   #21
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
I'm old enough for louvers to remind me of the dark age of car styling (70's...). That being said, I had them on a 1st gen RX7 and an Alfa GTV6 and they do make quite a difference in the heat coming in from the sun. They used to be made of thin stamped aluminum sheet, so they were pretty thin and didn't hinder rear visibility much, but the ones for the FT86 look like they're plastic and have thicker slats, although the smaller overall size of the slats does makes them look a bit more neat than the big ones from the 70's...
Old 03-13-2015, 05:19 PM   #22
NemesisPrime909
i scrolled too fast and missed that post
thanks for pointing it out
The Following User Says Thank You to NemesisPrime909 For This Useful Post:
Tcoat (03-13-2015)
Old 03-13-2015, 05:31 PM   #23
ls1ac
ls1ac's Avatar
louvers ala 1968
why when I resize to the lower pixel size do they display so small??
Old 03-13-2015, 05:32 PM   #24
ls1ac
ls1ac's Avatar
ok wrong pic.
try again
Old 03-20-2015, 11:30 PM   #25
Floggin Tires
Floggin Tires's Avatar
Drives: ZC6, Junk of ALL sorts
Originally Posted by ls1ac View Post
try agian
ala: MGB GT
# 1. Always know where your towel is.
ZC6-CBS, is home
Floggin Tires is offline   Reply With Quote
Old 03-20-2015, 11:39 PM   #26
try again
Well technically there are louvers in your first pic as well! They just aren't on the window.
Old 03-20-2015, 11:47 PM   #27
Teseo
Drives: frs
When i was a kid i thought that was a "kind" of spoiler to create downforce and still looking stock
The Following User Says Thank You to Teseo For This Useful Post:
Tcoat (03-20-2015)
Old 03-21-2015, 02:48 AM   #28
Have to admit I did too! (They were really rare and only on some pretty heavy duty cars)
Dadhawk (03-23-2015), Teseo (03-21-2015)
Is our car going to be called the F1Z? 5th 86 Scion FR-S / Toyota 86 GT86 General Forum 9 06-18-2013 10:18 PM
What are these called and where do I buy them? l0aded Cosmetic Modification (Interior/Exterior/Lighting) 7 02-09-2013 11:52 AM
Dealer just called me FJ40crusher BRZ First-Gen (2012+) — General Topics 28 11-05-2012 12:42 PM
What will it actually be called? Hounddub Scion FR-S / Toyota 86 GT86 General Forum 13 09-28-2011 09:58 AM
