Old 03-11-2015, 06:39 PM   #1
MicheleAbbate
MicheleAbbate's Avatar
Drives: Grr Racing FRS & BRZ
Send a message via AIM to MicheleAbbate
Routing the APR Brake Ducts
Hey guys! We just got done installed my APR brake duct kit and after some interest on instagram and facebook I figured I'd toss up a quick "how-to" on my site. Here's the link with photos:
http://m1cheleabbate.com/routing-the...s-brake-ducts/
www.GrrRacing.com - Won Scion's first Road Racing Championship in 2011. Raced the Grr Racing Scion FRS from 2014-2018. Have lots of OEM Part FS. lol Check my thread. Now I race in Trans Am TA2.
MicheleAbbate is offline   Reply With Quote
Old 03-11-2015, 07:08 PM   #2
CSG David
CSG David's Avatar
Nice work Michele!
Old 03-11-2015, 08:17 PM   #3
troek
troek's Avatar
Drives: 2012 Toyota 86
I have mine routed a little different, but yours seems better. my hoses have some tears and i will eventually replace, using your routing most likely. I havnt had fluid in my washer reservoir for over a month, so I might as well remove that lol.
troek is offline   Reply With Quote
Old 03-12-2015, 12:24 PM   #4
8R6
8R6's Avatar
Drives: FRS
legit!
8R6 is offline   Reply With Quote
Old 03-12-2015, 01:43 PM   #5
MicheleAbbate
awesome, glad this is helpful! i couldn't find anything for the install.
Old 05-19-2015, 06:32 PM   #6
philooo
Drives: 13' Scion FRS Track car
does anybody know if the APR duct kit is compatible with the AP Racing Sprint kit ?
philooo is offline   Reply With Quote
Old 05-19-2015, 10:53 PM   #7
churchx
churchx's Avatar
Drives: 2014 GT86
IIRC Endurance only.
Old 12-30-2015, 11:09 AM   #8
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
Sorry to bring this back from the dead but have you noticed any temperature difference with this kit?
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 12-30-2015, 11:11 AM   #9
MicheleAbbate
No problem. Yes, of course. I don't have my race binder with me at the moment but we no longer have heat stress marks on our rotors.
Old 02-19-2016, 12:00 AM   #10
Uplink
Uplink's Avatar
Drives: anything you let me
@philooo Yep, MotoIQ got some pics from APR and a response back questioning air delivery. They said on the Sprint Kit (shown) it's 70/30 ring to hub and on larger rotor kits it's about 50/50.
Uplink is offline   Reply With Quote
Old 02-19-2016, 01:17 AM   #11
Uplink
Uplink's Avatar
@MicheleAbbate Thanks for putting this together, great shots! Did your kit come with instructions? I e-mailed APR and they gave me a link to the .PDF (not readily available from their support page) with fairly detailed steps. If anyone needs it, PM me.
One important note for people that still have all the factory plastic in place, there are splash guards at the engine side of the control arms that need to be cut significantly to feed the hoses through to the calipers. These are APR's how-to pics.
Old 02-19-2016, 10:52 AM   #12
endless_pain
Pissin off regressives
endless_pain's Avatar
Drives: They have engines.
Don't know if APR changed their mold, but mine did not fit either side. Do you know if they had to modify the backing plates?
endless_pain is offline   Reply With Quote
Old 02-19-2016, 11:12 AM   #13
Uplink
Uplink's Avatar
Not sure. When did you order yours? I haven't personally picked up the set yet because the prices went up so I'm waiting on a sale.
From the pictures it looks REALLY close and barely has room for deflection.
Old 02-19-2016, 11:47 AM   #14
philooo
I have installed my APR just like in the photo above and I had a slight rub may be 1/16. I tried to sand it down by hand but the carbon is hard as metal...ery well built ! So I decided to let the rotor do their work ... and they rubbed in a little bit and now it is as tight as can be.
Could I see how you router your ducts ? I see that you kept the washer fluid container, I have no idea how it fit with that thing in place ?
Brake Cooling Routing with Turbo Kit pleong Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 09-08-2014 03:15 PM
APR Brake Ducts msile Cosmetic Modification (Interior/Exterior/Lighting) 23 09-08-2014 01:30 PM
Brake Air Ducts kombatlion Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 07-17-2014 04:39 PM
Project Mu Brake Ducts Now Available! Xero-Limit Brakes, Suspension, Chassis 1 06-11-2014 09:42 AM
Brake Ducting/Hose Routing? swift996 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 01-13-2014 03:20 PM
