| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#337 |
Drives: 2013 GT86
16's look good even when not lowered/slammed, IMO.
| The Following 4 Users Say Thank You to MacOverSteer For This Useful Post: |
#338 |
Drives: red frs
wheels should arrive today.
I need to get my brake template out and get my hub conversion done so I can test fit. |
#339 | |
Drives: 2012 Toyota 86
#340 | |
Drives: ae86/frs
#341 |
Drives: 2013 GT86
Nissan's new GT-R LM is running 16's. More sidewall more contact patch....
| The Following User Says Thank You to MacOverSteer For This Useful Post: | NissanGuy (04-12-2015) |
#342 |
Drives: 2013 Ultramarine FR-S
| The Following User Says Thank You to DustinS For This Useful Post: | troek (03-09-2015) |
#343 |
Drives: Scion FR-S
I haven't tracked it on the 16" setup so really couldn't give a straight answer. It seems like the rear end is easier to kick out on the 16's though, coming from the 18's.
| The Following User Says Thank You to GuerillaRacing For This Useful Post: | yo joshman (03-10-2015) |
#344 |
I am really liking these XXR 551 wheels in 16x8 I just gotta figure out the offsets up front and back. I'm liking the Chromium Black , not black, not grey. I think they will look good with a blue FR-S
http://www.xxrwheels.com/wheels/xxr-551
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#345 |
Only users lose drugs.
Drives: All the time
Just picked up a set of barely used Motegi Traklites in 16x7 ET40 (12.5 lbs each), wrapped in Kumho Ecsta XS 225/50-16. Can't wait for April to get here!
| The Following User Says Thank You to venturaII For This Useful Post: | Trettiosjuan (03-09-2015) |
#346 |
Drives: red frs
#347 | |
Drives: ae86/frs
Im really curious to see how much more roll will result because of the taller sidewall. The back end coming out easier could be both positive and negative depending on the intended purpose. Interesting..... |
#348 |
Drives: '15 BRZ RA
A comparison between 16inch and 17inch stock wheels and tires:
![]() Circuit is Suzuka. |
| The Following 4 Users Say Thank You to nikitopo For This Useful Post: | flippy (04-13-2015), GuerillaRacing (03-13-2015), Trettiosjuan (03-14-2015), yo joshman (10-08-2015) |
#349 |
Drives: 2013 FR-S Asphalt
| The Following User Says Thank You to AllStar0419 For This Useful Post: | Trettiosjuan (03-14-2015) |
#350 |
Drives: red frs
mine are getting coated and rebuilt right now.
I need to get some 11mm conversion spacers yet. |
| Wheel Directory: Styluz S006 18x7.5 +40 | Pavel | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 23 | 01-22-2014 04:16 PM |
| FS [SYD] 16 inch GT wheels and tires! | luv85 | Australia Classifieds | 3 | 11-04-2012 06:15 AM |
| Help! Two 10 inch vs One 10 (or 12) inch | cyntage | Electronics | Audio | NAV | Infotainment | 7 | 09-27-2012 11:20 PM |
| I need 19 inch wheels today! | benqld7 | AUSTRALIA | 16 | 08-07-2012 08:33 AM |
| 16 inch wheels for the base model!!! | Blokatos | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 12-07-2011 11:17 AM |
