Old 03-08-2015, 09:58 PM   #15
Kostamojen
Originally Posted by dannythetran View Post
it is used but it is certified.
Having worked at a dealership... That doesn't mean a damn thing.
They could have had the car slammed and drove the piss out of it, and then swapped stock springs back in.
But if you really want to try and "fix" the ride and think nothing is wrong... Then there are a few things you can do:
1. 16" wheels with taller tires (more sidewall = more flex = less rough ride)
2. FRS front springs (softer than BRZ front springs)
3. Better shocks that dampen the ride more.
But thats about all I can come up with... IMO this car "rides" just like a WRX/STI, and rightly so considering the suspension is basically the same. I've never felt uncomfortable with it, and I test drove a dozen or so different cars before buying the BRZ.
The Following 2 Users Say Thank You to Kostamojen For This Useful Post:
dannythetran (03-08-2015), NissanGuy (03-09-2015)
Old 03-08-2015, 10:41 PM   #16
Burrcold
Drives: Subaru BRZ Limited
Are you even sure that it's riding on the stock suspension?? Given that it's used...
The Following User Says Thank You to Burrcold For This Useful Post:
D_Thissen (03-09-2015)
Old 03-08-2015, 11:55 PM   #17
dannythetran
I'm not exactly sure but I am 90% positive it is. It looked stock when I was changing my exhaust.
Invidia Q300, Invidia catted front pipe, K&N air filter, DDM 3K yellow fogs, LED all around, and overlay taillight.
dannythetran is offline   Reply With Quote
Old 03-09-2015, 01:57 AM   #18
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by Simplicity View Post
my car literally flys off
Your use of "literally" is literally incorrect.
The Following 6 Users Say Thank You to Captain Snooze For This Useful Post:
8R6 (03-09-2015), cdrazic93 (03-09-2015), chubky (03-10-2015), juliog (03-09-2015), rlpaul (03-09-2015), Turdinator (03-09-2015)
Old 03-09-2015, 01:52 PM   #19
Poodles
Drives: 2015 Series.Blue
I have been reading around on the forums and I wanted everyone's opinion on it.
I have been reading that the stock suspension is the most comfortable compared to other after market suspension. I have been in several different cars and to be honest, the brz suspension is so stiff. I can feel every bump on the road. I'm not expecting it to feel like a Lexus and I know that it is a sports car. My old 01 accord dropped on springs were a lot better at absorbing stock then the brz. I haven't been in any other 86 then my own so I was wondering if maybe something was wrong with my suspension?
1) It's going to ride harsh when it's cold out. Tires have turned into wood and the bushings have too.
2) 2001 Accord is quite a lot heavier than this car and it's not a sports car. It's Honda's completion for the Camry so...
3) What year do you have? 2015 has reworked spring/dampers and rides nicer.
4) Aftermarket suspension can ride as good if not better than OEM, but you're paying a hell of a lot for it.
Old 03-09-2015, 10:14 PM   #20
NissanGuy
NissanGuy's Avatar
Drives: Strangely.
Come to think of it, can anyone think of an OEM vehicle that rides worse than BRZ? I haven't found one, harshest I've tried was probably MINI with 18" wheels. Special mention goes to Hyundai Accent for frightening body motion AND harsh damping.
Trucks can be a special kind of uncomfortable, but not harsh per se. Corvettes, MR2s, Miatas, and Zs all feel orders of magnitude softer to me. Z4 actually is roughly as stiff but it's so well-damped that it rides just fine, same story with M5 and M3.
My FR-S has a build thread!
(It's mostly full of Nissans)
NissanGuy is offline   Reply With Quote
Old 03-10-2015, 12:13 AM   #21
Poodles
Girlfriend's Kia Soul rides worse. Then again, I have a 2015 BRZ...
Old 03-10-2015, 12:25 AM   #22
Koa
yea and how much more is the Z bud?
Just some food for thought.
I'm not fanboying over here, I agree with you on the ride "quality".... but performance-wise, I can't think of a ~$25k car that handles better. Note I didn't say is more comfortable to cruise in.
Old 03-10-2015, 12:51 AM   #23
Turdinator
Señor Member
Turdinator's Avatar
The stock suspension is firm. Every friend I have driven in my 86 has commented that it is quite firm. I don't find it uncomfortable however comfort is very subjective. If you are concerned it is harsher than it should be then get it checked out. If it is as it should be there are other options out there to improve the ride comfort you do risk losing the sharp handling the twins are known for however.
1974 TA22 Celica
2013 86 GT
Old 03-10-2015, 03:38 AM   #24
NissanGuy
NissanGuy's Avatar
Drives: Strangely.
I suppose it depends on your definition of handling, but a base MINI on sixteens is sticky.
The Following User Says Thank You to NissanGuy For This Useful Post:
Koa (03-10-2015)
Old 03-10-2015, 04:20 AM   #25
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
stock tire isn't comfy to ride on too, I sat in one with Bridgestone RE760 & can confirm it rides smoother & quieter.
Old 03-10-2015, 07:17 AM   #26
Captain Snooze
Drives: Red Herring
I haven't been in any other 86 then my own so I was wondering if maybe something was wrong with my expectation?
Fixed.
most comfortable shock with Eibach Pro Kit Crashhollywood12 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 01-15-2016 12:01 PM
Which is the most comfortable coilover on brz/frs?? HowL Suspension | Chassis | Brakes -- Sponsored by 949 Racing 79 04-27-2015 08:02 AM
Lowering the car and a comfortable ride etherealfall Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 12-21-2014 03:03 AM
Comfortable street-only winter-only dampers dp1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 11-22-2014 11:13 AM
Lowering gear, AND keeping comfortable MarkMash Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 07-17-2012 02:12 PM
