Old 11-13-2014, 09:28 AM   #1
dp1
driving smoother faster
Drives: Sold
Comfortable street-only winter-only dampers
I live in north east (salt and potholes in winter), have Ohlins R&T and love them...but would like to save them for warmer months.
I would like to swap Ohlins with another set of dampers and adjust camber during winter months to minimal negative camber. Have rear SPL LCA. I drive winter "sport" tires on stock rims for about five months (November - March), then swap to summer tires when temps get above 45F.
In colder months, I don't do any track, AX or spirited driving, averaging up to 250 miles per week.
What dampers should I consider for comfortable winter street driving, without reusing any part of the stock dampers, drop no more than about 1" and budget up to about $2k? I drove on stock dampers for about 7 months (July - Feb) and the ride on the street was harsher than I would prefer. Not looking for Cadillac ride, just more comfortable than stock on NY roads.
Considering Bilstein B14 with Raceseng camber plates and adapters.
Please advise, thank you
dp1 is offline   Reply With Quote
Old 11-13-2014, 09:32 AM   #2
jvincent
jvincent's Avatar
Just throwing this out there, but wouldn't the cost of twice a year alignments + new dampers equal the cost of a new set of Ohlins assuming the Ohlins last 3 years?
The Following User Says Thank You to jvincent For This Useful Post:
dp1 (11-13-2014)
Old 11-13-2014, 09:36 AM   #3
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
It would be cheaper to rebuild the ohlins more often. Or buy a set of stocks with Koni yellows in them.
The Following User Says Thank You to Reaper For This Useful Post:
dp1 (11-13-2014)
Old 11-13-2014, 10:49 AM   #4
dp1
Drives: Sold
Thanks, good points - it's hard to estimate how long it will take for Ohlins to deteriorate with winter driving in north east. Given about $1000 cost for swapping between dampers and realigning two times per year, it would add up to the total cost of Ohlins in about 3 years. However, with street/track/AX use only during summer months, Ohlins will be at their peak performance longer and require less frequent ($480 + shipping) rebuilds. If I left them on year-round, I would still want them rebuilt at least once every 2 years, which requires two damper swaps/alignments.
If I swapped them every winter, I would still have them rebuilt every other season.
My objective is not to save money at all cost but to have the most optimal solution in the long term.
Thoughts?
Old 11-13-2014, 10:56 AM   #5
jvincent
jvincent's Avatar
Originally Posted by dp1 View Post
Thoughts?
Time to build a spreadsheet!
dp1 (11-13-2014)
Old 11-13-2014, 10:56 AM   #6
Reaper
Reaper's Avatar
Drives: violent
I lived in new England for 20 years and spent the last 6 in alaska so I understand. I swap my brakes out in the winter too.
I would look at stock struts with Koni yellows in them and a mild spring unless you have clearance issues. But if you did the bilsteins wouldn't fit either.
There is always the option of contacting an ATV suspension company that makes neoprene boots and covering the ohlins. I do this on my dual sport bikes. Then the top hats would be the only possible weak point.
If youve got the cash cusco and trd make coilovers that RAISE the car and you could run a serious winter setup!
dp1 (11-13-2014)
Old 11-13-2014, 10:57 AM   #7
dp1
Drives: Sold
BTW, I do have a set of brand new stock dampers that came off the car when Ohlins were put on, so if just swapping springs to add comfort works, that's an option also. Do Koni Yellows add enough comfort from stock springs and without too much drop? Alternatives?
Old 11-13-2014, 10:59 AM   #8
dp1
Drives: Sold
I also swap my AP Racing Sprint calipers and all rotors and pads to stock for winter.
Old 11-13-2014, 11:00 AM   #9
Reaper
Reaper's Avatar
Drives: violent
Not sure never driven on them with this car but they are adjustable and high quality.
dp1 (11-13-2014)
Old 11-13-2014, 11:00 AM   #10
Reaper
Reaper's Avatar
Drives: violent
What about custom spring rates on stock struts?
dp1 (11-13-2014)
Old 11-13-2014, 11:03 AM   #11
OkieSnuffBox
Drives: '23 BRZ Limited
If you did the suspension swap yourself that would drop your cost below $200.
The Following User Says Thank You to OkieSnuffBox For This Useful Post:
dp1 (11-13-2014)
Old 11-13-2014, 11:15 AM   #12
DAEMANO
Time Traveller
Stock shocks and something like RS*R Down Sus springs (not to be confused with their Superdowns because you want your ride to be nice). RS*R Downs only give about 1/2" drop and a just a bit firmer than stock to compensate for that. You can trim the same amount from your OEM bumpstop (the hard end) for the best ride. $200.
http://www.rs-r.com/product/scion-fr...-springs-2012/
Approximate Drop:
  • Front -10mm to -15mm (-0.4inch to -0.6inch)
  • Rear -10mm to -15mm (-0.4inch to -0.6inch)
Spring Rates:
  • Front 2.82kg/mm
  • Rear 4.49kg/mm
The Following User Says Thank You to DAEMANO For This Useful Post:
dp1 (11-13-2014)
Old 11-13-2014, 11:27 AM   #13
Racecomp Engineering
Bilstein B6 would be an option worth considering.
- Andy
Old 11-13-2014, 11:49 AM   #14
dp1
Drives: Sold
- Andy
Thanks, with which springs for street comfort?
most comfortable shock with Eibach Pro Kit Crashhollywood12 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 01-15-2016 12:01 PM
Which is the most comfortable coilover on brz/frs?? HowL Suspension | Chassis | Brakes -- Sponsored by 949 Racing 79 04-27-2015 08:02 AM
Cusco Street Zero-A & Street Spec A Coilovers - In Stock And Ready To Ship Enjuku Racing Brakes, Suspension, Chassis 0 09-12-2012 05:12 PM
Lowering gear, AND keeping comfortable MarkMash Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 07-17-2012 02:12 PM
