Old 03-06-2015, 11:21 PM   #1
Magiclow
Drives: 2013 Ultramarine Blue FRS
KW V3 Setup
Hey guys
Sorry if this has been asked before, but I did some searching on the forum and Google and I can't seem to find the answer I am looking for.
So I have a set of KW V3 that I am going to install (By a garage) and I want to confirm couple of things. I do track couple times a year, but my car is mostly daily drive.
For those who have the KW V3, if you could shed some light that would be awesome.
1. What is the lowest height setting on the KW V3? From what I read it 2 inches lower than stock, if somebody could confirm this that would be great
2. What is the perfect "ride height" for these coilovers, for I know that if its too low, I will sacrifice ride comfort and performance gain is minimal.
3. If you guys could direct me to some links for some pics of other peoples FRS/BRZ that is lowered on 2 inches on 17's that would be great as well.
Thank You in advance for your help!
Magiclow is offline   Reply With Quote
Old 03-07-2015, 07:02 PM   #2
Andreas83
Andreas83's Avatar
Drives: 2013 Subaru BRZ
When i installed a set of kw v3 on my brz i followed the intructions that came with the kit.
I set it up for max ride hight.
There is a lot of crappy roads were I live...
You will have to measure from bolts in the suspension to the spring base.
See page 4 in the manual.
http://docs.kwsuspension.de/ea-KWGFwEA-h68658004.pdf
I dont know what ride hight that is "perfect", but sticking to these measurements is what kw recomends.
Andreas83 is offline   Reply With Quote
The Following User Says Thank You to Andreas83 For This Useful Post:
Magiclow (03-09-2015)
Old 03-07-2015, 09:49 PM   #3
Magiclow
thank you for your help, I actually for got to mention that I bought these used, so it didn`t come with any manual. LOL
Old 03-07-2015, 10:39 PM   #4
cnk
Drives: '13 DGM BRZ Limited
Not sure if this will help you or not, but when I installed my KW V3's I measured from the hub center to the top of the fender arch. I set the drop for 1" based on that measurement. For settings, Front comp - 7, front reb - 10, rear comp - 8, rear reb - 7. . .these are all # of clicks from full stiff. That should get you started and you can modify from there based on what you want from the suspension.
The Following User Says Thank You to cnk For This Useful Post:
Old 03-15-2015, 03:11 PM   #5
ChaztonS
Drives: '14 World Rally Blue BRZ
I also just got these coilovers (used), but it seems as if that the front compression doesn't stop spinning from max soft/stiff. It is the one that reads "BUMP' right?
Originally Posted by cnk View Post
Not sure if this will help you or not, but when I installed my KW V3's I measured from the hub center to the top of the fender arch. I set the drop for 1" based on that measurement. For settings, Front comp - 7, front reb - 10, rear comp - 8, rear reb - 7. . .these are all # of clicks from full soft. That should get you started and you can modify from there based on what you want from the suspension.
ChaztonS is offline   Reply With Quote
Old 03-15-2015, 03:39 PM   #6
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
@Racecomp Engineering
Old 03-15-2015, 05:06 PM   #7
cnk
It should stop spinning unless something is wrong with them.
Old 03-15-2015, 05:20 PM   #8
ChaztonS
Should it be tightened all the way using the allen wrench? When it was tightened, it was locked in place.
Old 03-15-2015, 08:08 PM   #9
wparsons
wparsons's Avatar
Lowering it 2" without geometry (roll center, etc) correction is going to make it handle worse than stock, plus it'll ride really rough. If you want it really low, KW's aren't the way to go.
FWIW, this is a 1" drop (swift sport springs):
flickr
Magiclow (03-17-2015)
Old 03-16-2015, 12:12 PM   #10
cnk
Sorry. . must have been having a brain fart the other day. Settings should be from full stiff. I corrected my original post as well.
The Following 3 Users Say Thank You to cnk For This Useful Post:
ChaztonS (03-16-2015), Magiclow (03-17-2015), wparsons (03-16-2015)
Old 03-16-2015, 12:57 PM   #11
2016 Camaro SS
2016 Camaro SS's Avatar
Drives: Fast
Lowered mine to 1.4" using Myles suggested settings somewhere on these forums. Works great. I can't go much lower without my 5AD kit scraping everything and losing my front bumper.
2016 Camaro SS is offline   Reply With Quote
The Following User Says Thank You to 2016 Camaro SS For This Useful Post:
Old 03-17-2015, 09:59 PM   #12
Magiclow
Sir if you could be so kind and provide the link to Myles suggested settings that would be so awesome, Thank you or better yet, if you could please confirm if this the link you are referring to?
http://www.ft86club.com/forums/showthread.php?t=19946
Old 03-17-2015, 10:05 PM   #13
Lawnik
Lawnik's Avatar
Drives: Flat grey Toyota 86
That's it, I'm pretty sure. I used it to start from and reset to.
I'm only 20mm lower
Lawnik is offline   Reply With Quote
Old 03-17-2015, 11:27 PM   #14
cnk
Its the same settings I posted up earlier. I bought my KW V3's from RCE and those are the base settings.
FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp PrimeMotoring Engine, Exhaust, Bolt-Ons 8 10-30-2015 06:36 AM
KW V3 Setup texasbound972 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 12-31-2014 11:50 PM
FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp PrimeMotoring NY / NJ / CT / PA 0 10-20-2014 10:48 AM
Best FI setup for my needs? official_george Forced Induction 8 05-07-2013 01:41 PM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
