Old 12-21-2014, 04:13 PM   #1
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
KW V3 Setup
Let's see your setup! Engine is getting Crawford's built block a day after my KW V3 and Vorshlag top hat install. Want to see other peoples setup before I take it to get my alignment done. A big thanks to Randy at Evasive Motorsports for the install and great customer service!!
@Evasive Motorsports
texasbound972 is offline   Reply With Quote
Old 12-22-2014, 06:28 PM   #2
Griever423
Drives: 2020 BRZ PP
Good choice on the vorshlag top hats. With the KWv3 it's a great street setup for sure.
Griever423 is offline   Reply With Quote
Old 12-26-2014, 03:50 AM   #3
flightmaster
flightmaster's Avatar
Drives: Subaru BRZ
Sheesh, how much did the KWs set you back?
flightmaster is offline   Reply With Quote
Old 12-26-2014, 05:27 AM   #4
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Perhaps just pic but front looks really low. I have same setup V plates and all. I noticed going any lower then 1 3/8ths lower then stock ride and feel suffered. Likely due to roll Center. Also in rear I put Voodoo LCA which gave me another 1.5" of stroke which also really helped a lot to keep within optimum operating range. Honestly I may raise them in spring when pull car out again and goto 1.250" lower then stock. While being low looks cool there is a breaking point where ride and connected feeling starts to suffer. Cheers
Old 12-26-2014, 11:34 AM   #5
texasbound972
USMC
Lol enough. Went in to get my plugs changed and pick up a replacement Perrin oil cooler. Walked out spending 3k lol.
Old 12-26-2014, 11:41 AM   #6
texasbound972
USMC
Thanks for the input! Yes it does look too low. I guess I'd have to measure a stock twin from the ground to the rocker to get the actual drop I have. I hope the passenger side can be adjusted with the camber bolt and that's why there is more camber on that side. I don't want more than -2 camber in the rear and in the front. I've never had LCA'S on a car so I'll have to wait and see once it gets aligned and corner balanced if I need some LCA'S.
Old 12-27-2014, 04:16 AM   #7
OICU812
Just a dude
OICU812's Avatar
Zero toe all round and -2 at most all corners imo. If you're just DD with odd track day you'll get away with -1.5 all around camber wise and have less inner wear. If you have no rear LCA and you are 1.5" or lower you're likely near -3 degrees or more, which is well.... a ton, too much really.
What's your wheel size and offset and tires?
Old 12-27-2014, 07:44 AM   #8
OICU812
Just a dude
OICU812's Avatar
Note best measurement point is center of axle to bottom middle of fender @ 90 degrees straight up....., this eliminates the difference is tire and wheel size and gives accurate account of how much you are lowered. Goto a dealer or find friend with (stock) frs measure that front and back then you will know exactly how much you have lowered.
Old 12-27-2014, 01:15 PM   #9
texasbound972
USMC
When I was on my eibach pros I was at -1.4 front and -2 in the rear. Waiting for my short block to be put in by Crawford Performance.
Old 12-27-2014, 01:16 PM   #10
texasbound972
USMC
17x8.25 xxr 535 with a +35 offset
Old 12-27-2014, 01:17 PM   #11
texasbound972
USMC
Yeah I don't want more than -2 of camber. It's daily driven and canyon run on occasion.
Old 12-27-2014, 02:43 PM   #12
whataboutbob
AutoX-10/10ths every run
Stock height measuring as you suggested is 14.5 inches at every corner.
Build thread:Here
Old 12-27-2014, 10:59 PM   #13
OICU812
Just a dude
OICU812's Avatar
Perfect. There you go OP that's your base.
I'm at 13.00" from Center to Center of fender bottom therefore 1.500" lower basically, like I said I'm going to raise up this spring. Check and see what you"re at and then you'll know.
Old 12-27-2014, 11:00 PM   #14
OICU812
Just a dude
OICU812's Avatar
That being said -1.5 would do you fine all around. With your size and offset it would look better to if that counts.
FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp PrimeMotoring Engine, Exhaust, Bolt-Ons 8 10-30-2015 06:36 AM
FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp PrimeMotoring NY / NJ / CT / PA 0 10-20-2014 10:48 AM
Best FI setup for my needs? official_george Forced Induction 8 05-07-2013 01:41 PM
Setup Help Please gbgracer Tracking / Autocross / HPDE / Drifting 7 05-06-2013 06:41 PM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
