Old 03-04-2015, 04:33 PM   #2409
ST-A
Master Tuner
Drives: GT86 + Celica ST205 GT-4 WRC + MR2
i think we adjusted almost everyting now, thanks for all your help everyone!
just one thing left, MAP sensor scaling for metric value.
we have the denso/honda 37830-pgk-a01 sensor
soo i'm sure our scaling was wrong, and we never could measure 1.35bar because this sensor is only able to measure 11.2 pounds of boost or 0.89 bar.
so this is not a 2.5bar map sensor but a 1.9 or something
ST-A is offline   Reply With Quote
The Following User Says Thank You to ST-A For This Useful Post:
steve99 (03-04-2015)
Old 03-04-2015, 04:53 PM   #2410
steve99
Drives: FT86
maybe buy a 2.5 bar omni same as oft guys use and copy their settings ??
Old 03-06-2015, 11:54 AM   #2411
ST-A
Master Tuner
i emailed kraftwerks and they gave me the following values for the denso/honda map sensor
367 and -45
i think those are metric values though, so ho do i convert them to the "bar" values?
Old 03-06-2015, 12:03 PM   #2412
elBarto
elBarto's Avatar
Drives: Toyota GT86
367 and -45
Convert bar to psi
or of you want the defintions from Kodename47 / mine changed from bar to psi just open them with notepad++ and change calculation for the units.
Everything is explained in a post of mine a few posts above this one.
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
Old 03-06-2015, 07:56 PM   #2413
RelentlessGT
Drives: Toyota GT86 Manual
Hi guys,
Regarding the imperial to metric conversion does this mean we can have Degrees Celcius on the realtime diagnostics screen of the OFT? I like to monitor my Oil Temp and mental conversion from F to C is not so easy in realtime.
RelentlessGT is offline   Reply With Quote
Old 03-06-2015, 08:09 PM   #2414
steve99
Drives: FT86
Originally Posted by RelentlessGT View Post
Hi guys,
unfortunatly not.
were just talking about the definition files used to edit rom.
the disply function on oft would require oft guys to chage oft software.
Old 03-07-2015, 07:38 AM   #2415
elBarto
elBarto's Avatar
Drives: Toyota GT86
Would it be possible? If it's in a template file it's an easy fix. It would be the same principle as the definitions. If it's hardcoded in the OFT then it would be a lot more difficult. Still would be nice for the rest of the world.
Old 03-07-2015, 07:56 AM   #2416
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Probably something the OFT guys have to do.
Fairly certain the template doesn't have that kind of data in it.
Old 03-11-2015, 05:54 PM   #2417
Kostamojen
The stage 2 UEL tune... Does it limit the redline to 5000rpms at idle or is something else going on?
Old 03-11-2015, 06:01 PM   #2418
ohnoitsthefuzz
Drives: 2013 Scion FRS 6 Speed Raven Black
That would be the preset launch control feature on the tunes.
ohnoitsthefuzz is offline   Reply With Quote
Old 03-11-2015, 11:06 PM   #2419
Kostamojen
Kind of what I figured...
I'm thinking I need to get rid of it for autox, or at leat raise it to 6000-7000
Old 03-11-2015, 11:47 PM   #2420
s2d4
s2d4's Avatar
You idle for autox run?
Old 03-12-2015, 12:41 AM   #2421
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Considering all the data from the ECU is already metric and OFT converts it into imperial, I'd say it should be easy to to. Putting an option to switch between 2 though is more code.
Old 03-12-2015, 01:20 AM   #2422
Kostamojen
Do you have an availible constructive reply?
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 12:39 PM
