Old 03-06-2015, 04:12 PM   #15
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Originally Posted by rice_classic View Post
I'm 100% positively sure about the Panasonic battery is 390 CCA on the MT FRS. It said it right on the top of it.
I meant about the AT being higher CCA. I know the MT is 390 like you said and wondered what battery the mt had and if it was the same one or different
Old 03-07-2015, 12:50 AM   #16
Mikeez
Engineering Student
Drives: Scion FR-S 2015
I have a battery charger from Stanley 450 AMP.......
How do I use that... If I clip positive to positive and negative to negative.. wait 5 min and start the car... it does the clicking sound.
bat charger is full....
lol
There’s no time to stop for gas, we’re already late
Mikeez is offline   Reply With Quote
Old 03-07-2015, 01:37 AM   #17
TheVoiceOfReason
TheVoiceOfReason's Avatar
Drives: BRZ Limited
lol
What you have is likely a Jump starter that is intended for just starting the car, not charging the battery. If common batteries could be fully charged that fast we could have a lot more electric cars. If it is fully charged (and the switch to ON of course), you should be able to hook it to the terminals and start it up. No waiting 5 minutes. I would check the terminals of the jumper and see what kind of voltage you have. If the voltage looks good, and you are still not cranking, you could have something other than the battery keeping you from starting.
TheVoiceOfReason is offline   Reply With Quote
Old 03-07-2015, 09:07 AM   #18
Mikeez
Engineering Student
Yes exactly. It's a 12V, 450 AMP. It should just help start the car not charge the battery.
I have an extra security installed, I think it might be refusing the car to start. Though, I don't think it's the main reason. Since putting the key in overwrites the security.
So I really don't know. Am I suppose to try starting the car 5 times in a row for a period of 3 seconds?
Old 03-07-2015, 12:56 PM   #19
Hey @Mikeez , is your car in a garage that is above freezing? If not you may have a bigger issue if you have had temperatures like ours the last couple of weeks. A dead battery can freeze. Anybody that has ever tried to boost a frozen battery can support me in the fact that the results can not be pretty. If your car is outside or in an unheated garage you may very well be frozen by now.
stugray (03-08-2015)
Old 03-07-2015, 02:07 PM   #20
Silent_Dan
Drives: 2013 Scion FRS
I have a automatic transmission and the battery is 390 cca Panasonic and had to replace it a week ago.
Silent_Dan is offline   Reply With Quote
Old 03-08-2015, 02:11 PM   #21
Mikeez
Engineering Student
I got to start the car with a 1500 amp power pack
My garage is not heated, but it is always around the freezing point.
How old is the batter?
The Following User Says Thank You to Mikeez For This Useful Post:
Tcoat (03-08-2015)
Old 03-08-2015, 02:59 PM   #22
stugray
Drives: 2013 GBS BRZ Limited
For all of you using these high cranking jump systems to start your car with a dead battery: IF you "quick jump" a dead car then leave the car to charge the battery all by itself, get ready to buy a new alternator.
Alternators are not designed to charge a dead battery.
You might get away with it once or twice, but it is definitely something you are told to NOT do by the alternator manufacturer.
If you have a completely dead battery, you should disconnect it from the car (make sure it is NOT frozen) and trickle charge it at a low amp rate (2amps) for 30 hours before hooking it back up.
60 Amp-hour battery => 2 Amps * 30 hours = 60 Amp-hours
Old 03-08-2015, 06:27 PM   #23
Silent_Dan
I bought the car in June when they first came out so it's a 2013 model
Old 03-08-2015, 09:43 PM   #24
Mikeez
Engineering Student
Why do you want to get it to the 60 Ah? You're saying we should not jump the car with high cranking amps systems?
You've not changed the battery since then? Check battery acid level, =p
Old 03-08-2015, 10:15 PM   #25
Silent_Dan
I don't have the old battery anymore, turned it in for a $12 core refund but it looked good when I checked the level though.
Old 03-08-2015, 10:51 PM   #26
stugray
You dont HAVE to, but since youve gone through all the trouble, why not?
If the battery is just a little too dead too start the car, then a jump is ok.
Even being the source for the jumpstart can stress an alternator if the car being jumped is totally dead.
If the battery is completely dead, (nothing even clicks) then it should be charged by something other than the car.
ANd IF you have a monster alternator that can output a kajillion amps, then it would stress the battery to charge it from completely dead.
Old 03-09-2015, 11:54 PM   #27
Mikeez
Engineering Student
Haha alright my friend, good for you. Good luck with future projects
Alright, I get what you were trying to say. Thanks for the information buddy.
Old 03-12-2015, 11:24 AM   #28
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
My car sat for about three weeks outside before the battery died - as in dead dead, couldn't even unlock the doors from the remote - and there were days where we didn't get above 20*F and nights that were near 0, so I'm not terribly surprised. I swapped in an older Odyssey PC680 last night (not ideal, only 170CCA) as a temporary measure until I pick up a Shorai LFX36L3-BS12 (540cca). This car isn't a daily and will be connected to a maintainer, so the LiFEPO battery should be up to the task.
Parting out HERE
civicdrivr is offline   Reply With Quote
Dead battery technoid BRZ First-Gen (2012+) — General Topics 17 03-17-2016 04:17 PM
Dead battery. AlanKent BRZ First-Gen (2012+) — General Topics 50 03-31-2015 01:36 AM
Dead battery!?! Hoahao Issues | Warranty | Recalls / TSB 5 02-23-2015 04:06 PM
Is there any know that how to open the truck when the battery is dead?????? wilson0326 Scion FR-S / Toyota 86 GT86 General Forum 31 07-06-2013 09:24 PM
Ignorance and a dead battery Red John Issues | Warranty | Recalls / TSB 9 03-02-2013 01:29 PM
