Old 03-04-2015, 10:33 PM   #6105
stockysnail
Just the tip
stockysnail's Avatar
Originally Posted by mokinbird87 View Post
can anyone please confirm for me Gates K061010 belt is the right size for the 70mm pulley? not gonna read 278 pages worth of stuff... I searched but could not find anything concrete. thanks.
I have the 70mm pulley and run the normal size Gates K061015 model but haven't tried the Gates K061010 belt yet, but yes that's the belt to try.
The Following User Says Thank You to stockysnail For This Useful Post:
mokinbird87 (03-05-2015)
Old 03-05-2015, 03:33 AM   #6106
mokinbird87
BOXER FR
mokinbird87's Avatar
Drives: WRB BRZ Limited
thank you guys. my tuner thought it was weird how low the tension was on the belt. will give it a try. now I need to find me a shop to find that vacuum leak...
mokinbird87 is offline   Reply With Quote
Old 03-05-2015, 03:39 AM   #6107
dpgfunk
Drives: 2012 E92 M3, 2013 BRZ
What engine oil are you guys running with the 210 kit? I will be installing my 210 non intercooled shortly and wondering if it would be beneficial to switch engine oil as well.
dpgfunk is offline   Reply With Quote
Old 03-05-2015, 04:51 AM   #6108
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
You should definitely get something slightly heavier than stock oil. I'm using Redline 5w30 myself.
Fizz is offline   Reply With Quote
The Following User Says Thank You to Fizz For This Useful Post:
Chad86 (03-05-2015)
Old 03-05-2015, 07:10 PM   #6109
mokinbird87
BOXER FR
is there an oil cooler option that works well and doesnt sit in front of the radiator? I really like the FBM`s location but I dont trust their mishimoto rebranded cooler vs jackson racing`s setrab one..
Old 03-05-2015, 11:53 PM   #6110
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Lightbulb
Originally Posted by Chad86 View Post
Are the Tanabe gauges too bright at night? I am thinking to go with the Block8head triple vent setup and possibly the Cravenspeed dual pod steering column mount. This way I can have all 5 Tanabe gauges. Is this overkill for monitoring or do I only really need three gauges?
Bump. Anyone running this setup?
Chad86 is offline   Reply With Quote
Old 03-06-2015, 01:40 AM   #6111
stockysnail
Just the tip
You don't really need different oil unless you're taking it to the track and not running an oil cooler. 0w-20 works good. Temps are the same as without the supercharger. If you were running a turbo then yes you'd need 40. I run the Perrin oil cooler and it works well. If I were to do it again I would try the stock forrester oil cooler that comes in the new Forrester as it's the same engine. Lots of people have added it to the BRZ/FR-S and it works great, plus no need for an intercooler as it runs off the coolant system to cool the oil. It also heats up the oil quicker to operating temperature which is good.
The Following 2 Users Say Thank You to stockysnail For This Useful Post:
Chad86 (03-07-2015), Jmonty (03-06-2015)
Old 03-06-2015, 01:41 AM   #6112
stockysnail
Just the tip
See my post above this
Old 03-06-2015, 01:41 AM   #6113
stockysnail
Just the tip
See my post 2 posts above this.
Old 03-06-2015, 11:15 PM   #6114
Ethan
Drives: Subaru BRZ
I bought the AVO oil cooler which sits to the side of the radiator. I have not installed it yet.
Ethan is offline   Reply With Quote
Old 03-07-2015, 10:52 AM   #6115
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
After reading mNy of the pages I couldn't find if anyone is running the Grimmspeed intake with this kit?
Jmonty is offline   Reply With Quote
Old 03-07-2015, 11:37 AM   #6116
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Not possible without custom intake pipe or major modification to the intake.
The Following User Says Thank You to Andrew025 For This Useful Post:
Jmonty (03-07-2015)
Old 03-07-2015, 10:44 PM   #6117
Chad86
Chad86's Avatar
Drives: Toyota GT86
Cool
Beautiful sound of the Innovate Supercharger...
[ame="https://www.youtube.com/watch?v=5RKfSx3fDo4"]Innovate Twin Screw intercooled kit. First test drive - YouTube[/ame]
The Following 5 Users Say Thank You to Chad86 For This Useful Post:
itsibarra (03-11-2015), JonAvalon (03-08-2015), MINOCIN (03-08-2015), mokinbird87 (03-12-2015), sato (03-08-2015)
Old 03-07-2015, 11:49 PM   #6118
R3NIK
R3NIK's Avatar
Drives: 2013 FR-S/C
I just saw the grimmspeed intake in person today next to my car. Not a chance it'll fit
R3NIK is offline   Reply With Quote
The Following 2 Users Say Thank You to R3NIK For This Useful Post:
Dream20b (03-08-2015), Jmonty (03-08-2015)
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
