Old 03-02-2015, 10:28 PM   #29
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Did I love the car before going FI (Innovate stage 2, E85)? Yes.
Do I love the car now? Yes.
Would I want to go back because it takes a bit more attention? No.
What would I change? The lightweight flywheel. I love the quick revs, but the gear rattle and tendency to stall out if I'm not careful gets annoying.
Old 03-03-2015, 12:30 AM   #30
ShaunNeutron
ShaunNeutron's Avatar
Drives: BRZ Limited Manual CBS
Negative ghostrider. No way I could ever go back to stock. I want to go the other way and keep adding performance mods.
ShaunNeutron is offline   Reply With Quote
Old 03-03-2015, 01:23 AM   #31
sw20kosh
Drives: 2013 Black FR-S
Changes your perspective when you realize how little time you spend WOT on track
Not at laguna!!!!!!! Dat WOT life.
Old 03-03-2015, 05:58 AM   #32
erbaker67
erbaker67's Avatar
Drives: 2015 FRS RS1, 93 Supra
Thanks OP. This is a great post. Im jealous of all of you that have gone FI but unfortunately I do not know enough to continuously check the car for issues and more over fixing any if there are. I think based on the feedback here and others, the best thing for me, would be to keep it NA and enjoy it for what it is. Still jealous of you all and love all the information and videos.
erbaker67 is offline   Reply With Quote
Old 03-03-2015, 11:05 AM   #33
mrk1
Drives: Sterling BRZ Ltd
I'm going back NA, may not be permanent but the idea of a UEL header and a 4.56 final drive sound awesome. I really bought the car because it was NA I just got distracted by boost.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 03-03-2015, 05:39 PM   #34
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
I've yet to have heard of a cat failure on any of the Jackson Racing CARB cars...
oh it will happen, eventually
I don't think, it has to anything with different placement of the same supercharger, you guys were able to melt stock cats in a completely stock car so..
glamcem is offline   Reply With Quote
The Following User Says Thank You to glamcem For This Useful Post:
Derka (03-04-2015)
Old 03-03-2015, 05:39 PM   #35
glamcem
glamcem's Avatar
to the OP, read below:
I wanted to share two videos so that you can see the effects of the Supercharger, Coilovers and other mods..Later, I was able to improve my lap time by another second which you can see in my Youtube page..
In the first video you'll see how the stock car lacks the power when compared to a GT3 and in the second video how I can keep up with the same GT3 even after I took off a few seconds behind him(coincidentally same car and driver, in the same group, right in front of me), of course I am not implying a FI BRZ with supporting mods is faster than a GT3 (possibly a driver error) but it's a good way to see the effects of the mods, since same cars and drivers, in a relatively controlled environment
First Video (only mods, wheels and NT01 tires)- Track Time : 2:02.96
[ame="http://youtu.be/lvz-aYHuF44"]http://youtu.be/lvz-aYHuF44[/ame]
Second video (Kraftwerks Supercharger, tune, full exhaust, Coilovers, aggressive alignment ..etc)- Track Time: 1:58.79
[ame="http://youtu.be/Fa1UWvB-Lrg"]http://youtu.be/Fa1UWvB-Lrg[/ame]
The Following 2 Users Say Thank You to glamcem For This Useful Post:
Derka (03-04-2015), sb (03-03-2015)
Old 03-03-2015, 07:24 PM   #36
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
I believe the reason cats fail has more to do with the tune than whether it is boosted or not.
Sleepless is offline   Reply With Quote
Old 03-03-2015, 07:35 PM   #37
DAEMANO
Time Traveller
@Derka
If you really want to ditch the SC, keep in mind that removing your F.I. doesn't mean you have to go back fully to stock. You could go back to N.A. and run a catless header + e85 + tune. That'll get you 200 WHP with no torque dip. The car feels fun and balanced that way too.
The Following User Says Thank You to DAEMANO For This Useful Post:
Derka (03-04-2015)
Old 03-04-2015, 01:41 AM   #38
Derka
Drives: 2015 frs
Thanks for all the awesome responses! At the moment I'm going to stick it out and see where it goes. Lots of different and eye opening perspectives in this post!
Derka is offline   Reply With Quote
Old 03-04-2015, 02:31 AM   #39
glamcem
glamcem's Avatar
I would think the same if I didn't see them failing in stock cars,
for the record I didn't have cat failure in my car but I've noticed a crack on the OEM header which is close to the cats on the header, and figured the very restrictive OEM cats might be the root cause..
I think due to restrictive emission rules/regulations many new engines nowadays some with additional cats ..GM and LS motors for instance, they used to come with 2 cats on the H pipe and now there are additional cats on the exhaust manifold and some guy had cat failure which also caused a catastrophic motor failure.. (Engine sucked in the cat pieces)... additional back pressure and higher EGTs...same can be said for the newer MX-5 engines.. cats on the test pipe (down pipe), however, doesn't cause this since it doesn't sit close enough to the heads..
Axle back exhaust feed back requested Gruppe-s Engine, Exhaust, Transmission 10 12-10-2014 07:56 PM
HAVE YOU PUT SOMEONE IN THE BACK OF THIS CAR? spicyricecake BRZ First-Gen (2012+) — General Topics 72 11-08-2014 01:34 AM
18x8.5 with 235x35 on all 4 corners OR 18x8 front + 18x9.5 back 235/35 + 255/35 back KSpider Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 09-14-2013 07:06 PM
Possible trade? Nameless axle-back for Perrin Resonated Cat-back GTB/ZR-1 Engine, Exhaust, Bolt-Ons 0 03-26-2013 01:51 PM
Drove the 86GT and NC miata back to back on GT5 Hanzo FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 39 01-07-2012 12:56 PM
