Old 02-19-2015, 09:34 AM   #155
BobbyBlue86
BobbyBlue86's Avatar
Drives: Subaru BRZ
Originally Posted by moto-mike View Post
Has a full exhaust and header right now, but it won't go back on the dyno until spring and we have summers on. Header is a skunk2 unit but we may change that out.
Post up some videos! I wanna hear that thing scream... :P
BobbyBlue86 is offline
The Following 2 Users Say Thank You to BobbyBlue86 For This Useful Post:
Freeman (02-19-2015), sato (02-21-2015)
Old 02-19-2015, 09:52 AM   #156
Dream20b
Y u do dis?
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline
Old 02-23-2015, 10:18 PM   #157
blown
Drives: ft86
anyone know if the 72.5 mm pulley is still in the safe range of the blower??
blown is offline
Old 02-24-2015, 02:30 AM   #158
alexisfire02
Drives: 2013 Pearl White FRS
According to the sprintex spec sheets maximum RPM of the blow, and the FRS stock crank pulley, you can go down to a 67mm pulley.
However, I had a ton of heat / IAT issues even using a 75mm pulley.
alexisfire02 is offline
Old 02-24-2015, 06:37 PM   #159
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Rule of thumb on the BRZ is this: Using a max continuous operation of 15000 RPM as specified from sprintex, multiply the pulley diameter by 100 to get your max RPM. So a 72.5mm pulley will hit the max continuous operation limit at approximately 7250 RPM. Although many have exceeded it intermittently without much issue, that tends to be the point where efficiency starts to fall off at a quicker rate. I would probably run a 75 given how large it is unless you're at a really high elevation.
Xero-Limit is offline
Old 02-24-2015, 09:29 PM   #160
sam69
Drives: GT 86
Hey Mike you off your winter tyres yet ??
sam69 is offline
The Following User Says Thank You to sam69 For This Useful Post:
Calum (02-24-2015)
Old 02-24-2015, 09:43 PM   #161
Calum
That Guy
Drives: 2013 asphalt FRS MT
http://www.post-gazette.com/news/edu...s/201502240137
It'll be at least late march before the weather is consistently warm enough for summer tires. I normally don't take my car out of storage until early to mid April, the weather here is normally only a couple degrees colder than where Mike is.
Calum is offline
Old 02-24-2015, 10:14 PM   #162
sam69
Drives: GT 86
Mmmmm looks like global warming is really starting to kick in then .. LoL
sam69 is offline
Old 02-25-2015, 07:08 PM   #163
Xero-Limit
Xero-Limit's Avatar
It was 30f in anchorage Alaska yesterday. It was -8f here. WTF, I'm moving.
The Following 3 Users Say Thank You to Xero-Limit For This Useful Post:
Calum (02-25-2015), Dream20b (02-26-2015), sam69 (02-26-2015)
Old 02-27-2015, 06:40 AM   #164
AJPG
Drives: 22RE, FA20, 4G63
Yesterday
[ATTACH]103430
Last week
[ATTACH]103431
Sir you are more than welcome in my town PR, but be aware that it is summer all year.
AJPG is offline
The Following 2 Users Say Thank You to AJPG For This Useful Post:
Hyper4mance2k (04-23-2015), sato (02-27-2015)
Old 02-27-2015, 11:34 PM   #165
alexisfire02
Seems easier to just take the pulley ratios and multiply by RPM.
Our spec sheet from Sprintex lists 15000 max continuous, and 17000 max instantaneous.
I felt like with my car that is was very safe to say that even under any kind of race/track/strip conditions, that nobody would "continually" hold the revs at over 7000 rpms.
Old 03-05-2015, 01:26 AM   #166
sam69
Drives: GT 86
Mike you started to thaw out over there yet ?? if not you could always move to the land of Oz .
Noticed in one of your earlier posts you said the 335 wouldn't be so flash to run on pump gas all the time but if going to 10:1 pistons would that be better or worse as I've only got access to 98 ultimate where I am .
sam69 is offline
Old 03-05-2015, 01:51 AM   #167
s2d4
s2d4's Avatar
Don't have access to E85?
Do you live in a major city or out in the sticks?
s2d4 is offline
Old 03-05-2015, 03:33 AM   #168
sam69
Drives: GT 86
Yeah country so no e85 but might run a water meth kit if needed but would just like to run on pump if possible for convenience .
sam69 is offline
Chad86 (03-05-2015)
500whp or bust, sprintex, sprintex 335
The new sprintex 335 supercharger jet86 Forced Induction 39 11-01-2014 11:27 AM
Innovate/sprintex SC rudysaliby Scion FR-S / Toyota 86 GT86 General Forum 3 10-28-2014 03:14 PM
Innovate/ Sprintex vs vortech GeeTee86 AFRICA 24 04-04-2014 02:38 PM
Innovate/ Sprintex vs vortech GeeTee86 AFRICA 5 03-05-2014 07:26 AM
TyperRspec789's Full Blown Stage 1 Base Turbo & e85 Progress and Testing TyperRspec789 Forced Induction 63 12-31-2013 07:39 PM
