Old 02-24-2015, 08:26 AM   #2451
kodyo
Drives: Scion FR-S
Originally Posted by NissanGuy View Post
I admit I didn't re-tap the holes or use anti-seize, but I've actually replaced all the gaskets twice (lesson learned: Grimmspeed literally blows), and followed up with a smoke test to verify no leaks. Apparently this fault code (nominally for a stuffed cat) happens to a lot of people with this header.
Most people getting leaks aren't getting the p0420 code alone. It's likely just a mismatch between what the ecu expects to see after the cat and what it is actually seeing.
kodyo is offline
Old 02-24-2015, 11:07 AM   #2452
nunonuna
nunonuna's Avatar
If you have chance, would you mind logging data channel of AFR and wide band AFR from OFT? AFR in OFT is primary O2 sensor reading and wide band AFR channel is rear O2 sensor reading. I just want to compare yours with mine to see if there is difference because mine never throw CEL with full exhaust also.
I will also post mine soon.
nunonuna is offline
Old 02-24-2015, 11:12 AM   #2453
Koa
mate, I've used G/S gaskets, including their phenolics, for years. Soo many other people use their gaskets to great effect. User error or header error, sorry to burst your bubble.
Koa is offline
Old 02-24-2015, 11:46 AM   #2454
2016 Camaro SS
2016 Camaro SS's Avatar
Drives: Fast
Same here, Grimmspeed gaskets are the best ones to use. I also re-use them and they work just fine and seal great. Worth the extra penny. I've got a set on my header and all of my 2.5" gaskets are Grimmspeed's. No leaks.
2016 Camaro SS is offline
Old 02-24-2015, 06:04 PM   #2455
kodyo
Drives: Scion FR-S
Here's a log I took last night with the OFT Stage 1 93 oct tune, P0420 disabled.
Should have 3 100% throttle runs and some good cruising time (was trying to use it to scale my MAF, but gave up since its 50F outside).
http://www.datazap.me/u/kodyo/log-24215?log=0&data=0-1
kodyo is offline
The Following User Says Thank You to kodyo For This Useful Post:
nunonuna (02-24-2015)
Old 02-26-2015, 11:04 AM   #2456
nunonuna
nunonuna's Avatar
Thanks for sharing your log.
I'm not the expert, but it seems like that your rear o2 reading fluctuates very often while regular driving & when it does that, the rear o2 reading goes above of front o2 reading (1251 sec. ~ 1254 sec. mark for example). Front O2 seems fluctuate also. Lines are zigzag-ish.
I checked all of my logs, but I did not find any similar activity like yours. Most of the time rear o2 reading stays below front o2 reading. & both lines are steady.
Also at WOT, mine shows rear O2 value is 1 ~ 1.5 less than front O2 reading value, but your about 0.5 less than front O2.
I'm not pro/expert so I can't tell what is exactly causing it, but it seems not normal for me. I guess even if the cat is not as efficient, at least it should give constant AFR reading of O2 unless it is broken or defective, but yours just goes up and down while cruising driving. If I were you I would not just rely on disabling the code in this case.
My poor guess would be there may be leak, but I would pass this to someone who has way more knowledge about car because my assumption may be totally wrong so experts and pros, come and help~
@steve99 @Shiv@Openflash would you mind take a look at his log & share your thought?? Sorry if I bug you~
nunonuna is offline
The Following User Says Thank You to nunonuna For This Useful Post:
kodyo (02-26-2015)
Old 02-26-2015, 01:51 PM   #2457
kodyo
Drives: Scion FR-S
@nunonuna
Thanks, I'll look into it more this weekend and check for any leaks. Only intake mod I have is drop in and Perrin tube, so it shouldn't be acting that weird if it is. Other mods are 4.56 diff, ft86sf header, motiv over pipe, motiv carted front pipe, and Greddy sp elite axle back (along with OFT stage 1 93 Oct tune). Definitely a conservative setup.
If shiv or anyone else can advise, that would be awesome. I'll be checking for leaks this weekend. I can post another log if needed now that it's warmed up a bit outside. The log I took was also in a lot of stop and go traffic, if that means anything.
kodyo is offline
Old 02-26-2015, 02:42 PM   #2458
nunonuna
nunonuna's Avatar
@nunonuna
Hope you find your answer soon~ cheers
nunonuna is offline
Old 02-26-2015, 10:32 PM   #2459
kodyo
Drives: Scion FR-S
Did some searching, this may or may not have something to do with it (post from 2/18/15):
http://www.ft86club.com/forums/showthread.php?t=82655
I think you guys were looking at the wrong knock type.
I think its more likely its the FLKC knock thats happening arround 5000 rpm and load 0.9 that is the issue you pulling -1 to -2 degrees just before and as the iam drops. The "Knock Correction" or FBKC in that log is very minor prior to the iam drop.
see extract from you log below
http://datazap.me/u/celadrielas/tune...zoom=4704-5199
fix you leak then see what it looks like, likely pull some timing around 5000 loads around 0.9
You could try the cam timing as suggested for the lower rpm lower load knock. or just pull about 0.7 out of the timing map. in that load rpm range.
Don't use "wideband afr" on oft unless you have changed the second o2 sensor to AEM and controller as it not calibrated for stock sensor. Use the front AFR sensor logs as "afr" and compare that to "afr commanded" that the ecu is targeting
I would not take much notice of that Wideband afr value unless he has correct wideband sensor fitted, read my previois post, he needs to log just AFR on oft so it logs front sensor.
kodyo is offline
Old 03-01-2015, 04:49 AM   #2460
NissanGuy
NissanGuy's Avatar
Drives: Strangely.
Does anyone make a good OFT tune for this header? Cause I just checked the price on the FT86 tune, and damn.
My FR-S has a build thread!
(It's mostly full of Nissans)
NissanGuy is offline
Old 03-01-2015, 06:42 AM   #2461
Cartman
Cartman's Avatar
Drives: 10 Series Scion FR-S
Well... an ECUTEK cable, dongle and licnece is 650 without a tune, so technically you're only paying 175 for the tune.
Best thing to do is get a used ECUTEK cable and dongle for cheap on ebay (I got mine for 175) then buy a licnece ($300) and load up OFT tunes, or have a tuner make you a custom tune, as ECUTEK is the main tuning software used.
With OFT you're limited to OFT tunes.
Cartman is offline
Old 03-01-2015, 09:39 AM   #2462
nunonuna
nunonuna's Avatar
Why don't you visit OFT guys & do Dyno tuning since you live close to them?
nunonuna is offline
Old 03-02-2015, 11:11 AM   #2463
GrimmSpeed
GrimmSpeed's Avatar
Drives: '13 BRZ, '12 WRX
Send a message via AIM to GrimmSpeed Send a message via MSN to GrimmSpeed
Hey there! Just wanted to chime in with a response I just wrote to another member that applies here as well!
Originally Posted by GrimmSpeed View Post
Hey man, sorry to hear that you're having trouble with your headers sealing!
With that said, I can absolutely promise you that the issue here isn't with our gaskets. We've sold tens of thousands of these gaskets and the only time when they don't seal well is when the two mating components have flange faces that are either a.) not flat or b.) not parallel. We know this because we also manufacture exhaust components and flange flatness and part 'warpage' are the major challenges.
One of the things that you might try is checking the header flanges for flatness individually and also between the two flanges. A lot of times just bolting them down will flatten any angular discrepancies between the flanges, but sometimes during welding, a header might pull just the right way and make that impossible.
In any case, I'd encourage you to continue using GrimmSpeed gaskets and to avoid double stacking them if possible. They aren't really meant to be a solution to fitment issues and sometimes double stacking will add enough thickness that other issues are created. In our experience, the guys at *** are awesome, so maybe it's just a worth a call to them for some help!
Best of luck and let us know if we can assist in any way.
Matt Beenen
Engineering
GrimmSpeed is offline
Old 03-12-2015, 04:54 PM   #2464
nunonuna
nunonuna's Avatar
Originally Posted by Cartman View Post
I plan on going to the dynojet where I did 186 tunned with the catted header and compare it.
Any update yet??
nunonuna is offline
catted uel header, ft86speedfactory header, is my order ready yet?
Invidia Catless and Catted Front Pipe - ** FT-86 SpeedFactory ** FT-86 SpeedFactory Engine, Exhaust, Transmission 107 03-29-2016 10:48 AM
catted header or catted front pipe? gabeg86 Engine, Exhaust, Transmission 28 10-13-2015 12:32 PM
P&l EL catted and coated header. wootwoot Engine, Exhaust, Bolt-Ons 8 10-11-2013 12:50 AM
Catted UEL Header Cjymiller Engine, Exhaust, Transmission 20 05-24-2013 12:01 PM
***Invidia Catted and Catless Front Pipes*** - FT-86 SpeedFactory RELEASE SALE FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 12 10-24-2012 10:12 PM
