Old 02-24-2015, 01:17 PM   #449
N234
N234's Avatar
Drives:
I didn't see it as rude at all. It was simply a direct statement that it is always better to bring the oil/engine up to normal operating temp as quickly as possible to minimize wear.
And absolutely correct, btw.
Relax.
Agreed. Just because someone takes offense does not mean the speaker was rude.
N234 is offline   Reply With Quote
The Following User Says Thank You to N234 For This Useful Post:
wparsons (02-24-2015)
Old 02-24-2015, 02:04 PM   #450
Originally Posted by tigermack View Post
wtf just happened...
Apparently I was elected without even running.
tigermack (02-24-2015)
Old 02-24-2015, 04:42 PM   #451
nunonuna
nunonuna's Avatar
I understand @yomny when people keep giving irrelevant answers. He was just to try to find out if cusco set up is effective even if it is not as effective as OEM set up, but some people just kept answering "their set up is better" kind of answer which he seems already know.
nunonuna is offline   Reply With Quote
The Following User Says Thank You to nunonuna For This Useful Post:
yomny (02-24-2015)
Old 02-24-2015, 04:52 PM   #452
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Glad someone understands.. In my case due to the placement of my oil return line I can't use the coolant line route of the OEM setup, which ideally I would rather use since it gets the oil up to temp faster but I can only opt for either cusco or air coolers which only really help when the car is moving and since I mostly do city driving, its not ideal.
(thought to self: then again the oil wouldn't get too hot unless I'm running the car hard=cool air coming in)
So the Cusco doesn't have a thermostat in the adapter, it starts to cool when the cars coolant thermostat opens?
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 02-24-2015, 05:18 PM   #453
nunonuna
nunonuna's Avatar
Actually, it cools oil even with car's thermostat closed. Once the engine is warmed up, the coolant temp supposed to be cooler than oil temp. Even there is no flow in this kit until t-stat opens, coolant temp in the core of cooler unit is still cooler than oil temp.
yomny (02-24-2015)
Old 02-24-2015, 05:27 PM   #454
Kostamojen
That is correct.
And sorry if my post upset you. Just trying to make sure everyone understands it doesn't matter where you live, the OEM setup will get oil up to operating temps faster and thats a good thing!
The Following User Says Thank You to Kostamojen For This Useful Post:
yomny (02-24-2015)
Old 03-07-2015, 02:10 PM   #455
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Installed/How-To: 2014 Forester XT OEM Oil Cooler(pics!)
Sorry if this is a repost I didn't go through all 23 pages on this thread to find it but do you think this alternative shown at this DIY thread is basically the same performance?. This seems to be much much simpler. The only thing that seems a little weird is the use of 1/2" hoses to go onto 3/8" barb of the throttle body. http://www.ft86club.com/forums/showthread.php?t=73684
Edit: Sorry nevermind I found out it is essentially the same.
mit_peid is offline   Reply With Quote
Old 04-18-2015, 03:17 AM   #456
FLYFISHR
FLYFISHR's Avatar
Drives: 2014 BR"ZED" Sport-tech DGM MT
Is this right??
Is the little nub on the bottom of the oil cooler suppose to be there or does have to be removed? I didn't see it on the oil cooler in any of the pictures here.
Thanks
Old enough to know better but young enough to do it again
FLYFISHR is offline   Reply With Quote
Old 04-18-2015, 03:20 AM   #457
FLYFISHR
FLYFISHR's Avatar
Oil cooler nub
Second view
Old 04-18-2015, 08:09 AM   #458
CARNZ
CHECK ENGINE
Drives: 2004 STi
That nub is supposed to be there, it aligns the oil cooler on the chain cover
i don't cry about crickets
CARNZ is offline   Reply With Quote
The Following User Says Thank You to CARNZ For This Useful Post:
FLYFISHR (04-18-2015)
Old 04-27-2015, 07:24 PM   #459
ducky106
Drives: Scion FRS
Does anyone have more before and after data on stock HP on a track? I'm thinking of going this route for oil cooling just not 100% convinced it will be enough
ducky106 is offline   Reply With Quote
The Following User Says Thank You to ducky106 For This Useful Post:
CxG (04-25-2016)
Old 04-27-2015, 07:37 PM   #460
jvincent
jvincent's Avatar
Hitting the track on Friday. First time out with the oil cooler so I'll have some data then.
The Following 3 Users Say Thank You to jvincent For This Useful Post:
Chrisbrz14 (04-28-2015), ducky106 (04-28-2015), FLYFISHR (04-28-2015)
Old 04-27-2015, 09:15 PM   #461
sickmint79
Drives: bmw
quite interested too.
i will likely have data post 5/15 myself.
PointMeBy - auto enthusiast / 86 / car blog - https://www.pointmeby.com
IGoByPlane - travel/credit/auto experience blog - https://www.igobyplane.com
sickmint79 is offline   Reply With Quote
Old 05-01-2015, 10:08 PM   #462
jvincent
jvincent's Avatar
OK, just got the data from the track.
Max oil temp was 124C, or 255F. That was for one sample. The rest of the time it was 122C or lower.
Coolant was pretty steady at 93C to 94C all around.
brz, fxt, oil, oil cooler
OEM Oil cooler from the 2.0 DIT Forester Kostamojen Engine, Exhaust, Transmission 119 09-10-2019 05:28 AM
Bought a 2014 Subaru Forester EAGLE5 Other Vehicles & General Automotive Discussions 10 10-02-2013 12:54 PM
2014 Forester key fob - nicer than BRZ Turbowned Cosmetic Modification (Interior/Exterior/Lighting) 3 04-17-2013 03:35 PM
BRZ 2.0L Turbo in 2014 Forester Sleeperz BRZ First-Gen (2012+) — General Topics 37 03-21-2013 06:42 PM
Review after test driving a 2013 WRB BRZ and 2014 Forester in Okinawa, Japan… 2013GTRNate BRZ First-Gen (2012+) — General Topics 12 02-01-2013 12:29 PM
