#1625 | |
Drives: FT86
I was considering ecutek for map switching until i found out a map switching issue that killed it for me It does not remember the last map you were on when you turn car off. So each time you startup you have to remember to switch to correct map as it defaults to map 1. So if you had an 91/93/E40/E85 map switch tune and were running say E85 you have to switch it to map 4 each startup. Yes ok if your the only one who ever drives car but wife/girlfriend/mate is never going to remember or know, or if you took it for service or repair somewhere. apparently their is some weird startup proceedure you can do to make it go to last map but they are not going to remember to do that either on every startup. |
#1626 | |
Drives: '22 BRZ
Also, about the throttle issue... I've followed your procedure for that and it's a tiny bit better, but the first 1/4" of pedal travel is still dead for about two weeks.
#1627 |
Drives: Silver Premium Edition BRZ
I'm so tempted to start running E85 now that I have a second vehicle but there aren't many stations I my area that offer it.
#1628 |
Drives: White '17 86
#1629 |
Already did that... There's one kind of near my office but nothing near my house.
#1630 |
Drives: Scion F-RS 2013 Asphalt MT
I ran my second tank of e85 on my car recently, I noticed that my the mpg readings were around 30mpg running uel stage 2 tune for e85 but when I switched back to running 91(stage2 uel tune), my mpg went down to 17mpg. Shouldn't the readings be backwards?
#1631 |
Drives: Neptune GR86
Are you taking the numbers from the dash?
#1632 |
#1633 |
Drives: '22 BRZ
The dash numbers are known to be about 30% off when using E85 due to the way it calculates fuel economy and the way the mapping is changed to handle E85.
#1634 |
Drives: '13 SSM BRZ Limited 6MT
I got 216 miles out of my first tank of E85 and filled up with another 10 gallons, so averaging 21.6 miles so far with 70% hwy/30% city driving. Got about 25-26 mpg with regular 91 gas before.
#1635 |
Drives: 2014 Scion FR-S
I'm getting an average of 19 on E85. Was getting low twenties on 93. Mostly city
#1636 |
Drives: '23 BRZ Limited
Is there a JRSC tune available yet?
#1637 |
Drives: '13 BRZ
#1638 |
Drives: Toyota GT86
ST-Autosport (Belgium) has almost finished his JRSC OFT tune. Just some tweaking left.
And also, Shiv can only make such kind of tunes when he has a car with those mods on his dyno. If somebody supply the car with the JRSC then you (and the rest of the world) will have a tune for it.
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners |
| Tags |
| #lolwut, divinecomedy, dopeandcashcabinet, free shiv now, goddamitimissedit, golden cage, i missed the show, looks good, missed the fun, omgbbq, shiv 2016, thefatandthefurriest |
| Tablet on the dash ! | TRD_86 | Electronics | Audio | NAV | Infotainment | 23 | 05-16-2015 03:48 AM |
| Tablet Install | ThugNasty | Electronics | Audio | NAV | Infotainment | 4 | 04-13-2013 03:15 PM |
| Blutooth OBD II and a 9.7 tablet.. | Scooby South | Electronics | Audio | NAV | Infotainment | 10 | 12-16-2012 08:11 PM |
| 7.0 Tablet w/ Torque App | Thatruth2001 | Northwest | 26 | 11-21-2012 11:53 AM |
