Old 02-21-2015, 05:18 PM   #1625
steve99
Drives: FT86
Originally Posted by DocWalt View Post
Damn. To be honest I'd be perfectly happy with fast map switching like Ecutek. I HATE losing the throttle calibration and that's holding me back from trying E85 now that I have all of my exhaust bits on.
Yes with map switching you wont get that throttle lag, but if you follow correct steps after a flash you can minimize it. I very rarely get it any more.
I was considering ecutek for map switching until i found out a map switching issue that killed it for me
It does not remember the last map you were on when you turn car off. So each time you startup you have to remember to switch to correct map as it defaults to map 1.
So if you had an 91/93/E40/E85 map switch tune and were running say E85 you have to switch it to map 4 each startup. Yes ok if your the only one who ever drives car but wife/girlfriend/mate is never going to remember or know, or if you took it for service or repair somewhere.
apparently their is some weird startup proceedure you can do to make it go to last map but they are not going to remember to do that either on every startup.
Old 02-21-2015, 05:24 PM   #1626
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Interesting. Good to know of that limitation. I wouldn't like that much because I'd forget to swap to the right map if I shut the car off between runs at autocross or whatever.
Also, about the throttle issue... I've followed your procedure for that and it's a tiny bit better, but the first 1/4" of pedal travel is still dead for about two weeks.
DocWalt is online now   Reply With Quote
Old 02-21-2015, 11:20 PM   #1627
Wankel Rex
Wankel Rex's Avatar
Drives: Silver Premium Edition BRZ
I'm so tempted to start running E85 now that I have a second vehicle but there aren't many stations I my area that offer it.
Wankel Rex is offline   Reply With Quote
Old 02-22-2015, 12:44 AM   #1628
spyingwind
Drives: White '17 86
Just google "e85" and some of them should pop-up. Here in Dallas you normally only find them outside the city.
spyingwind is offline   Reply With Quote
Old 02-22-2015, 07:12 PM   #1629
Wankel Rex
Wankel Rex's Avatar
Already did that... There's one kind of near my office but nothing near my house.
Old 02-22-2015, 08:39 PM   #1630
winsometang
Drives: Scion F-RS 2013 Asphalt MT
I ran my second tank of e85 on my car recently, I noticed that my the mpg readings were around 30mpg running uel stage 2 tune for e85 but when I switched back to running 91(stage2 uel tune), my mpg went down to 17mpg. Shouldn't the readings be backwards?
winsometang is offline   Reply With Quote
Old 02-22-2015, 08:54 PM   #1631
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Are you taking the numbers from the dash?
Old 02-22-2015, 09:04 PM   #1632
winsometang
Yeah I'm taking the numbers off the dash, I reseted the average before each tank. Same mods both times
Old 02-22-2015, 10:18 PM   #1633
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
The dash numbers are known to be about 30% off when using E85 due to the way it calculates fuel economy and the way the mapping is changed to handle E85.
Old 02-23-2015, 12:09 AM   #1634
tracerit
Drives: '13 SSM BRZ Limited 6MT
I got 216 miles out of my first tank of E85 and filled up with another 10 gallons, so averaging 21.6 miles so far with 70% hwy/30% city driving. Got about 25-26 mpg with regular 91 gas before.
tracerit is offline   Reply With Quote
Old 02-25-2015, 01:24 PM   #1635
DC2R
Drives: 2014 Scion FR-S
I'm getting an average of 19 on E85. Was getting low twenties on 93. Mostly city
DC2R is offline   Reply With Quote
Old 02-26-2015, 11:37 AM   #1636
OkieSnuffBox
Drives: '23 BRZ Limited
Is there a JRSC tune available yet?
Old 03-05-2015, 06:49 PM   #1637
uRBAN_Metal
Drives: '13 BRZ
There isn't, and I wouldn't hold your breath for one. For this reason I'm ditching OFT and going with EcuTek.
uRBAN_Metal is offline   Reply With Quote
Old 03-05-2015, 07:07 PM   #1638
elBarto
elBarto's Avatar
Drives: Toyota GT86
ST-Autosport (Belgium) has almost finished his JRSC OFT tune. Just some tweaking left.
And also, Shiv can only make such kind of tunes when he has a car with those mods on his dyno. If somebody supply the car with the JRSC then you (and the rest of the world) will have a tune for it.
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
#lolwut, divinecomedy, dopeandcashcabinet, free shiv now, goddamitimissedit, golden cage, i missed the show, looks good, missed the fun, omgbbq, shiv 2016, thefatandthefurriest
Tablet on the dash ! TRD_86 Electronics | Audio | NAV | Infotainment 23 05-16-2015 03:48 AM
Tablet Install ThugNasty Electronics | Audio | NAV | Infotainment 4 04-13-2013 03:15 PM
Blutooth OBD II and a 9.7 tablet.. Scooby South Electronics | Audio | NAV | Infotainment 10 12-16-2012 08:11 PM
7.0 Tablet w/ Torque App Thatruth2001 Northwest 26 11-21-2012 11:53 AM
