go_a_way1
Old 02-15-2015, 05:12 PM   #2689
VroomVroom86
VroomVroom86's Avatar
Drives: 2013 Firestorm FRS MT
18 x 9.5 +45 with 265/35/18. Will this work? I'm on coilovers and dropped about 1.5 inches
VroomVroom86 is offline   Reply With Quote
Old 02-15-2015, 11:45 PM   #2690
Nhan55nguyen
Drives: SUBARU BRZ 2013 WRB LIMITED
Will this fit ?
19x9 +38 245/35/19
19x10 +38 265/35/19
on 1 inch drop
Nhan55nguyen is offline   Reply With Quote
Old 02-16-2015, 01:02 AM   #2691
Nhan55nguyen
I think the front will be a problem. might need to roll the front fenders.
Old 02-18-2015, 10:17 AM   #2692
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
Is there anyone running 17x9 +10? My 20mm adapters are being a pain, the acorn nuts dont sit flush with my adapters thus hitting my wheel (my wheels dont have pockets on the back of them) so I was thinking of ordering 25mm.
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 02-18-2015, 10:30 AM   #2693
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
I'm guessing you weren't able to fit your current wheels to see if they fit?
Either way 17x9 +15 or +10 is a ton of poke.
Not sure what your setup is, but you would need pretty severe camber to tuck those wheels in.
Slick is offline   Reply With Quote
Old 02-18-2015, 10:42 AM   #2694
WolfsFang
Scrape Master
WolfsFang's Avatar
Sadly no i wasent, my studs also hit my wheel's so I couldn't get a good idea on how much poke i would be getting with my 20mm
I use to run 16x9.5 +16 with around -2.ish camber, so if i have to run -3 or -3.5 that wont bother me at all.
Old 02-18-2015, 10:45 AM   #2695
Slick
Slick's Avatar
I use to run 16x9.5 +16 with around -2.5 camber, so if i have to run -3 or -3.5 that wont bother me at all.
Sounds like you know what you're up against already, so I don't think another 5mm will cause an issue.
Normally, I would refer these questions to the "Aggressive wheels" thread, but I know you're there already.
Old 02-18-2015, 10:54 AM   #2696
WolfsFang
Scrape Master
WolfsFang's Avatar
Well my fear was since im going to 17's I would have to run alot more camber, like -4 or even more, -3.5 is really the max I would like to run since im also on stock toe arms with just PBM LCA.
Old 02-20-2015, 01:16 PM   #2697
Jesse36m3
Jesse36m3's Avatar
Drives: JDL Turbo BRZ
Stock brz. I have hotchkis sport springs. 1" drop.
Looking for some wheels that I won't have to do a ton of work to make fit.
Are 18x9.5 too wide in the front? I noticed on other cars there is a bit of poke. I don't like that. I love how it sits in the rear, however. Can I get away with using camber bolts in the front to remedy this?
Recommended offset and tire size if that is an acceptable wheel width? I see +38 is a common offset. Will I have any problems running a 245/35/18?
Again, this is with a 1" drop.
Jesse36m3 is offline   Reply With Quote
Old 02-20-2015, 03:57 PM   #2698
Slick
Slick's Avatar
Max you will likely be able to fit up front without coilovers is 18x9, ideal offset is around +35.
There's more room out back, so you could run a wider rear wheel or stay square. Even with a 9" wheel up front, you can easily run a 245 or even a 255 if you have the right wheel offset.
Old 02-20-2015, 04:17 PM   #2699
Amir Ghadiri
Amir Ghadiri's Avatar
Speaking based on personal experience, 18x9.5 +38 with camber bolts will be no problem on the front with up to 265 tires.
Amir Ghadiri is offline   Reply With Quote
Old 02-20-2015, 04:21 PM   #2700
Amir Ghadiri
The rear will be perfect but you will rub on the INSIDE of the front at full lock.
You won't need any fender mods to fit this.
Old 03-01-2015, 12:38 PM   #2701
HGaudio
Drives: 13' Scion FRS
Will enkei rpf1's 18x9.5's fit if my car is on eibach sport line springs? I can't find rpf1's in 18x8.5 for the front
HGaudio is offline   Reply With Quote
Old 03-04-2015, 12:05 PM   #2702
Killerbee
Killerbee's Avatar
Drives: GR86 / Supra MK5 MT / MR-S / Z4
Depends on the offset, and the tires you want to run. However they will most probably stick out of the fenders, but if the offset is not to low they should fit (but again, they will stick out). If you post the offset and tires you want to run I can help you more.
Killerbee is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
