#211 |
Junior
Drives: a car
no, no one has mentioned the spring characteristics or damping forces of the materials together.
#212 |
Drives: 2013 black AT, OFT, 4.65
Hi, has anybody pointed out going to aluminum driveshaft you lose a u-joint? I'm not a rocket scientist or physicist but I have built off road trucks and loathe u- joints. living with one less u- joint in my drive train is enough for me to go to a solid aluminum driveshaft..
Living the dream in a nightmare.
| The Following User Says Thank You to skye67 For This Useful Post: | CSG Mike (02-19-2015) |
#213 | ||
| The Following User Says Thank You to CSG Mike For This Useful Post: | Strife26 (04-17-2017) |
#214 | |
#215 |
Dismember
Drives: 2013 Red Scion FR-S
I think we really need to think about the use of various drive shafts as weapons. The aluminum is clearly superior to the two-piece stock design. It's hard to swing such a heavy hunk of metal when part of it is flopping around. Not only is the aluminum lighter, it's one-piece design avoids the whole flopping thing. However, the AL shaft is also 3" in diameter. That's pretty hard to wield. I speak from experience. The carbon fiber shafts are a bit thinner, at 2.75" in diameter, one-piece, and lighter than stock, making them the superior bludgeon.
#216 | |
#217 | ||
Drives: 2013 GBS BRZ Limited
![]() Referring to this? Quote:
#218 | |
Dismember
https://i.imgur.com/lbbm2.jpg
| The Following 3 Users Say Thank You to EAGLE5 For This Useful Post: |
#219 | |
You can fight me but you can't fight physics!
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Decimus (07-17-2018) |
#220 | |
Drives: 2015 Series.Blue
Hate to be "that guy" but it's an entirely different issue on offroad trucks. - Crazy amounts of torque by using low range transfer cases. - Bad angles that the U-joints aren't designed for. - If bad angles are used, they use a double U-joint as a CV joint to get around the angle so the u-joints don't fail. None of those issues effect this chassis as it's not a live axle and the two piece shaft is more likely to counter critical speed issues... |
| The Following User Says Thank You to Poodles For This Useful Post: | Ultramaroon (02-19-2015) |
#221 |
Drives: 2013 ultramarine Scion FR-S
Just guessing here: driveshaft whip is what we're trying to avoid. It's basically the driveshaft acting like a jump rope. With aluminum this can cause work hardening. This can make it weaker to other stresses, such as torsion. If your driveshaft twisted in the middle I bet it was likely work hardened from spinning too fast.
I'd expect if a healthy driveshaft were going to fail in torsion it would be at one end or the other rather than in the middle. The leverage of the length of it causing some bending to add to the torsional shear. I'm guessing here. |
#222 | |
It's the Mad Cow
Really need to find a solution for this as it sucks.
05 GTO 408 Stroker \ 13 FRS 210 Twin Screw Supercharger on E85 \ 14 F-150 5.0L |
#223 |
Drives: 2013 Ultramarine FR-S
Remove the Mod you like less, or buy a Carbon Driveshaft unfortunately.
![]() I am still upset over it myself.
#224 |
I thought of another reason why a LWDS should make no difference in HP measurements while discussing this on anoher thread.
Here's another reason: While measuring the "Brake Horsepower", the oldest method in existence is to run the engine (or CAR in the case of a chassis dyno) at a constant RPM while applying the "Brake" and finding the point at which the engine can just hold RPM at max output. The hp rating was determined at this constant RPM by how much power is consumed in the "brake" (hence the term "brake-horsepower") How much hp is a lightweight driveshaft stealing from the system while it is rotating at constant RPM? the exact same amount as a heavy driveshaft rotating at constant RPM - ZERO. Same concept applies to any rotating mass - IF you can measure HP at a constant RPM (which you CAN), then the mass of the rotating assembly does not matter in the HP measurement. Will a driveshaft that weighs 10 pounds lighter than your competitor help you beat him to the end of a quarter mile? - SURE. The same as removing the 10 pounds from anywhere on the car. |
| The Following User Says Thank You to stugray For This Useful Post: | CSG Mike (05-19-2015) |
| Lightweight aluminum drive shaft installed. | stockysnail | Northwest | 18 | 02-05-2020 12:18 AM |
| Driveshaft Shop Aluminum Drive Shaft. | FT-86 SpeedFactory | Engine, Exhaust, Transmission | 40 | 10-15-2015 10:11 PM |
| Invidia N1 interference with Driveshaft Shop aluminum shaft. | xkalelx | Engine, Exhaust, Transmission | 6 | 03-03-2015 10:43 AM |
| Scion FR-S / Subaru BRZ Drive Shaft Shop Carbon Fiber Drive Shafts In Stock | Anthony@RWHP | Transmission and Driveline | 4 | 12-25-2013 09:09 PM |
