| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: CWP series blue brz
Need Oil change recommendation
Hello! my 3K service is coming up in a couple hundred miles and i was wondering what people could recommend me as far as the oil change! Leaning towards the Motul Gear 300 but i dont know if i need to buy anything extra or i can just get the oil and take it to the dealer to have them change it.
#2 |
there is no 3k service. 6k for 2015's, 7,500 for years before.
Many people do the trans/diff early and find lots of debris on the magnetic drain plugs. I plan to do mine at 6k for my 2015. I am going to use motul also. Read your manual. |
#3 |
Drives: 2014 Argento FR-S
Read this.
Also, although Motul is reportedly great oil, Toyota OEM oil is very hard to beat (read the endless threads on this forum). |
#4 |
First Motul 300 usually refers to Gear and Diffy fluid.
There are a few items: Motul Gear 300 75w90- good to put in around 3-5K miles in the Trans and Diffy Motul 8100 0w20- good engine oil and would suggest changing at 3K miles and then every 5K miles after that. Motul 300v- racing oil that I wouldn't suggest being used in a street car unless you track it and if you do track it and street drive it then change it every 2k-3k miles due to a lower detergent/additive package. -mike |
#5 |
Turning is for Nerds
Drives: 35 characters is not enough
For a street driven car, standard Toyota or Subaru engine oil every 6-7.5K per owners manual.
Driveline oils should only really be done to sort out shifting issues, why fix what isn't broken. For a street car a 20K mile trans/diff oil change interval would be a nice aggressive preventative maintenance schedule. For a track car, do whatever makes you feel comfortable and change fluids often. |
#6 |
#7 |
#8 |
Drives: Sema 2013 Frs Project car
i use MOBIL 1 and ITS GREAT!
#9 | |
Drives: 2004 Subaru Forester 2.5XT
![]() There's also a voa in that thread. |
#10 |
Drives: 2013 FRS Whiteout
Wouldn't be surprise as there's a member here that ran the oem subaru 0w-20 for 10k+ and blackstones oil analysis report came back great.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
#11 | |
Mike |
#12 | |
Similar to the CYA move by Amsoil advising to stick with SoA's oil change interval recommendation on all turbocharged Subaru's after a knucklehead Legacy GT owner ran a 25k mile OCI as advised by his knucklehead Amsoil dealer.
#13 | |
Mike |
#14 | |
Drives: '23 BRZ Limited
So 8100 for a street car that sees the occasional track weekend or auto-x would be just fine? (This is assuming the use of an oil cooler.) |
| Recommendation for GTA PDR? | 1Cor10:23 | CANADA | 12 | 11-08-2014 09:08 PM |
| Oil Change Interval Change (Subaru recommended) | Flow | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 34 | 09-10-2014 07:27 PM |
| Recommendation on coilovers please | Shad0ez | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 10-27-2013 01:17 AM |
| Non LED recommendation for DRL | boredom.is.me | Cosmetic Modification (Interior/Exterior/Lighting) | 13 | 05-11-2013 05:34 PM |
| PDX Recommendation for Detailing | JayNutter | Northwest | 2 | 12-08-2012 10:26 PM |
