| Software Tuning Discuss all software tuning topics. |
#15 |
Drives: 2013 FRS
Awesome! Remember that you'll need the raw RPM and Torque Data from the Dynojet run file (.drf). I can send you a sample data file if you need it.
#16 | |
The torque curves for a lot of larger displacement engines (and especially turbo engines) peak earlier in the midrange and drop off, leading to more area under the curve. I think this is an issue for some of the Twins competing in power/weight-classed time attack series. Not enough area under the curve compared with larger displacement engines.
2022 BRZ Build 2013 FR-S Build |
| The Following User Says Thank You to DarkSunrise For This Useful Post: | xxBrun0xx (03-02-2015) |
#17 |
PhoneFlash by EcuTeK
For what it's worth, the "pseudo numbers" we're pulling out of our rears are to a specific Dynojet up in LA that we've taken the time to do comparison baseline pulls on in the same day to our Mustang.
We used the same car, on the same day, in relative same weather, with all the same mods and tune file to get an accurate conversion factor. We only do this because no one seems to be happy with numbers the way a Mustang dyno will spit them out as per standard. As far as an above post which stated something along the lines of " Now compare that to a car that makes 190hp over the entire rpm range. Which would you like to drive?"; Horsepower is a unit of torque over time, and as such, for that kind of HP curve your torque would have to peak almost immediately in the low end, and nose dive the rest of the way to redline. It would feel and drive awful, with no pull. The only real reason to tune for that kind of power delivery is if you were in something like a NASA Time Trials race, where you're power limited by the rules and want the maximum amount of torque you can have without breaking the horsepower limits. Shiv is correct in the statement that any standard tuning solution (EcuTek, OFT, BRZEdit, etc) given the same values may produce the same numbers. There are certain above and beyond features that some solutions may have over another, and perhaps yet another solution may have its own perks elsewhere in ease of use, or what have you. In the end the tuning solution you choose is about what's right for you. As far as the tuner goes, the basics are all going to be about the same, and then every tune has their own special way of mixing it up a bit to suit their style. Hope this helps. Sincerely, Zach Delicious Tuning |
#18 | |
Drives: 2015 WRX
#19 | |
http://www.delicioustuning.com/Stage_2_PumpGas Complete with area under the curve gains, peak gains, drag curves, corrected power curves, ambient temps, intake temps, humidity, oil temps, even rotating mass. We aren't hiding anything from the consumer. It's all available right here for everyone to see. Sincerely, Zach Delicious Tuning |
#20 | |
Drives: 1FRS, 1 BRZ, 2S2000s, Evo8, Dak.R/T
#21 | |
Drives: '13 Ultramarine FR-S M/T
Mod List:
FT86SF Catted header / Nameless combo pipe with cat and res/ FT86SF V1 CBE / GrimmSpeed Intake / OFT STG 1 GS Tune / Fortune Auto 500's |
| The Following User Says Thank You to Sypher For This Useful Post: | killboy (02-18-2015) |
#22 | |
#23 | |
Drives: 4 wheels
| The Following User Says Thank You to justint5387 For This Useful Post: | killboy (02-18-2015) |
#24 | |
Drives: MR Spyder/GT86
GT86
Current Mods: Ace Header with 350 OP-Berk Frontpipe-Miltek Resonated Catback-OFT-k&n drop in filter |
| The Following User Says Thank You to GT86meMR2 For This Useful Post: | killboy (02-18-2015) |
#25 |
Drives: 2013 ultramarine Scion FR-S
The "area under the curve" of a power and RPM plot is energy delivered.
If you're looking at two plots and compare the area between the two plots then you have a difference in energy delivered, which is what most people comparing two plots are thinking in their head, anyway. If you take the total energy delivered and divide it by the total RPM it's delivered over you have an average of the power produced. This is a useful number. |
#26 |
Let's not forget that the S2K also has significantly more aggressive gearing.
![]() Sincerely, Zach Delicious Tuning |
#28 | |
Drives: 14 Ultramarine FR-S
2014 Ultramarine Scion FR-S 2000 Integra LS - SOLD ![]() |
| Have you hit 200whp NA? | empower-auto | Engine, Exhaust, Transmission | 323 | 11-26-2015 07:49 PM |
| Best combo since my Ecutek flash and headers. | BC-Boy | Engine, Exhaust, Transmission | 3 | 05-15-2014 08:49 PM |
| Delicious Tuning - 200+ whp E85, Stock Headers, EcuTeK ProECU | DeliciousTuning | Software Tuning | 19 | 12-07-2013 12:01 PM |
| 200whp for ~$1000 | Shiv@Openflash | Software Tuning | 127 | 11-27-2013 07:26 PM |
| Dyno take 2, 200whp on 92Octane ?! | AJ PwR | Engine, Exhaust, Transmission | 76 | 07-31-2013 02:14 AM |
