Old 02-17-2015, 03:58 AM   #1
momo3605
Drives: 2014 Fr-S Monogram
Is 200whp achievable on OFT with headers and 91 like ecutek?
Some threads claim that they can get 200whp on an ecutek tune with just headers. I haven't seen any numbers like that for an OFT. Are the ecutek tunes superior to the OFT tunes or are they essentially the same?
momo3605 is offline   Reply With Quote
Old 02-17-2015, 04:33 AM   #2
steve99
I'm pretty sure that car had a full complete exhaust not just header.
"Well, we've done it again. This time around we've hit 200whp with 91 Octane on a Naturally Aspirated BRZ with a stock engine. Mods included were a JDL UEL Header, JDL Over Pipe, and JDL Front Pipe. There may or may not have been a drop in filter or intake on this particular brz, I'm not entirely sure. "
http://www.ft86club.com/forums/showthread.php?t=64770
Your also comparing an OFT tune which is a canned or off the shelf one size fits all tune with an Ecutek custom dyno tune.
let the oft guys (or any other competent tuner ) do a custom tune on car with same mods and they would produce similar results.
What hp did a stock car post on that dyno ? you realy need to look at percentage or hp increase not the end numbers as all dynos read different unless your comparing same dyno or at least same dyno type with same calibration.
No reason it could not be done your changing the same tables in the ecu with ecutek OFT/Romraider Ecuflash Brz-edit ect.
Old 02-17-2015, 07:04 AM   #3
Malt
Drives: 2015 WRX
If you are referring to that post by delicious tuning that steve linked, I see a dyno chart of a 86 making 174 whp and then they apply pseudomath to arrive at that "200" number by attempting to relate mustange dyno numbers to dynojet numbers.
Not knocking Delicious Tuning as I think they do amazing stuff but the important thing to remember here is that dyno numbers can vary wildly from car to car and dyno to dyno depending on many variables such as weather conditions and how the dyno was setup.
Furthermore, I don't understand the fascination with peak HP numbers. As an example take a mythical car that makes 200HP at 7000rpm as its peak number but makes like 100hp almost everywhere else in the rpm range. Now compare that to a car that makes 190hp over the entire rpm range. Which would you like to drive?
People need to stop and really look at dyno charts and see whats going on instead of blindly focusing on a single data point or you run the risk of missing out on extremely interesting possibilities like the ESC setup.
Malt is offline   Reply With Quote
Old 02-17-2015, 10:20 AM   #4
phrosty
A more useful (but humbling) number would be "80% of the time, HP is over X". Perhaps further separating into street and race RPM ranges. But then tuners wouldn't look as good for that one tiny spot their intake got a 5whp improvement, so this'll never happen.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 02-17-2015, 11:58 AM   #5
Toyota John
Calle Atun
Drives: 13 FRS, 93 Mr2, 85 ae86
Your goal should be gained whp over stock. Most full bolt on frs/brz make about 25ish whp over stock on good 93 pump. Some really good tuners with an aggressive tune for ideal conditions might get close to 30 whp over stock. Forget about getting some dyno number. My mr2 made 311 whp on one dyno and 360 whp on another same tune and gas.
Toyota John is offline   Reply With Quote
Old 02-17-2015, 12:15 PM   #6
Koa
Well said. I often think that how we measure a car's power is flawed.. Area under the curve, as you eloquently put it, is MUCH more important than peak.
How can we quantify this area under the curve on a Cartesian plane? Using integration/calculating the integral would be one easy approach. Would love to see this kind of perspective prevail over the currently "peak hp/tq" metrics
Old 02-17-2015, 12:38 PM   #7
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Old 02-17-2015, 12:39 PM   #8
xxBrun0xx
xxBrun0xx's Avatar
Drives: 2014 WRB BRZ Limited
This is a really good idea. I bet people would be surprised by how much "area under the curve" the twins have. I would be shocked if it didn't beat the pants off the S2K and all 2.0 WRX's, which people typically consider "faster". Somebody should start a thread about this. Would be interesting.
xxBrun0xx is offline   Reply With Quote
Old 02-17-2015, 12:46 PM   #9
Shiv@Openflash
Drives: 2013 FRS
We only use Dynojets for custom tunes. Other tunes use other dyne's and then apply a very optimistic "correction" to bring their numbers to "Dynojet-like" numbers. Unfortunately (or fortunately for them), this is not accurate or even logically sound.
The truth is that any flash tuning solution will results in equal power gains all things equal. Any tuner suggesting that their Kung Fu is stronger than anyone's else's Kung Fu needs to be taken down a couple notches.
Old 02-17-2015, 12:50 PM   #10
Koa
Shiv what do you think about the current automotive power metrics of peak whp/tq, and our proposed metric of finding the 'area under the curve' via integrals and calculus?
Would this be feasible? What are you thoughts on how people measure and discern the power of a combustion system?
Old 02-17-2015, 12:56 PM   #11
Shiv@Openflash
Drives: 2013 FRS
I think that is the best way to quantify power/power gains. In fact, we employed the same calculation back in the late 90s when compared power curve (area under the curve) in Sport Compact Car magazine's Ultimate Street Car Shootout
Old 02-17-2015, 12:57 PM   #12
Koa
Would following the integration process arrive us at similar results as you guys? How'd yall do it?
http://www.wyzant.com/resources/less...nding_the_area
Old 02-17-2015, 01:11 PM   #13
Shiv@Openflash
Drives: 2013 FRS
We used Excel By exporting the raw torque and RPM data from the dynojet run file, we created a spreadsheet that took rectangular "slices" of the torque curve and calculated area. Then we added up the areas of all the slices to get a reasonably accurate total area.
Old 02-17-2015, 01:12 PM   #14
Koa
Prime.. Thanks Shiv. I teach a business Excel course for accounting and MIS students at the University of Washington | Bothell campus, and love that dang program to death. Will certainly explore creating a macro-enabled tool to do this for people!
Have you hit 200whp NA? empower-auto Engine, Exhaust, Transmission 323 11-26-2015 07:49 PM
Best combo since my Ecutek flash and headers. BC-Boy Engine, Exhaust, Transmission 3 05-15-2014 08:49 PM
Delicious Tuning - 200+ whp E85, Stock Headers, EcuTeK ProECU DeliciousTuning Software Tuning 19 12-07-2013 12:01 PM
200whp for ~$1000 Shiv@Openflash Software Tuning 127 11-27-2013 07:26 PM
Dyno take 2, 200whp on 92Octane ?! AJ PwR Engine, Exhaust, Transmission 76 07-31-2013 02:14 AM
