Old 02-14-2015, 01:53 AM   #15
AlexBinJackson
Drives: 2015 Brz Blue Series Pearl White
Originally Posted by SPCorBUST View Post
i think you might be fine with those - several KW and JR kit folks are using similar setups with success. you can pop into the owners threads in the forced induction section and ask, i think both threads are pretty helpful in that regard.
just be careful of the kool-aid. seems like you "have" to be one camp or the other in those threads, consumer due diligence seems to be frowned upon.
Noticed you sold ur kW kit due to carb and I'm in the same boat. Still waiting for cosworth to see if they go carb if they don't most probably will be Jackson racing
AlexBinJackson is offline   Reply With Quote
Old 02-14-2015, 02:00 AM   #16
Andreas83
Andreas83's Avatar
Drives: 2013 Subaru BRZ
Originally Posted by AlexBinJackson View Post
A word of warning when thinking about dealing with robispec
I would suggest to find a different route
I was considering a robispec radiator when i got the car.
But based on feedback on this forum i never ordered one.
The solution itself seems to work very good.
But the downside was delivery time was way to long, people had issues with leaks and bad customer service in general.
I might pull the trigger on the Skunk2 ultra radiator.
But i would like some more info on it.
Stuff like fitting sizes etc.
I am installing a kraftwerks kit, solutions that avoids having to stack even more coolers in the front would make the install alot cleaner.
I am currently using a mocal laminova cooler, it has worked great for me NA.
But i think it will be to small for a FI application.
I really like using liquid2liquid coolers, they heat the oil up faster on startup.
Overcooling wintertime is not an issue.
Hoses can be alot shorter compared to a air cooled setup.
Andreas83 is offline   Reply With Quote
Old 02-14-2015, 02:22 AM   #17
http://store.skunk2.com/brz-frs-ultr...-radiator.html
Old 02-14-2015, 02:34 AM   #18
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
In for any testing data, might go this route if it proves effective. I am a starting to overwhelm the Perrin oil cooler on track.
Decay107 is offline   Reply With Quote
Old 02-14-2015, 02:51 AM   #19
I'm not loving the design and welding of the mounting tabs. Look like stress risers right at the weld. No buttress. Pass.
Old 02-14-2015, 04:13 AM   #20
SPCorBUST
SPCorBUST's Avatar
actually i didn't sell it yet. i do have a thread up, but i think i've only bumped it once or twice. i'm pretty much waiting for CARB approval, but I don't think that's ever gonna happen, so i'm just starting to think about dumping the kit in earnest.
i've ridden and driven both the KW and JR kits now, would be interested in hearing your experience switching kits to JR or Cosworth when it comes time. perhaps even Vortech...?
SPCorBUST is offline   Reply With Quote
Old 02-15-2015, 12:31 PM   #21
AlexBinJackson
Ya will keep u updated on the route I take but will be avoiding vortech for sure but the three options are Jackson, Cosworth and edelbrock. Not in a rush, and it keeps me in street class for the cup which is good
Old 02-15-2015, 02:12 PM   #22
SPCorBUST
SPCorBUST's Avatar
I think forced induction is okay for street class. I'll be at the cup event in a couple weeks, so I've been considering putting the kit back on temporarily.
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
Old 02-15-2015, 02:14 PM   #23
AlexBinJackson
I think it's modified class if I'm not mistaken I will be at button willow on 28 of feb
The Following User Says Thank You to AlexBinJackson For This Useful Post:
SPCorBUST (02-15-2015)
Old 02-24-2015, 09:28 PM   #24
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
So the radiator comes with a place to cool the oil but no lines and or oil filter adapter? anyone out the develop an oil cooler kit to go with this?
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 03-05-2015, 01:13 PM   #25
DAN_BRZ
DAN_BRZ's Avatar
Drives: 2013 WRB BRZ Sport Tech
i called skunk2, as was thinking of running this instead of a separate oil cooling but now im confused. scott told me this is for the transmission?? anyone running this as an motor oil cooler? maybe @KraftWerks can give us some more info on this product...
DAN_BRZ is offline   Reply With Quote
Old 03-05-2015, 01:36 PM   #26
kbye
kbye's Avatar
Drives: 2014 FR-S
maybe he means you can run the lines to the factory heat exchanger on automatic transmission models to effectively act as an auto tranny cooler. But I don't see any reason why this can't be used as an oil cooler as well.
kbye is offline   Reply With Quote
The Following User Says Thank You to kbye For This Useful Post:
DAN_BRZ (03-05-2015)
Old 03-05-2015, 01:37 PM   #27
yomny
yomny's Avatar
lol.. seems they're not interested in pushing their product, so little information I wouldn't want to deal with an RMA or some sort of problem. I'm sure you could use this to cool whatever you'd like.
The Following User Says Thank You to yomny For This Useful Post:
Old 03-05-2015, 01:50 PM   #28
DAN_BRZ
DAN_BRZ's Avatar
honestly that what i figured, but scott doesnt really to know what he is talking about, not bashing the guy but he gave vague answers and left me totally confused afterwards.
Skunk2 Header? FirestormFRS Engine, Exhaust, Transmission 69 10-11-2019 09:42 AM
Skunk2 Review. FirestormFRS Engine, Exhaust, Transmission 1 12-31-2014 08:55 PM
Skunk2 BRZ Intake Results! Xero-Limit Engine, Exhaust, Transmission 21 10-20-2014 01:43 PM
New skunk2 frs brz cold air intake 831GT86 Engine, Exhaust, Transmission 17 09-09-2014 04:09 PM
FS: Robispec Radiator (Massive radiator and liquid to liquid oil cooler in one) Sportsguy83 Engine, Exhaust, Bolt-Ons 15 05-27-2014 12:18 PM
