Old 02-10-2015, 03:53 PM   #43
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
Originally Posted by KoolBRZ View Post
It's not shocking at all. It's to be expected that @shiv would do a lot more work refining the UEL tune, since that was the tune used by Shiv everyday, while driving his car with a UEL OFH installed. This tune is designed to get the most from an unequal length header, to promote the header that they sell for the FT86 cars. So it makes sense that it would be the best running tune. What people don't realize, is that it is a better tune for EL headers also. This is a reason to BUY the OFT. To get that amazing stage 2 UEL tune.
From that perspective, I could see how you think that makes sense, but the OFT is marketed as a one stop shop with optimized tunes specified for a variety of products. When a tune designed for a certain product is outperformed by a tune designed for something entirely different, I find fault in that. If it's a better tune overall, then call it a header tune for both UEL and EL. This just shows me that the the EL optimised tune is in fact not optimized for an EL header.
It's like Darigold saying skim milk has all the flavor of whole milk... But, now we're entirely off topic. Obviously any header needs a tune to make the most power out of it, but you have to admit, a tune for an EL manifold should out perform a tune optimized for an UEL manifold, and that's where I find fault.
Back on topic. This header rocks for the price, and we need some more people who have it to get tunes to see how it compares accross the market.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 02-10-2015, 04:02 PM   #44
sachu
Drives: rocketship
The caveat being that the Skunk2 is indeed an EL header and not UEL. There are some headers taht claim to be EL but are actually UEL depending on how much variance is present in the lengh of the runners.
sachu is offline   Reply With Quote
Old 02-10-2015, 04:12 PM   #45
86SPEED
86SPEED's Avatar
Drives: The silvertrooper 10 series
We will have one of the local cars tuned very very shortly with his Skunk2 EL header.. Unfortunately.... or Fortunately depending on how you look at it, a Kraftwerks C30 blower will be added at the same time as the tuning lol. BUT he has had the header for the last month and he loves it. His setup sounds really good, and is currently the only EL setup i personally like the sound of, Skunk2 header, MXP overpipe, OEM front pipe and Perrin 3" catback. Mike from Moto-East will be setting up the tune, but the base canned tune he sent felt great. We do have 2 cars running the same kits, just different headers and we will be getting dynos. we know it wont be a perfect scenario but both will be on the same fuel, SC kits, and mapped from the same tuner. only difference will be the 2 exhaust setups.
-Thomas
P.S. out of the 4 cars here in Vegas, not one has had a CEL at this time
86SPEED is offline   Reply With Quote
Old 02-10-2015, 04:49 PM   #46
Hyper4mance2k
Alexandrino_Auto
Drives: series.Blue
My car gets a CEL with the header, but I'm still on the stock tune, so obviously it should. I even tried the spacer trick and it only delays the CEL for about 800 miles.
Has anyone ever successfully tried one of those mini cats (spacer with a tiny chunk of "Catalyst")?
Old 02-10-2015, 05:04 PM   #47
sachu
Drives: rocketship
I went back to stock tune as my tuner wanted to do some more homework based on what we learned from the OFT UEL tune specifically.
My tuner's original tune still did the best up top (but laggy and choked in the bottom) but the OFT UEL tune gives some ideas about waht to do on the bottom end in the torque dip area. Till he comes up with a few solutions to try later this weekend I am back on the stock tune.
No CEL so far.
I do like the osund of this header, there is some rasp with the stock tune past 4k RPM.
Swapped my 3 inch perrin resonated catback to a 2.5 inch perrin resonated. Loving it so much more as there is minimal drone.
The sound was brilliant with the UEL OFT tune I must say.
Old 02-11-2015, 05:31 PM   #48
limitedblkwrx
Ultimate Member
limitedblkwrx's Avatar
Drives: 2014 Satin White BRZ
I don't have dyno numbers but I I am running
OFT stage 2 EL tune
Skunk2 Header
Tomei Overpipe
@MAPerformance 3" front pipe and catback
I have noticed that where the header meets the tomei over pipe has a small leak at the bottom. I am going to try and replace the gasket that came with the Skunk2 header with the tomei overpipe gasket that I have and see if that fixes it.
Installed pic:
Cold Start Video:
[ame]http://youtu.be/HjUKvCqqyNg[/ame]
About 70% Acceleration Video: (yes I changed my wheels while it was in the air)
[ame]http://youtu.be/8Qq3oxRRnUM[/ame]
limitedblkwrx is offline   Reply With Quote
Old 02-11-2015, 05:38 PM   #49
johan
Drives: '14 981CS, '99 NB1
Originally Posted by wparsons View Post
Was it re-tuned after the header, or still running the original tune?
Car had already been tuned with existing mods. Header was installed at the shop and then immediately the car was re-tuned.
johan is offline   Reply With Quote
Old 02-12-2015, 09:00 PM   #50
86SPEED
86SPEED's Avatar
With what header are you getting the Code?
The shop car has well over 1000 miles with the skunk2 header with no CEL at all.
Old 02-13-2015, 01:10 AM   #51
Hyper4mance2k
Alexandrino_Auto
Drives: series.Blue
I have a Skunk2 header. Just wait... I've put on over 2500 miles and I've had a check engine light 3 times. There's no cat and on the stock tune you're going to get a CEL.
Old 02-13-2015, 01:49 PM   #52
sachu
Drives: rocketship
OFT stage 2 EL tune
Skunk2 Header
Tomei Overpipe
Installed pic:
Attachment 102352
Cold Start Video:
Try running the OFT UEL tune..let me know how it feels from 2k-5k RPM compared to the EL tune.
Also, the sound between the two tunes. Hearing that rasp with the EL tune i noticed in mine.
Old 02-13-2015, 04:31 PM   #53
Hyper4mance2k
Alexandrino_Auto
Drives: series.Blue
OFT stage 2 EL tune
Skunk2 Header
Tomei Overpipe
Installed pic:
Attachment 102352
That looks great ceramic coated!! I'm planning on taking mine off soon to have it coated. The plan was to have it coated before i instaleld it, but I can't have parts in my hads very long -not without using them.
Old 03-01-2015, 12:43 AM   #54
sachu
Drives: rocketship
Here's my current tune with thefollowing mods.
Skunk2 header
Skunk2 intake (with insert)
Nameless overpipe/front pipe with cat
Perrin 2.5 inch resonated catback
Stock car versus modded tuned car.
The insert on the intake needs to be removed and the MAF rescaled again. SO more gains to be had likely.
I might go back to the stock overpipe and front pipe and see if that gives me more torque as well.
Want to give a shout out to Wryaan at VIP performance for working on the tune.
Old 03-01-2015, 01:49 PM   #55
Hyper4mance2k
Alexandrino_Auto
Drives: series.Blue
Love it! And here I thought you needed e85 to make 200+ who NA.
Old 03-01-2015, 03:27 PM   #56
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
His stock run was at 180whp which is unusually high though.
Skunk2 Lowering Springs NOW AVAILABLE! KraftWerks Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 01-10-2015 09:22 PM
Skunk2 BRZ Intake Results! Xero-Limit Engine, Exhaust, Transmission 21 10-20-2014 01:43 PM
New skunk2 frs brz cold air intake 831GT86 Engine, Exhaust, Transmission 17 09-09-2014 04:09 PM
Skunk2 Garage Sale: 06.28.14 KraftWerks Southern California 4 06-24-2014 08:53 PM
FS: Skunk2 Racing 1.3 kg/cm Rad Cap ***SOLD*** JPxM0Dz Canada Classifieds 0 10-01-2013 01:25 PM
