| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#15 |
Drives: 2013 FRS, with boost by ATS Racing
The tool works fine. It's just not completely idiot proof, as evidenced by some of the responses here, mine included.
EDIT: The tool is idiot proof. The process is apparently not. Last edited by robr; 02-11-2015 at 01:03 PM. |
#16 |
Drives: 2014 Subaru BRZ Limited WRB AT
I have the same setup as @tobin and it works great.
Cosworth Drop-In Air Filter, Diode Dynamics DRL module, Perrin Tips |
#17 |
Drives: FRS 10 Series
#18 |
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
I just live with the dash light being on. Both sets of aftermarket wheels/tires I have don't have TPMS sensors in them. Just another dash light to have on, I often have the traction and/or stability control lights lit up on my dash too. On some other cars I've used pre-cut pieces of tint on the dash to minimize the annoyance of TPMS or other dash lights being lit up.
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar |
#19 | |
Just to make sure those other lights are on by choice? I read somewhere that in some cars the stability/traction don't work with out tpms? |
#20 |
"Worth it" is a decision you need to make yourself. I didn't buy the one at our shop, but I would have if we didn't have it. I can't stand dash lights being on. To the point I might look into making the traction control lights come on when those systems are on (which is never) instead of when I turn them off.
But if a dash light isn't a $150 problem to you, then no, it's not worth it. See if any locals have one you can borrow/use? |
#21 |
Drives: '13 BRZ
FYI, the tool/program can store 4 cars in it at once. So if you have a friend that also swaps wheels/tires, maybe you guys can split the cost of the tool?
I agree the $150 seems a little pricey up front, but if you plan on owning the car for a while, divide the 150 by the number of years you're going to keep the car, then figure you'll use it twice a year, etc. Say you keep the car for 10 years, you're talking $15 a year to not have an annoying yellow light on the dash. |
#23 | |
Drives: '13 BRZ
#24 | |
#25 |
Drives: 2014 Scion FR-S
Just go to americas tire or discount tire where ever you live. I work at one of the shops in California, just take your new set of oem wheel with new sensors (make sure they're on your car) and they'll do the process (tpms relearn protocol) which takes like 5 minutes
#26 | |
Drives: '13 BRZ
#27 |
TPMS
I can take care of this for you P.M me The atqe is the hard way to do it .
Thanks |
#28 |
Drives: 2014 SWP BRZ, MT
I saw something a little while back about clone-able TPMS sensors that you can basically program to report the same serial numbers as the original sensors. That way when you swap wheels the car doesn't know you're using a set of 4 different sensors. Certain tire shops may be capable of doing it, you could probably ask around your local tire shops and see who's heard of it.
The answer is racecar. Always.
| WTB: TPMS | jgonx213 | Wheels and Tires | 3 | 12-01-2014 02:29 AM |
| NEED HELP!! TPMS light on. with TPMS installed on aftermarket rims+tires | Figo | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 09-23-2013 08:11 AM |
| Changed to new wheels w/o TPMS, car still thinks I have TPMS sensors? | Ahz | Issues | Warranty | Recalls / TSB | 9 | 11-06-2012 08:25 AM |
| TPMS | smbrm | CANADA | 2 | 09-21-2012 11:17 AM |
| so what is everyone doing about their tpms? | Hachi6 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 07-22-2012 05:04 AM |
