Old 02-10-2015, 08:08 PM   #15
Originally Posted by UchihaFanBoy View Post
I hope so I'm still going to flush it out just in case.
If it makes you feel better. Not needed though.
Old 02-10-2015, 08:11 PM   #16
JohnJuan
JohnJuan's Avatar
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
There is the recommended type but it won't hurt anything if mixed a bit.
He means you'll be wasting money if you have it flushed. Don't do it.
JohnJuan is offline   Reply With Quote
Old 02-10-2015, 08:13 PM   #17
enjetek
Drives: 93.5 supra t & prius
Me oh my. Relax you'll be fine.
enjetek is offline   Reply With Quote
Old 02-10-2015, 08:15 PM   #18
TheVoiceOfReason
TheVoiceOfReason's Avatar
Drives: BRZ Limited
The blue stock coolant is made to last 100k miles. Mixing with green coolant shortens the life to 30k miles but isn't harmful other than that. It just breaks down sooner.
TheVoiceOfReason is offline   Reply With Quote
Old 02-10-2015, 08:32 PM   #19
UchihaFanBoy
UchihaFanBoy's Avatar
Drives: 16 BRZ,99 Forester,13 FRS(RIP)
I'm doing it myself. Not going to be that hard to flush it out. Pretty easy lol
UchihaFanBoy is offline   Reply With Quote
Old 02-10-2015, 08:34 PM   #20
UchihaFanBoy
Thats the reason why I want to flush it out ASAP!!! lol
Old 02-10-2015, 08:36 PM   #21
Priapus
Priapus's Avatar
Drives: 2013 Asphalt FR-S
I work for Toyota, and it is a common knowledge there that you cannot add GM's Dex-Cool into your cooling system. Toyota and GM use different coolants that can (and will) turn each other into shit if mixed. So not all coolants are the same, and not all coolants can be mixed. To be on the safe side, I recommend doing a flush.
On the other hand, if your engine is not overheating, you should be fine.
Priapus is offline   Reply With Quote
The Following User Says Thank You to Priapus For This Useful Post:
Tcoat (02-10-2015)
Old 02-10-2015, 08:48 PM   #22
UchihaFanBoy
Will happen tomorrow for sure. Don't want to shorten the life of my car.
The Following User Says Thank You to UchihaFanBoy For This Useful Post:
Tcoat (02-10-2015)
Old 02-10-2015, 09:02 PM   #23
More important than using the correct antifreeze, IMHO, is using only distilled/deionized water in the mix.
No deposits. No corrosion.
Don't forget to burp out the air.
Old 02-10-2015, 09:03 PM   #24
Oh, jeez. You're fine.
Old 02-10-2015, 09:08 PM   #25
BlackMonarch
Drives: Red BRZ
I run royal purple antifreeze omg am I doomed?
BlackMonarch is offline   Reply With Quote
Old 02-10-2015, 09:10 PM   #26
rekt
Old 02-10-2015, 09:37 PM   #27
BlackMonarch
Drives: Red BRZ
rekt
#awshitididntreadthemanual - #rektmykar
Really though, OP... I wouldn't even worry about it. I had to run some super low-temp washer fluid, and mixing it turned out just fine. It's roughly the same thing.
Old 02-10-2015, 11:34 PM   #28
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
The life of the car is fine. Your coolant isn't.
Even if you flush/change the coolant -- it doesn't mean your new coolant will last for like 10 years. Toyota recommends after the factory fill, change it every 30k miles I believe.
Just wait until 10k miles. (Assuming you used a universal antifreeze).
If you used Dexron then your car is going to explode
jk
N1rve
Heaviest Shift Knob that won't burn / freeze your hand? bren5279 Cosmetic Modification (Interior/Exterior/Lighting) 13 09-28-2014 09:18 PM
Anti A-Hole Button ButtonMasher Off-Topic Lounge [WARNING: NO POLITICS] 45 07-25-2014 12:55 PM
FS:NY RCE Anti-roll/Sway Bar kit $250 snky_snky Brakes, Suspension, Chassis 2 08-19-2013 09:42 PM
BRZ Navigation Freeze/Crash TM Electronics | Audio | NAV | Infotainment 3 06-08-2013 12:29 PM
BRZ Anti Theft system Skurj BRZ First-Gen (2012+) — General Topics 15 01-21-2013 03:38 PM
