Old 02-09-2015, 01:49 PM   #2479
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
Originally Posted by 7thgear View Post
lol, fuck him.
unless you threw those rocks at him yourself, out the side window while flipping the bird, then it's just tough luck.
And if anything, more his fault than yours, seems like he was following you so close that he made the same mistake in corner entry... that's like one of the biggest no-no's in racing/lapping, don't let the driver in front of you zone you into a tunnel.
It sucks that his glass got scratched but it ain't your problem.
@Jonsey This. It's flawed logic to think rocks are kicked up intentionally. If you want your car pristine, don't track it.
raul is offline   Reply With Quote
The Following User Says Thank You to raul For This Useful Post:
CSG Mike (02-09-2015)
Old 02-09-2015, 02:17 PM   #2480
ddeflyer
Originally Posted by Jonsey View Post
You are right, I should have gone zero lock a tad bit sooner, however, it never felt close to a spin or out of control. Perhaps I am missing something, but I don't see it in the video either.
To me it looks like you were understeering through most of the turn and then you started to get into oversteer just a moment before going off. I think if there had been a couple more feet of track you would have had the ends swap places.
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next!
ddeflyer is offline   Reply With Quote
Old 02-09-2015, 06:05 PM   #2481
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
Unless it's a dedicated track car he will probably file a claim regardless and possibly get paid twice. In Florida windshield replacement is 100% covered with zero deductible.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
Old 02-09-2015, 06:20 PM   #2482
Jonsey
Jonsey's Avatar
It is possible that there was a transition from understeer to oversteer before going off, however, that doesn't necessarily equate to the ends swapping places. Thankfully our cars in general are very balanced and usually require only minor corrective action to control any slide.
Jonsey is offline   Reply With Quote
Old 02-10-2015, 12:32 AM   #2483
OnionTou
OnionTou's Avatar
Drives: Toyota GT 86
My car is a weekend car, autox, trackday car. (I think I go to 5 or 6 autox, 2 or 3 trackdays a year). I don't want a hardcore racecar, but I don't want it to be completely a soft car. (Does that even make sense?) My goal for autox and trackdays is to have fun, not to shave milliseconds on my lapt times. Some people think I'm crazy for spending so much and not properly racing my car.... anyway...
I need alignment info for my setup. and if possible damper for settings.
My setup is:
NA engine (no FI, nor plans to get FI)
Yokohama AD08 225/40R18
Tein Street Flex (Damper set at 7/16 front 9/16 back for daily 10 front, 8 back of autox)
Sway Bars 19 mm front
Sway Bar 16 mm rear.
End links (front and back)
LCA (rear)
Toe Arm (Rear)
Rear diff support (Brace)
whiteline Bump steer kit
I've tried other people's setups and I find the car a little too twitchy. I want an easy to drive setup.
OnionTou is offline   Reply With Quote
Old 02-10-2015, 01:06 AM   #2484
CSG Mike
CSG Mike's Avatar
What's your current alignment?
Hollow or solid sways?
Old 02-10-2015, 07:19 AM   #2485
OnionTou
OnionTou's Avatar
On the topic of my sway bars, both are perrin but I don't know if they are solid or hollow.
According to Perrin's spec, they way I have them set up:
Front 19mm Bar Hole #2 72% Stiffer than 18mm OEM Bar
Rear 16mm Bar Hole #2 65% Stiffer than 14mm OEM bar.
Based on the specs for perrin I could go:
Front:
PERRIN 19mm Bar Hole #1 25% Stiffer than 18mm OEM Bar
PERRIN 19mm Bar Hole #2 72% Stiffer than 18mm OEM Bar
Rear:
PERRIN 16mm Bar Hole #1 30% Stiffer than 14mm OEM bar
PERRIN 16mm Bar Hole #2 65% Stiffer than 14mm OEM bar
PERRIN 16mm Bar Hole #3 116% Stiffer than 14mm OEM bar
I am willing to change to a different hole if you guys think I would get better cornering.
Old 02-10-2015, 07:25 AM   #2486
OnionTou
OnionTou's Avatar
FYI, if you want to see the local circuit:
[ame="https://www.youtube.com/watch?v=xLfRtwzA_us"]Trackday from last year[/ame]
Most of it is 3rd, I think the fastest you can go on the main straight is about 110-120 mph. I was in the 1:15 range, and that was before I got most of my suspension stuff. I only had coilovers )settings were probably in the middle for dampers) and 18 inch Yokohama AD08s.
My buddy with the fastest gt86 clocks in around 1:09 (I think), with goodyear assymetrics, intake, springs and pulleys.
Old 02-10-2015, 11:38 AM   #2487
ddeflyer
Man, that black car at the beginning is dangerous!
Old 02-10-2015, 11:49 AM   #2488
Pat
Pat's Avatar
Drives: 2023 BRZ
Interesting braking technique, huh?
Old 02-10-2015, 12:09 PM   #2489
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Stupid and suicidal are the words I'd use, pulling onto the track mid-corner without looking for oncoming traffic. I also didn't see anybody with flags. He should have been taken off and yelled at, if not beaten.
I think driver mods will make much more of a difference here than car setup, but what do I know.
Old 02-10-2015, 12:35 PM   #2490
OnionTou
OnionTou's Avatar
he was a new guy. first sports car, first trackday. first everything I think.
The video is from a trackday that was sponsored so the usual fees were waived. So a lot of non-trackday people came to learn about their cars.
Old 02-10-2015, 12:58 PM   #2491
ddeflyer
Even if some of them were first timers, it is pretty cool that you had a line of several 86s there!
Old 02-10-2015, 01:35 PM   #2492
CSG Mike
CSG Mike's Avatar
@OnionTou
Whats your current alignment?
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
