go_a_way1
Old 02-05-2015, 10:54 PM   #2661
swarb
^245/40's are too tall.
Old 02-05-2015, 11:05 PM   #2662
rixter145
Sleep Chomper
rixter145's Avatar
What would you suggest? 245/30?
Because this guy has it at 225/40 for his car:
http://www.ft86club.com/forums/showthread.php?t=57214
rixter145 is offline   Reply With Quote
Old 02-06-2015, 05:00 AM   #2663
swarb
Look at the tire specs and compare to stock. Around 25 inches diameter is good. Stock is 24.7, 245/40 is around 25.6, 225/40 is 25. Many people run 245/40, but to me it looks like too much sidewall. Since you say function>form you should just get 255/35 or 245/265 35's
Old 02-06-2015, 11:05 AM   #2664
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Originally Posted by rixter145 View Post
Hello everyone, I am looking to get a new set of wheels & tires (choices tbd later, right now I'm looking for measurements and sizing) for my boosted set up (going for ~300 whp & lowered 1")
My main use cases are:
Streets & AutoX
Requirements:
lighter wheels - function > form, though looking good is a definite plus.
Perfect Flush
Square Set up
My option:
Looking at 18x8.5 with 245/40, offset: +42 Front, +32 Rear, no Camber
Taken this from the Wheels Directory post Darren started but I am wondering if the offsets are a bit too much for the front?
Also I am wondering if that tire is too skinny for the power I am putting down. I don't want to kill gas mileage as well.
Any sort of suggestions?
What @swarb said about the tires is correct.
It's about total diameter, so as you go wider you need to go with a shorter sidewall number to match the ideal diameter. For speedo accuracy, you want to stay within 5% max, but close as possible to stock.
OEM diameter for 215/45R17 is 24.6"
  • 225/40R18 - pretty close, 25.1", 7.5-9" wheel
  • 235/40R18 - bit tall but okay 25.4", 8-9.5" wheel
  • 245/35R18 - just about perfect 24.8", 8-9.5" wheel
  • 255/35R18 - pretty close but still okay, 25.0", 8.5-10" wheel
  • 265/35R18 - even taller but doable, 25.3", 9-10.5" wheel
  • 275/35R18 - tall but within 5%, 25.6", 9-11" wheel
  • 285/30R18 - close to perfect OEM diameter, 24.7", 9.5-10.5" wheel
What is your suspension setup? Stock, lowering springs or coilovers, camber settings?
Slick is offline   Reply With Quote
The Following User Says Thank You to Slick For This Useful Post:
rixter145 (02-06-2015)
Old 02-06-2015, 02:33 PM   #2665
rixter145
Sleep Chomper
rixter145's Avatar
I am lowered 1" all over - using Megan Racing Streets Coil Overs (not the ez ones). I don't have any camber settings right now.
Looks like 245/35 seems likes a go for me in that case.
What about 235/35? Would that be too skinny for a 300 whp grip?
As for 8-9.5 wheels, is it advantageous to choose bigger or is it just user preference?
Old 02-06-2015, 04:58 PM   #2666
Slick
Slick's Avatar
Looks like 245/35 seems likes a go for me in that case. As for 8-9.5 wheels, is it advantageous to choose bigger or is it just user preference?
There is no "real" reason to go with bigger wheels other than your own preference. Larger = more unsprung weight, more inertia to overcome.
But then I should be on 17x8's, and not running 18x9's with 255's, lol..
Old 02-06-2015, 05:23 PM   #2667
rixter145
Sleep Chomper
rixter145's Avatar
Looking at the tire-size conversion
It shows:
275/35R17 = 24.6x10.8R17 is the only other equal one... that's too wide of a tire and definitely too much if I'm only aiming at 300 whp lols
If I do want to stick with 17s and have a wider grip than stock 215, I will have to do a 245/40 which is a +0.4%... which is as close as I am going to get on 18s.
So is 245/40 with 17x8.5-9 a sound choice?
Btw thanks so much for the input Slick!
Old 02-08-2015, 08:10 AM   #2668
Slick
Slick's Avatar
It shows:
Yeah, perfect size tire and the wheel size is spot on.
rixter145 (02-08-2015)
Old 02-08-2015, 08:09 PM   #2669
Quball
Hello guys, Hoping for some help from across the pond, I've some 18 x 8.5 ET35 alloys on order what would you guys suggest for tyres?
I have KW V3's fitted also.
Quball is offline   Reply With Quote
Old 02-08-2015, 08:26 PM   #2670
Slick
Slick's Avatar
As long as the wheels don't poke (correct offset), then a 245/35R18 would be a perfect fitment.
Old 02-09-2015, 12:34 PM   #2671
sftateofmind
Evening Primrose
sftateofmind's Avatar
Good morning or afternoon to you east coasters. I am having trouble finding the answer via search but I'm sure it's been asked before.
I'm going to run stock rims for awhile but I want to get rid of the gap that exist with the stock tires on as well. How would I go about remedying this problem without a drop?
Spacers? If so could you point me in the right direction?
Would those spacers also work for new tires in the future so as long as they are the same dimensions?
Complete noob in this area so apologies for the silly questions. Thanks.
sftateofmind is offline   Reply With Quote
Old 02-11-2015, 02:56 PM   #2672
cdo221
Drives: 2013 Ultramarine FR-S, 2015 RS 1.0
Would 215/50/17s fit on stock everything lowered a bit over 1 inch?
I'm on TRD springs but want to get some 215/50s on my stock wheels. Will it fit without rubbing?
I know 215/55s will rub on lowering springs from this thread:
http://www.ft86club.com/forums/showthread.php?p=536325
But not sure about 215/50s, any help would be appreciated!
cdo221 is offline   Reply With Quote
Old 02-11-2015, 07:22 PM   #2673
FloridaBRZ
Drives: 2013 Subaru BRZ Limited 6sp DGM
Im lowered on Tein S springs. I am looking at the Advan RGIII rims. Would 18's fit without rolling the fenders? What would be the best size? I don't care if they are 17's or 18's. I just don't want to rub or have issues after I order them.
Thanks.
FloridaBRZ is offline   Reply With Quote
Old 02-11-2015, 10:29 PM   #2674
Beachnuttz
Beachnuttz's Avatar
Drives: '13 Firestorm
Any camber bolts used?
You may need spacers, might not, depends on your camber. 5mm spacers are cheap, so buy them just in case.
245/35 is a perfect tire size for an 8.5" wheel.
I just got the wheels, spacers came today. THEY LOOK AMAZING! I can not lie, I am a little nervous on them even fitting, they look HUGE compared to what is on now! LOL
Thanks for your help Slick and I will post a picture when installed.
Beach
TRD Lowering Springs
TRD Front and rear sway bars
Perrin 3 inch Cat Back Exhaust
Beachnuttz is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
