Old 12-05-2012, 12:25 PM   #29
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
Originally Posted by miodculae View Post
nice. weight only 11.5 lbs.
wonder how it will perform compare to stock. please report back.
how much of a weight savings ?
I used the 17 lb Braille no-weight AGM for a couple years. It always started but sometimes when it was really cold, it barely made it. If you leave your lights on with the engine off for 5-10 min, it will no longer start. And after about 2 years, the battery loses so much energy, you have to replace it. I now use the 21 lb version and it seems to be more forgiving.
Toyota + Subaru =
Bristecom is offline   Reply With Quote
The Following 3 Users Say Thank You to Bristecom For This Useful Post:
DocWalt (05-10-2023), HATED1 (02-07-2015), Keenercarguy (01-19-2016)
Old 02-04-2013, 09:32 AM   #30
Tommy_H
Drives: Toyota GT86
Originally Posted by stevo_12v View Post
No issues what so ever. Really good battery. It's been running excellent since I posted up above(30th August) Starts first time all the time. I don't even have it connected up to a tender.
Hello stevo_12v
So another two months have passed... are you still happy with the smaller battery?
See, I'm thinking about doing the same but am not yet decided on the new battery's capacity. I'm most concerned about those times when one does not drive the car and the battery empties itself. I will most likely drive my GT not more than twice a week, sometimes maybe only on the weekends. So any smaller battery should give me say 10 days of bridge time that I need not drive the car.
I'm very diligent to always turn off all obvious power consumption like stereo, radio, air con, lights etc. whenever I turn off the engine, but some electronics is always running, obviously. I also understand that in winter a more powerful battery makes sense. Well, I guess you do not have this problem in Perth AUS!!
Basically I would just like to ask you a bit about the driving pattern and the down times that your GT is submitted to. Do you drive it every day? Once a week? Rather many shorter trips or fewer longer ones?
Thank you very much!
Tommy_H is offline   Reply With Quote
Old 02-04-2013, 03:03 PM   #31
stevo_12v
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
Hi,
The battery is very good. Haven't had the need to use the battery tender. Always starts first go.
I drive my car pretty much every day(for the past month) as the weather is nice.
If I don't drive it, it's probably about 2 full days which I don't drive it.
If I drive it to go out/go to work.. I'm usually driving it for over 20mins at a time too.
One time I accidentally left my interior light on overnight(its LED) and I managed to start the car no problem at all.
stevo_12v is offline   Reply With Quote
Old 02-04-2013, 04:31 PM   #32
wtout86
Drives: Whitout FR-S 6MT
Anyone seen these? http://antigravitybatteries.com/?page_id=994
For $220 you can get 360CCA at just 2.3LBS.
Made in the USA
wtout86 is offline   Reply With Quote
The Following 3 Users Say Thank You to wtout86 For This Useful Post:
Anthonytpt (03-09-2013), Black Tire (02-10-2013), supragoods (03-05-2013)
Old 02-10-2013, 12:50 PM   #33
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
Here's another possible alternative:
http://lithiumpros.com/products/more...rt_number=C680
My cars always dress formally. They all wear black tires.
Black Tire is offline   Reply With Quote
Old 03-08-2013, 03:16 PM   #34
Anthonytpt
Anthonytpt's Avatar
Drives: '13 Argento 6MT FR-S
If I were to switch to a Shorai LFX14L2-BS12 battery, would I experience issues running the car and listening to stock stereo? I'm confused with all the mentioning of smaller batteries and stereos being troublesome in this thread.
Much thanks in advance!
Anthonytpt is offline   Reply With Quote
Old 03-11-2013, 09:55 PM   #35
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
Lol I went the opposite way...
Diehard Platinum Group 35. Rebadged Odyssey battery so it is AGM, and has insane cranking power (740 CCA). Heavy though, 38 lbs.
It's not racecar, but I've been having issues starting the car and three places said my OEM battery is bad. Don't want to get stranded. The bonus is that my car should start in almost every climate.
I believe the stiffened suspension shook my battery bad. I read these things don't like to be shook.
20130308-DieHardBattery-005 by VictorN07, on Flickr
F1point4 is offline   Reply With Quote
The Following User Says Thank You to F1point4 For This Useful Post:
DandoX (03-27-2017)
Old 03-11-2013, 09:58 PM   #36
F1point4
Photo Specialist
F1point4's Avatar
Keep in mind the battery's primary purpose is to start the vehicle. Then the alternator takes over in keeping the car running and powering your electronics.
However, you will rely on the battery to keep you going if you decide to listen to the radio or turn your AC on with the engine off. A battery that is rated low may have a hard time starting your car if you do stuff with the engine off.
I considered a lightweight battery, and most of them look up to the task of getting you going reliably. However most of them match the stock battery performance and I wanted something a bit more so I decided to go with a big drop-in replacement.
Anthonytpt (03-12-2013)
Old 03-12-2013, 03:03 AM   #37
Anthonytpt
Anthonytpt's Avatar
Thanks for the input. I never use the electronics after the engine's off so the lightweight batteries are still a go.
Old 01-16-2014, 12:30 PM   #38
ML
ML's Avatar
Drives: 13 White MT FR-S
is the stock battery SLA?
Old 06-28-2014, 04:58 AM   #39
quark
Hi,
Hi Stevo 12v
Where did you get the dome Leds's from? Jaycar?
How does the dimming go as the delay times out?
quark is offline   Reply With Quote
Old 09-05-2014, 08:57 AM   #40
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
An Autocraft Group 51R battery is smaller and weights 2 pounds less than the stock Panasonic battery. The Autocraft Gold Group 35 is listed as the replacement and it weighed 38 pounds.
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 02-05-2015, 10:49 PM   #41
YouShallKnow
Drives: Man
Send a message via ICQ to YouShallKnow Send a message via AIM to YouShallKnow Send a message via Yahoo to YouShallKnow
Originally Posted by Draco-REX View Post
Subaru likes using group 35.
Mine will be quickly replaced with a Lawn and Garden Battery unless the compression is too high for 275CCA to crank. But I doubt it.
Did you ever end up doing this?
My battery just died and I can't shell out ~$200 for the Shorai I want atm. I'm looking for something cheap to last a month or two and your lawn and garden idea seems perfect. If it works that is!
YouShallKnow is offline   Reply With Quote
Old 02-06-2015, 01:47 PM   #42
YouShallKnow
Drives: Man
Nevermind! I just sacked up and bought the damn thing. I didn't buy any kind of terminal adapter so I just kind of wedged the stock connectors on and zip tied them closed.
Works fine, cranks to start easy, and seems 15 pounds lighter.
I ended up getting a Lawn & Garden from walmart with 275 cca, cost $30 plus $12 core charge. I'll run it until it fails then get my Shorai!
Tow hook specs? mufasis BRZ First-Gen (2012+) — General Topics 15 10-21-2012 10:41 PM
Aftermarket battery speed-wiz Scion FR-S / Toyota 86 GT86 General Forum 59 08-07-2012 11:23 PM
BRZ CDN specs up at Subaru.ca! Sport-Tech CANADA 17 04-05-2012 09:12 PM
Aussie specs sneaky AUSTRALIA 7 03-14-2012 12:37 AM
Two Ft86 Specs for Aus church Scion FR-S / Toyota 86 GT86 General Forum 17 06-19-2011 07:53 PM
