go_a_way1
Old 02-04-2015, 04:29 PM   #2647
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Originally Posted by hayden55 View Post
* looking for a 52 offset for the rear and 45mm offset in the front. Then i can change up wheel studs and spacers to get what i need since rims for this car arent very common.
Mostly i want a rear tire that is straight up and down and has the largest contact patch in a straight line for boost, and up front i wouldnt mind a 1-1.8 ish degrees of camber for fitment and a little bit of grip in the corners.
Still kinda thinking about everything
If you're adding 5x114.3 conversion spacers, then those will add 15-25mm depending on the type you choose.
Let's say 25mm spacers (most common), then your effective offset will be +27. You will have poke unless you gain extra negative camber, somewhere around -3 or more.
You can use smaller conversion spacers like 15mm as you stated but make sure the wheels you are fitting have voids to let the rest of the OEM studs poke through (see pic below to explain what I mean). This would give you effective offset of +37 which is just about perfect. With this setup a 245/40R17 will work very well.
Slick is offline   Reply With Quote
Old 02-04-2015, 04:51 PM   #2648
Sploozel
Drives: 2015 BRZ CWP
SSR GTV02 18x9.5 +40 square setup lowered on fortune auto coils.
What kind of tire size you think is appropriate? I was looking at 255/35. What would you recommend?
I assume the rear will be fine, how would the front be?
Sploozel is offline   Reply With Quote
Old 02-04-2015, 06:14 PM   #2649
SkyBRZ
SkyBRZ's Avatar
Drives: 2015 Subaru BRZ
Originally Posted by SkyBRZ View Post
Hey there,
New Brz owner here, 2015 Limited.
I am currently looking at buying ROTA D2-Ex wheels 18x9.5 +38mm 73
with the sumitomo tires 265/35ZR18
I currently have Tein S-tech lowering springs on the car
Im unsure if the wheels will fit in the front just because of the width?
Thanks for any help!
Any input??
SkyBRZ is offline   Reply With Quote
Old 02-04-2015, 11:11 PM   #2650
Beachnuttz
Beachnuttz's Avatar
Drives: '13 Firestorm
looking at Kojin's, 8.5 18's with a +45 with a 245/35 tire setup work? I believe I will need spacers for the fronts (5mm)? Lowered on TRD springs
Thanks, Beach
TRD Lowering Springs
TRD Front and rear sway bars
Perrin 3 inch Cat Back Exhaust
Beachnuttz is offline   Reply With Quote
Old 02-05-2015, 11:39 AM   #2651
Slick
Slick's Avatar
Hey there,
Sorry man, missed responding to your post.
Firstly, what camber settings are you at?
With just lowering springs, these wheels will be a no go, you need coilovers.
I'm on 18x9 +35 on springs and I have only about 4-5mm clearance to the strut spring seat on -2.2 camber. You will be closer by 9mm hence the extra clearance by going on coilovers. As you stated, rears are probably okay but fronts are the issue.
Old 02-05-2015, 11:53 AM   #2652
Slick
Slick's Avatar
Wheels and tire selection are good. Should be fine with a 255/35R18, could even go to a 265.
Old 02-05-2015, 11:56 AM   #2653
Sploozel
Awesome man, thanks for your help. I ordered 255/35.
YOU WONT.
Old 02-05-2015, 11:57 AM   #2654
Slick
Slick's Avatar
Thanks, Beach
Any camber bolts used?
You may need spacers, might not, depends on your camber. 5mm spacers are cheap, so buy them just in case.
245/35 is a perfect tire size for an 8.5" wheel.
The Following User Says Thank You to Slick For This Useful Post:
Beachnuttz (02-06-2015)
Old 02-05-2015, 01:06 PM   #2655
Beachnuttz
Beachnuttz's Avatar
Not sure on the camber bolts as I had the dealer install everything. But I will buy the spacers just in case.
I really appreciate your feedback!!
Beach
Old 02-05-2015, 07:54 PM   #2656
SkyBRZ
SkyBRZ's Avatar
Damn I just have the Tein S-tech Springs which lower the car 1.4 inches in the front and 1.2 inchs in the back so I have to have coilovers for them fit? Is the issue for them to be hitting the suspension or?? Because there was another thread on here with a dude who had Rota Torques 18x9.5 on front and rear he had coilovers but they didn't look like they had that much more camber than the natural camber from just putting the lower springs, on the wheels just seemed to stick out a bit http://www.ft86club.com/forums/showthread.php?t=15097
I am just wondering if they wont fit at all or if they will just stick out? I really love the look of the D2Ex's but I am not ready to throw 1600 on decent coilovers
Thanks for being patient with a new car enthusiast
Old 02-05-2015, 08:20 PM   #2657
Slick
Slick's Avatar
Yep, the wheels will hit the spring perch of the struts. With a coilover, that perch is gone and the springs are much smaller, giving extra inside clearance.
Saw that thread and the natural camber from his 2" drop is probably around 2+ degrees. He has clearance inside, just not outside. And he was still running a 225 wide tire up front to avoid rubbing the outer fender. No ways would you fit a 265 up front with that combo.
They won't fit. If you were stock they might, but would stick out a shit-ton, and you'd have to run a skinny tire anyways. You could add a 5mm spacer and they "might" fit, but then, you'll have more issues with the fenders.
Your best bet for a wide wheel is a 18x9 +35. You can run this setup with springs and no one will notice the extra 1/2". And you could easily run a 245, even a 255/35 with the right camber.
Or buy coilovers.
Old 02-05-2015, 08:34 PM   #2658
SkyBRZ
SkyBRZ's Avatar
Or buy coilovers.
Thanks yea I honestly don't really want to run the 18x9.5s but the only problem is those wheels only come in 18x9.5 or 18x10 is why i was asking..
So for the 5mm spacers are you referring to the stock springs or with the tein springs? and if so is the problem with clearing the fenders when turning the wheels?
Old 02-05-2015, 09:15 PM   #2659
SkyBRZ
SkyBRZ's Avatar
Alright this is my last post! I apologize, so i found a set of the wheels 18x8 +48mm 56.1 so with my S-Techs these should fit with no problems correct? Any tire size suggestions?
Old 02-05-2015, 09:36 PM   #2660
rixter145
Sleep Chomper
rixter145's Avatar
Hello everyone, I am looking to get a new set of wheels & tires (choices tbd later, right now I'm looking for measurements and sizing) for my boosted set up (going for ~300 whp & lowered 1")
My main use cases are:
Streets & AutoX
Requirements:
lighter wheels - function > form, though looking good is a definite plus.
Perfect Flush
Square Set up
My option:
Looking at 18x8.5 with 245/40, offset: +42 Front, +32 Rear, no Camber
Taken this from the Wheels Directory post Darren started but I am wondering if the offsets are a bit too much for the front?
Also I am wondering if that tire is too skinny for the power I am putting down. I don't want to kill gas mileage as well.
Any sort of suggestions?
rixter145 is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
