#28715 |
Drives: 2013 Asphalt Fr-S
No worries. I'll put fuel in the vehicle tonight
#28716 | ||
The header alone doesn't make a massive difference without VVT changes a proper tune though. The tune does the biggest difference as for a single mod aspect.
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread |
#28717 |
You ought to get that sucker tuned! :P
#28718 | |
That's sort of the lines I was thinking of. So last night, I did the first 3rd gear pull since tune while getting onto the free way. Shifted early first to second, and second to thrid (Both shifts around 3k), then full throttled to get a pull. I had my OFT with me, plugged in, but forgot to hit record on all pulls. Heard what I thought was a rattle coming from engine bay, but it happened so quick, I thought I was hearing things. Did a second pull and sure enough, from 3,800-4500 ish I am hearing something. Rolled down the window but can't hear it that way, so I drove home. I guess it's possible it's knock, but I woke up late for work today and barely got to my job on time. I'll have to record tonight but I heard it again this morning on "standard driving" down the city streets. It's specific to that RPM band and happens no matter how fast or slow I am accellerating or what gear I am in. (since it's low RPM, I tested it in 1,2, & 3) I am a little nervous it may be knock, but the only other time I remember hearing a noise which sounded similar was on a turbo tC with open dump. almost like you can hear the exhaust pouring out of the overpipe (Which does have a bad gasket. I have the parts on me. Just need to do the work.)
#28719 |
AZ FRS 86
Sent from ARIZONA86 HQ
@AZFRS86
#28720 | |
#28721 |
refreshing to hear. Will create some logs tonight, upload them to Datazap, and then go from there. Gasket will be changed out over the weekend, hopefully.
#28722 | |
the oft tunes rely on learning (which Is fine) but your maf scale could be off which can throw a few off bits into the tune. If your intake calibration is off your target afr / ignition base is going to shift.
#28723 | |
I figured I would log IAM, RPM, Throttle, FBKC, FLKC, Wideband AFR, Ign. Timing, STFT, and LTFT. (I'll let it graph the AFR, RPM, IAM, and FLKC.
#28724 |
Toss in ignition timing, engine load, and maf v too!
#28725 |
AZ FRS 86
@AZFRS86
#28726 |
Weendog
Drives: 2014 Scion FR-S
My new wheel I'm looking for is the Rota RKR or XXR 537 or anything similar. I can't find anything in our bolt pattern and 16" diameter. Anybody know of any similar wheels that would be a match for what I'm looking for? 4 bolt patterns have all the nice 16" wheels.
#28727 |
Weendog
Hmm, what do you guys think about these Enkei Compe's? 16x8, 25mm offset.
#28728 |
Drives: 2013 FR-S/C
| Tags |
| arizona, fr-s, mesa, phoenix, scion, tucson, we need a subforum |
| Arizona Bill 'could' criminalize Internet Trolls | Giccin | Off-Topic Lounge [WARNING: NO POLITICS] | 18 | 12-30-2013 02:54 PM |
| Accessories page for Canadian BRZ owners | percyng | CANADA | 1 | 06-15-2012 07:27 PM |
| FR-S\BRZ owners give thumbs up to AE86 owners | Oriental Life | Scion FR-S / Toyota 86 GT86 General Forum | 19 | 06-13-2012 03:12 AM |
| Home Sweet Home, it made it today. Delivery party 5/11 though.. | MarkRacerX | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 05-14-2012 03:24 PM |
