Old 02-04-2015, 11:49 AM   #15
Gunman
Drives: 2019 Mazda Miata RF
TSB worked for me, they haven't froze since.
The Following 2 Users Say Thank You to Gunman For This Useful Post:
Tcoat (02-04-2015), Ultramaroon (02-04-2015)
Old 02-04-2015, 12:28 PM   #16
AznBRZer
Drives: 16 CBS WRX Limited
Last winter, I had a problem on my driver-side window after getting a new weather strip, but haven't had a problem this winter after I got my passenger-side fixed. I guess it really takes the right circumstances for them to stick, but it's definitely better now than having to reset them all the time last year.
AznBRZer is offline   Reply With Quote
Old 02-04-2015, 01:19 PM   #17
eguzman6
eguzman6's Avatar
Drives: FRS 10 Series
Thanks all for the responses. But don't need reprograming. I was just trying to make sure im not breaking anything by just leaving it alone.
eguzman6 is offline   Reply With Quote
Old 02-04-2015, 01:21 PM   #18
eguzman6
eguzman6's Avatar
Originally Posted by D_Thissen View Post
I find if you run the corner of a credit card between the bottom of the window and the rubber (before opening the door) the window usually doesn't get stuck or make scary noises. I start the back of the door and work my way to the mirror.
I read that before on the forum and tried it but sometimes it doesn't work. I'm just afraid to break the motor or something from being stuck. But the thing is that there is no snow or ice on the window so don't understand why it does it.
Old 02-04-2015, 01:22 PM   #19
eguzman6
eguzman6's Avatar
Originally Posted by Chanpion View Post
If your window light is flashing, it's needs reprogramming. Reprogramming your window directions are in your manual. Look in the appendix for the page. I can't remember what it is specifically.
And ^^^ hahaha! I know exactly how you feel, I usually can't brush all the snow off the seats either but it's usually cold enough that I can sit on it a not have it melt before I get to work.
Thanks but no flashing lights. But now I know where to find the directions incase it does
Old 02-04-2015, 01:29 PM   #20
It is actually freezing at the guides down inside the door. The flashings let to much water in and it freezes there.
You won't hurt the motor by trying. That is exactly why the system cuts out and needs to be reset. The cut out isn't an error it is a protective device for the motor and mech.
Old 02-04-2015, 03:55 PM   #21
eguzman6
eguzman6's Avatar
Thanks that was what I was thinking too but when I did a quick Google search I found nothing
Window Shatter / Fracture - passenger small triangular window btune Issues | Warranty | Recalls / TSB 5 12-25-2016 02:14 PM
Window Scratched by Window Motor / Lifter? tomkozski Issues | Warranty | Recalls / TSB 22 05-31-2014 07:25 AM
DIY - Cancel auto up/down window for winter Rayme DIY (Do-It-Yourself) Guides 28 04-18-2014 11:23 PM
Any resolution to the window not closing all the way in winter? NOHOME Issues | Warranty | Recalls / TSB 4 11-29-2013 04:47 PM
Passenger window stuck. Marshman Issues | Warranty | Recalls / TSB 6 03-08-2013 07:39 AM
