Old 01-30-2015, 06:57 PM   #15
Poodles
Drives: 2015 Series.Blue
Originally Posted by Chrono View Post
I'm sorry, but ignore everything else in this thread and get a K&N air filter. Problem solved.
Enjoying our placebo pill are we?
The Following 3 Users Say Thank You to Poodles For This Useful Post:
funwheeldrive (08-24-2015), Rota (08-25-2015), strat61caster (02-02-2015)
Old 01-30-2015, 09:30 PM   #16
Burrcold
Drives: Subaru BRZ Limited
The Following 2 Users Say Thank You to Burrcold For This Useful Post:
raven1231 (08-25-2015), strat61caster (02-02-2015)
Old 01-30-2015, 09:55 PM   #17
xia
Drives: 1995 Supra TT & 2013 FRS
It's a slow car, what'd you expect?
xia is offline   Reply With Quote
The Following 2 Users Say Thank You to xia For This Useful Post:
Choco (02-02-2015), raven1231 (08-25-2015)
Old 01-30-2015, 10:20 PM   #18
Mim
Mim's Avatar
Drives: MY11 Maxima 350st, MY15 BRZ
If not wanting to effect warranty then lighter wheels / tires (to reduce un-sprung weight), drop in air filter, aluminium drive shaft and change your diff ratio. OFT or a custom tune would also do wonders, but impact on warranty. All said and done though mine is pretty good and seems to be improving as I wind on the km.
MY15 CWP A/T BRZ | Leather heated seats | STI CAI filter, A/T leather shifter, strut brace, V-brace, draw stiffener, battery tie down, Radiator cap, Oil cap, push start button | TRD door stabilizer | YoSpeed STI console garnish | Pioneer AVIC-F70DAB + Rev-camera, TS-WX710A sub | JL speakers, Amp | TOMS' Clear Brake Lights | Cusco 4.556 FD | Driveshaft Shop aluminum shaft | Tein FlexZ, EDFC AP+GPS | Crawford BPB
Mim is offline   Reply With Quote
Old 01-30-2015, 11:17 PM   #19
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
throttle controller http://www.avoturboworld.com/avoshop...2007-p-58.html
The Following User Says Thank You to Kiske For This Useful Post:
Gords_zenith (07-30-2015)
Old 01-31-2015, 12:06 PM   #20
Jfheisenberg
Jfheisenberg's Avatar
Drives: 2015 BRZ Series Blue WRB
It seems pretty responsive to me.. I have like two days driving the brz and it does not feel slow like many people claims to be. it pulls hard and sound sweet even as stock!
Jfheisenberg is offline   Reply With Quote
The Following User Says Thank You to Jfheisenberg For This Useful Post:
steel86gt (10-05-2020)
Old 01-31-2015, 12:14 PM   #21
Speed2th
I love my series blue brz
Speed2th's Avatar
Drives: 2010 335d
i think my BRZ low end is pretty responsive and that is what sold me the car. 3k-5k felt pretty pathetic however and that is the famous power dip
Speed2th is offline   Reply With Quote
Old 02-02-2015, 02:19 PM   #22
kilohercas
Drives: Subaru BRZ (soon?)
It is nearly impossible to get any dip in power/rpm (or get negative number from derivative of power curve) .
Torque is what is dipping, and it only ~15lbf*ft, that is 10%, anyway, in few mouths i should get BRZ and experience terror myself of that famous dip
kilohercas is offline   Reply With Quote
Old 02-02-2015, 02:35 PM   #23
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
What you could buy that would actually make a difference. All of these combined would basically make a NA short track monster for sure.
1. A tune
2. High quality headers
3. light weight fly wheel
4. Light wheels
5. Light weight drive shaft
6. New rear dif (to shorten the gearing)
7. Throttle controller
8. Light weight crank pulley
9. High quality air filter
10. Clutch adjustment on the manual (feels nice, it helps)
11. larger downpipe/mid pipe (the back end really is all for sound)
Old 02-02-2015, 02:41 PM   #24
stugray
Drives: 2013 GBS BRZ Limited
Umm, HP = (Torque X RPM)/5252
So saying the HP does not drop, but the torque does is nonsense.
It's like those people who say "It's not the volts that gets ya, its the AMPS".
Old 02-02-2015, 03:26 PM   #25
kilohercas
Torque is dipping 10%, so power should dip too, but it stays nearly flat.
And yes, only current is killing. two different persons can have different effect on same voltage, but will have same exact effect on same current, due to variations in resistance.
Old 02-02-2015, 03:38 PM   #26
Braces
Braces's Avatar
Drives: 17 Alfa Romeo 4C
Try sprintboostersales.com. Not sure they have an application for the twins. Pretty popular with the R8 crowd.
Braces is offline   Reply With Quote
Old 02-02-2015, 05:22 PM   #27
stugray
It does not work that way.
If torque dips, so does power (UNLESS you have a corresponding increase in RPM).
So IF you change the Torque at a given RPM, you also change the HP.
You cannot change one without the other (at a given RPM).
But since we are not talking about one point in time (fixed RPM), then saying "dip in torque" is ambiguous.
Is it a "reduction of torque at a given RPM"
or is it "lower torque through the same RPM range"?
or "Torque decreased as RPM increased" which might be a constant HP
And as far as the current vs voltage:
Current differs from voltage by a constant R.
So current and voltage "track together". (they differ by a constant)
So I can argue that since the Voltage DRIVES the current, it is the voltage that kills you.
OR I can argue that Current is DEPENDENT on Voltage and Resistance So the current kills you.
OR I can say that it is your body's resistance that kills you because IT is what lets the current flow.
See all three comparisons are meaningless.
In truth, it is the POWER that is dissipated across the resistance in your body that kills you.
The Following User Says Thank You to stugray For This Useful Post:
akahenry (03-04-2015)
Old 02-05-2015, 01:06 PM   #28
MGPAX
Still 17!
MGPAX's Avatar
Drives: 2014 Silver BRZ Limited
...."It's the watts!" LOL
MGPAX is offline   Reply With Quote
Throttle Response CamryDS Northern California 27 03-31-2015 03:35 AM
poor throttle response Djen Engine, Exhaust, Transmission 21 06-14-2014 01:22 AM
poor throttle response Djen Electronics | Audio | NAV | Infotainment 5 06-18-2013 07:31 PM
Does the throttle response improve? pr086 Scion FR-S / Toyota 86 GT86 General Forum 36 12-01-2012 01:06 PM
How's the throttle response? SFTiofoso Scion FR-S / Toyota 86 GT86 General Forum 9 08-14-2012 11:50 AM
