Old 02-02-2015, 12:56 AM   #281
Skorov
Skorov's Avatar
Drives: 86 GTS White
yes stock front 02 sensor is not wideband so wont accuratly measure rich afr and its scale finishes at 12.1 stock scale.
you could put a proper wideband in second o2 position.
I do have an AEM failsafe gauge waiting to be installed. This would be a good excuse to get off my ass and do it.
Alternatively, what if I were to temporarily flash the stock fuel map and force open the wastegate? Take logs with 0 boost and then revert back after scaling is finished. Any risks doing that?
Skorov is offline   Reply With Quote
Old 02-02-2015, 02:04 AM   #282
steve99
Drives: FT86
i dont have experience with FI so i dont know sorry
Old 02-02-2015, 02:43 AM   #283
Kodename47
Kodename47's Avatar
Drives: UK GT86
@Skorov why do you want to scale the MAF? If the car is running fine then there isn't really any need to.
.: Stealth 86 :.
Kodename 47 DJ:
Old 02-02-2015, 03:31 AM   #284
Skorov
Skorov's Avatar
I installed the perrin 3" intake. When I flashed the provided scale, I got quite a large LTFT (15%). So I figured I better rescale the whole thing.
Old 02-02-2015, 03:40 AM   #285
D-VO
Drives: Whiteout FR-S, Evo 8 RS
there is a table in ecu flash called "front oxygen sensor scaling" that you can adjust to come pretty close to the wideband sensor. The thing is you need to log a known good wideband and the cars O2 at the same time.
D-VO is offline   Reply With Quote
Old 02-02-2015, 01:09 PM   #286
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
Kudos @steve99, @Kodename47, @vgi - will give this all a try come late spring. Thanks for adding to the community!
1Cor10:23 is offline   Reply With Quote
Old 02-10-2015, 09:21 PM   #287
kodyo
Drives: Scion FR-S
Originally Posted by vgi View Post
next time you should tag me so i'd get a notification
sorry, mate, there was a bug which displayed a wrong column name for the error. What you actually did not specified is the "CL/OL Status". It's been fixed and will be in the next release.
Still getting same error even with the correct CL/OL Status logged and attributed.
Log attached, any ideas?
kodyo is offline   Reply With Quote
Old 02-11-2015, 11:28 PM   #288
vgi
Drives: frs
https://www.dropbox.com/s/vkp0dy8ea9...%20V2.csv?dl=0
I just loaded your file into 1.6.3 open loop and closed loop, no errors. I left everything at default except the CL/OL Status which I set to 2. See the pics. (the POL fueling table and MAF scaling are obviously from some of my tunes I opened)
vgi is offline   Reply With Quote
The Following User Says Thank You to vgi For This Useful Post:
kodyo (02-11-2015)
Old 02-11-2015, 11:44 PM   #289
kodyo
Drives: Scion FR-S
OK, awesome, thank you so much! I'm going to try again tomorrow to see if I can get it working correctly. Thanks for checking!
Old 02-24-2015, 02:29 AM   #290
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
If we're scaling to use E85, should we do it on straight 98, or 44/6L 98/E85 for 10% E like US 91 fuels?
For straight 98 it makes sense to scale on straight 98.
Old 02-24-2015, 02:39 AM   #291
steve99
Drives: FT86
If you have guaranteed E content E85 like united then you can just scale using that fuel if thats all your going to run.
The oft guys probably scaled using something like E70 content then jacked the Open loop scetion of the scale about 5% or so to make sure it always ran on the rich side even if E% went high.
Ig you going to use E flex then your going to have to compromise and scale on the average e% and see how it copes with the variance then maybe jack the ol scale a bit if you find it runs lean on increased e%. Its always going to be a compromise without a flex fuel setup. Foortunatly ethanol is a forgiving fuel on NA motors.
Old 04-09-2015, 09:48 AM   #292
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Hey all, I did some logging with the OTS Stage 2 UEL tune from OFT, and I have a bit of a dip in AFR as seen here:
I did some maf scaling and it pulled quite a bit of fuel in the dip, but now I have a touch of tip-in knock correction (-0.69 IIRC) when going WOT.
I played around with the EL comp table (lowered the values in the table in the rich spot, they were at 3.1) because I figured that would lean it out, but it seemed to have almost no effect.
What's the best way to get rid of the rich spot without making a big sag in the maf scaling?
Old 04-09-2015, 11:23 AM   #293
Kodename47
Kodename47's Avatar
Drives: UK GT86
Engine Load Comp only works in closed loop AFAIK. The best way to lose the rich spot is to adjust the actual open loop fuel table
.: Stealth 86 :.
Kodename 47 DJ:
DocWalt (04-09-2015)
Old 04-09-2015, 12:35 PM   #294
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Bah. I was afraid you'd say that. Shouldn't be too hard, I know how far it's off and I can remove the dip from my maf scaling.
I have to admit, this is all a bit overwhelming coming from Megasquirt using one VE table and one IGN table, heh.
AFR in Closed Loop Toyota John Software Tuning 39 07-07-2019 08:26 AM
BRZedit Fuel Trims, Closed to Open loop transiton mad_sb Engine, Exhaust, Transmission 32 08-06-2015 03:14 AM
Notes on injector / maf scalining using full time open loop mad_sb Software Tuning 40 03-03-2014 05:49 PM
Screencast: closed loop boost control with RaceRom jamesm Software Tuning 2 02-10-2014 02:23 PM
Screencast: experimenting with full-time closed loop fueling jamesm Software Tuning 2 12-27-2013 10:19 AM
