#141 |
Drives: 86 & GRB
How about use portable/detachable torque wrench that can bolt on hollow type head and torque to 41 ft-lb directly.
#142 |
Overthinking it
Drives: BRZ in CS
Note. The stock front springs come off fairly easily without a spring compressor. But if you are putting the stock springs back on, you will need a spring compressor.
| The Following User Says Thank You to mla163 For This Useful Post: | immortal_suby (12-10-2019) |
#143 |
Overthinking it
Drives: BRZ in CS
Great write up @DarrenDriven. With 7 pages of follow up after the initial DIY, it would be helpful to amend the original post to include some of the more recent info such as:
- Special tools or procedures to use when taking off the strut top nut to avoid spinning the strut shaft and damaging the shocks - At the rear, loosening the hub bolt and unbolting the swaybar can help to make more room for the rear shock. - Unclipping the ABS clips - see post 136 - The proper method for taking off the front swaybar to endlink bolt. This bolt will spin endlessly unless you use an allen wrench and a box wrench since it is in a ball joint. |
#144 |
Drives: AE86 & GT86
On step #47 there's two rubber (one on each side) that you slide the bolt in. Does it matter if one of the rubber is out of place? Because when I tried to push the LCA in place it sort of pushed the rubber and pushed it out of place. Is it fine to just put it back like that or should I try and pull the rubber back in place? Any help would be helpful
#145 | |
Road-hole
Drives: 2013 Whiteout FR-S
Also...
Jaden |
| The Following User Says Thank You to Jaden For This Useful Post: | DarrenDriven (12-08-2014) |
#146 | |
Road-hole
I found...
Jaden Last edited by Jaden; 12-08-2014 at 03:17 PM. |
#147 | |
NW Region Moderator
Drives: FR-S No More
I have never had a problem getting the rear strut in and out with the swaybar left bolted in. Is this really an issue? I did update the photo for the lower ABS clip and moved the arrow to show the proper screwdriver placement. Again, since I use an impact wrench to remove the front swaybar nut, it hasn't been an issue. Sometimes I squirt a little WD40 on the threads first, if there is any rust forming, but I haven't met a nut that didn't spin off in a few seconds. If you can recommend the proper hand tool technique then I can include that in the writeup.
#148 |
Drives: 2014 Scion FRS 10 Series
Thanks
Thanks for the great write up, it helped out tons, the new springs are on and looking so lovely
2014 Sc10n FRS 10-Series #655 of 2500 ![]() |
| The Following User Says Thank You to MasterMech77 For This Useful Post: | DarrenDriven (01-04-2015) |
#149 |
I installed springs today. No need to remove the struts from the car to do this. Just unbolt the top hat bolts using a pass through and allen wrench combo, undo the sway bar in the front and the LCA bolts on the rears. The struts will lower just enough so you can rotate them out enough to put the new springs in.
For the rears, I used the jack the car comes with to lift the LCAs and guide the strut back into the hole. Start to finish took about 2 hours for all four corners double checking everything. |
| The Following User Says Thank You to buckseventysix For This Useful Post: | exE36M3 (04-26-2015) |
#150 |
Drives: 2013 SWP BRZ
So I tried removing the strut top nut but found it impossible using the pass through socket/wrench and 6mm allen key. Has anyone else found it very difficult to remove and if so what did you to circumvent this?
"Don't be a don'ter, do be a doer" - Johnny Wu
#151 | |
Drives: 2017 Cayman S
Not to be insulting, but make sure you are doing lefty loosey. ![]() I replaced my springs about 3 weeks ago and found all the nuts to be easy except the nut that anchored brake line to the front strut. I didn't expect that.
… and loving it! Maxwell Smart
. Gone but not forgotten 2014 BRZ Limited - 2013 VW Golf R - 2010 Forester XT - 2006 Mazda 3 GT |
| The Following User Says Thank You to Agent 86 For This Useful Post: | ap5512 (02-10-2015) |
#153 | |
#154 |
One of the top nuts I took off required quite a bit of muscle.
| Replacing the Scion FR-S seats | bloomy116 | Scion FR-S / Toyota 86 GT86 General Forum | 36 | 11-09-2012 12:41 PM |
| Installing TRD Parts / Locating a good shop | Re~Mix | Engine, Exhaust, Transmission | 9 | 06-12-2012 12:05 PM |
| T1R Coil-over suspension | AJ PwR | Brakes, Suspension, Chassis | 33 | 05-29-2012 10:07 PM |
| Handling: Camber Attainable with Struts. Your Experiences? | skeeler | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 31 | 11-09-2011 04:07 PM |
