Old 02-01-2015, 03:19 AM   #15
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Most likely an issue with the BCM.
I ran into on my previous car...my lights stayed on..all my dash lights stayed on, my keys didn't work, couldn't lock the doors except physically, trunk wouldn't open at all.
Technicians did a PIN test on the vehicle.
Took 2 days to diagnose it...it was an issue with the BCM. Flashed BCM and tada...fixed.
To my understanding:
ECU - controls all engine related tasks (EX: A/F Ratio)
BCM - controls all vehicle body related tasks
N1rve
The Following User Says Thank You to N1rve For This Useful Post:
Tcoat (02-01-2015)
Old 02-01-2015, 07:29 AM   #16
paulca
Drives: Toyota GT86 Coupe Red (UK)
Originally Posted by HotLavaChick View Post
it's called spelling LEARN IT bitch
I'm confused. It was spelt correctly. You might want to learn punctuation and capitalisation.
You might also want to do a course or two in vehicle electrics before you fry another one retro fitting dodgy electrics and fecking it up.
The lesson, BTW, is: If you going to feck about with your car do it when you are at home! Or better yet, don't do it if you don't understand it, get someone that knows what they are doing to do it.
Trunk = Boot | Hood = Bonnet | Sidewalk = Pavement | Transmission = Gearbox | Stick/shifter = Gear knob/stick | E-brake = handbrake | Windshield = Windscreen | Turn signal = Indicator
paulca is offline   Reply With Quote
Old 02-01-2015, 07:57 AM   #17
Sarlacc
/dev/null
Sarlacc's Avatar
Drives: Uphill
Sounds really weird. Let us know what the dealership says about it!
Old 02-01-2015, 08:36 AM   #18
HeadBanger
HeadBanger's Avatar
Drives: '14 Subaru BRZ
It's called grammar. Learn it, bitch.
I don't understand why you towed the vehicle though. why not just drive it? Unless it was night which I don't think you specified.
Life's too short to drive a boring car
HeadBanger is offline   Reply With Quote
Old 02-01-2015, 08:37 AM   #19
ckkone
ckkone's Avatar
Drives: 2013 BRZ Limited
But those LED turns will look really cool, LOL.
ckkone is offline   Reply With Quote
Old 02-01-2015, 12:25 PM   #20
HotLavaChick
HotLavaChick's Avatar
Drives: '15 Hot Lava FRS
It's an auto it wouldn't go into gear. And it was at night my headlights won't turn--
HotLavaChick is offline   Reply With Quote
Old 02-01-2015, 01:15 PM   #21
HeadBanger
HeadBanger's Avatar
The best part of having a BRZ is the DRLs are pretty much bright enough lol
The Following User Says Thank You to HeadBanger For This Useful Post:
Choco (02-01-2015)
Old 02-01-2015, 02:54 PM   #22
cjd
cjd's Avatar
Drives: 2017 BRZ
Agree. They seem very sensitive to shorts and other unexpected electrical issues (not sure if surge would also do it, probably though.)
I had a battery short out internally on a previous car, dealer insisted on trying to jump it. All the internal electronics were on the fritz, flashing like crazy and they wanted me to just go home! I refused, pointed out the issue, so they said "oh, well, let's check the battery." It was bad... Two weeks later my horn decided to start randomly honking. Right in the middle of Chicago rush-hour traffic (i.e. no one was moving.) BCM had to be replaced.
The Following User Says Thank You to cjd For This Useful Post:
HotLavaChick (02-02-2015)
Old 02-01-2015, 02:58 PM   #23
Koa
"spelled"
The Following 2 Users Say Thank You to Koa For This Useful Post:
Caspeed (02-19-2015), HotLavaChick (02-02-2015)
Old 02-01-2015, 03:00 PM   #24
FlamingRectumSyndrome
Shriveled Old Member
FlamingRectumSyndrome's Avatar
Drives: 14 Hot Lava FR-S
Originally Posted by Koa View Post
"spelled"
Depends on which side of the Atlantic you are. Same goes for "capitalisation" vs. "capitalization".
FlamingRectumSyndrome is offline   Reply With Quote
The Following User Says Thank You to FlamingRectumSyndrome For This Useful Post:
Koa (02-01-2015)
Old 02-01-2015, 03:00 PM   #25
babydriver
Hit the road and I'm gone
babydriver's Avatar
"spelled"
Not if you're English. Check out the OED; either spelling is acceptable.
Slip, slidin' away.
The Following User Says Thank You to babydriver For This Useful Post:
Koa (02-01-2015)
Old 02-01-2015, 03:05 PM   #26
stugray
Drives: 2013 GBS BRZ Limited
Is there not a lesson here somewhere?
I think the lesson he was referring to is :
Dont fuck with the electrical system in a modern car because all that shit is tied together.
Even some light modules and door switches are tied into the OBD computer system.
And if you want help, learn some manners.
I would have gladly helped you out, but based on your comments I think you're just a *&^%&.
The Following 6 Users Say Thank You to stugray For This Useful Post:
burnt toast (02-20-2015), DarkPhoenix (03-31-2016), FRSBRZGT86FAN (02-19-2015), Manic (02-02-2015), Pete156 (02-02-2015), TJ3000 (02-03-2015)
Old 02-01-2015, 03:13 PM   #27
Koa
Spelt is a type of wheat though..
Old 02-01-2015, 10:11 PM   #28
HeadBanger
HeadBanger's Avatar
And scat is a type of music
Turn signal lights whip Cosmetic Modification (Interior/Exterior/Lighting) 13 02-26-2015 10:45 PM
Is there another way to keep the turn signal lights on? DeadStar7 Scion FR-S / Toyota 86 GT86 General Forum 10 06-29-2014 10:43 PM
OEM fog lights to turn on with parking lights subiestyle Cosmetic Modification (Interior/Exterior/Lighting) 7 02-27-2014 06:41 AM
WTB FR-S Turn Signal Lights retrosmiths Want-To-Buy Requests 2 01-08-2014 02:13 PM
Turn signal lights Brzer Cosmetic Modification (Interior/Exterior/Lighting) 9 10-18-2012 01:36 PM
