Old 01-24-2015, 01:01 PM   #1
radroach
Drives: car
Should I replace my oem mounts?
I feel a bit of slack in the drivetrain and am wondering if it's the mounts or if it's just the old clutch. I'm planning on replacing my clutch soon, have ordered a new clutch last week. Thinking about ordering some fresh OEM mounts. Would also probably do a spark plug job at the same time too. Tell me if it's a good idea to change the mounts now or if that is unnecessary right now on my 2-yr, 50k mile BRZ.
Old 01-24-2015, 01:18 PM   #2
blackhawkdown
blackhawkdown's Avatar
Drives: 2012 WRX, 2003 RSX Type S
why replace them with oem? if your gonna replace them, replace them with harder bushings.
Originally Posted by fatoni View Post
saying they wanted to add weight to improve handling is like saying people wear condoms to improve sex.
blackhawkdown is offline   Reply With Quote
Old 01-24-2015, 01:56 PM   #3
radroach
Drives: car
Because that's not my goal. I want to return to how it was new, OEM. Or if its really necessary or not. Not sure how much life I can expect out of the factory mounts or if that's anything I should be concerned with at this stage.
Old 01-24-2015, 02:40 PM   #4
Koa
50k miles isn't bad for OEM mounts nowadays.. those depending on driving conditions will deteriorating in about double that time, if that, depending on the design of the mount and stressed onto that part
Old 01-24-2015, 02:49 PM   #5
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Did you inspect the mounts? I've not heard of any failing yet.
The Following User Says Thank You to EAGLE5 For This Useful Post:
AZP Installs (01-28-2015)
Old 01-24-2015, 08:28 PM   #6
radroach
Drives: car
Thanks all, I guess the drivetrain lash I feel is just stemming from the old clutch. Just needed some opinions on how these mounts should hold up.
May wait until the 100k mile mark to do them then.
Old 01-25-2015, 09:11 PM   #7
Ashikabi
Ashikabi's Avatar
I doubt your mounts could be bad in just a few years. I felt mine was kinda sloppy(first rear wheel drive though) but when I put in a one piece aluminum driveshaft it cleaned that right up. Very happy with how it feels now
Old 01-28-2015, 07:04 PM   #8
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
A few notes...
The slop you feel is likely from the rear diffy carrier bushings. Whiteline sells inserts that can firm that up nicely.
On the one piece drive shaft, we've seen several cars both WRX/STi and BRZs that have had rear trans bearing issues from the 1 piece driveshafts since they put extra stress on that bearing in the tailshaft of the trans.
-Mike Paisan
Maintaining, Modifying and Educating TriState Enthusiasts since 2001.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
Old 01-28-2015, 07:07 PM   #9
EAGLE5
Dismember
EAGLE5's Avatar
Does lifting the rear diff as some have done with a modified rear subframe help reduce that strain? Would stiffer bushings affect that strain?
Originally Posted by AZP Installs View Post
A few notes...
-Mike Paisan
Old 01-28-2015, 07:10 PM   #10
AZP Installs
I'm not sure that lifting it would help a lot. The issue lies in that the trans bearing was designed not as a weight bearing item because of the 2-piece nature of the OEM ones. So it doesn't fail immediately, but rather over time the extra strain slowly wears it down. Perhaps the failures are from folks who are drag racing them as well which obviously will put even more strain on them.
-Mike Paisan
Old 01-28-2015, 07:19 PM   #11
EAGLE5
Dismember
EAGLE5's Avatar
Well, that sucks.
-Mike Paisan
Better Mic to replace OEM Mic in BRZ / FRS ??? Zgrinch Electronics | Audio | NAV | Infotainment 42 02-06-2015 01:19 AM
Worth it to replace or just keep it as is? x1UP BRZ First-Gen (2012+) — General Topics 15 12-04-2014 03:58 PM
Window weld motor mounts (poor man's solid mounts) unsurety Engine, Exhaust, Transmission 8 06-05-2014 02:36 AM
Anyone replace rotors yet? NickFRS Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 01-16-2013 02:38 PM
Looking to replace my sedan carbonBLUE Other Vehicles & General Automotive Discussions 5 01-11-2013 08:41 PM
