Old 05-13-2012, 10:48 PM   #43
st162celica
Drives: 86 GTS Manual - Tornado Grey
The space saver spare reminds me of this video where they put 4 of them on a c63 amg. Drift king .
st162celica is offline   Reply With Quote
Old 05-13-2012, 10:48 PM   #44
st162celica
Forgot the link
http://www.motorauthority.com/news/1...ce-saver-tires
The Following User Says Thank You to st162celica For This Useful Post:
iBRZ (11-24-2012)
Old 05-13-2012, 10:50 PM   #45
Alias
Resident Genius
Alias's Avatar
Drives: Subaru Legacy GT, 1990 Geo Prizm
Personally given a choice I would not only keep the spare I'd prefer a full sized instead of the donut.
Agreed, having a decent jack and tire iron would be nice too, I glanced at the provided ones and... they'll do in a pinch but I wouldn't mind better quality equipment.
I think it's hilarious that people are talking about the weight savings of removing somethings as useful as a spare tire; yet on all the threads where people have talked about height/weight there are TONS of people 200+lbs
Alias is offline   Reply With Quote
Old 05-13-2012, 11:42 PM   #46
bestwheelbase
Drives: 1985 P-Type
Yeah, it's funny people want to remove the useful spare tire when they're carrying one around their belly!
I can say this, I'm big-boned.
Old 05-14-2012, 03:26 AM   #47
fistpoint
Drives: Supercharged Golf Cart
I think you're seriously over estimating how though tires are. Yeah they're a lot better then they used to be, but it still happens. Between my wife and I we have a flat on one of our cars about once a year, and we only drive about 6K miles each. In my 17 years of driving I've never had a punctured radiator or oil pan. (I did have a dented oil pan from hitting some critter)
While I don't actually get a flat that requires needing a spare(never in 22 years), I have had nearly every single tire I own have a nail removed.
fistpoint is offline   Reply With Quote
Old 05-14-2012, 10:01 AM   #48
feedbag
Seasoned Spirit
Drives: 2013 DGM BRZ Premium
My favorites are the people saying that you're more likely to get a hole in your radiator / oil pan than a flat tire.
feedbag is offline   Reply With Quote
Old 05-14-2012, 10:14 AM   #49
StuttterButtter
Yes i have a stutter
StuttterButtter's Avatar
Drives: 94 Acura Integra
Ill be keeping in for my everyday driving around town. But will take it on the weekends when i go out with friends for a drive.
But since this is a RWD car would keeping the spare in = more grip for the rear tires? Or will it not even make a diffidence
StuttterButtter is offline   Reply With Quote
Old 05-15-2012, 01:55 PM   #50
bestwheelbase
Drives: 1985 P-Type
Just going to leave this here:
http://www.ft86club.com/forums/showthread.php?t=6282
If this had really been a flat tire, he would have made it all of a couple days before needing to use his spare. That's reason enough for me to keep it in the car.
Food for thought.
Old 05-15-2012, 01:59 PM   #51
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
- ~30lbs for free? Yes please! AAA if any issues arise.
chulooz is offline   Reply With Quote
Old 05-15-2012, 03:20 PM   #52
Just a thought but removing this significant amount of weight where it sits from the CG (out on the arm) you will negatively affect the balance and shift the distributiom more towards the front.
Passenger weight wouldn't have an offset impact since I suspect the CG is around the front seats somewhere.
The car's performance is not all about weight/horsepower, its about balance.
Old 05-15-2012, 03:38 PM   #53
chulooz
Registered you sir
chulooz's Avatar
Sorry, but I will never buy into this 'balance' argument for a spare tire... its ~30lbs you will not feel(not significant enough). It will not 'shift' distribution literally, only take away from the f/r split via subtraction.
*Theoretically* it will fudge the weight split (less than 1%?) but it will also make it faster, lighter, more fuel efficient and less tail happy... *theoretically*.
Also if it is still a concern a lightweight battery (or a month of exercise for some) will negate the *issue*.
If perfectly balanced split was a practical concern Id worry about the extra ~100lbs from an AT. :happy0180:
Old 05-15-2012, 03:55 PM   #54
DeeezNuuuts83
Drives: 2006 Evo IX SE
But if you really think that you won't "feel" the difference in weight distribution if you take out the spare tire, then you probably wouldn't notice any difference in acceleration or fuel economy either.
However, I'd still say that the "benefits" of removing the spare tire will be outweighed by the weight balance being slightly off. Sure, you may not start sliding around because of it, but just look at the difference when you relocate your car's battery to the trunk. Even though a battery is probably heavier than a spare tire, it's still something to think about. Just look at the Evo... the VIII and IX were roughly 59/41 or 60/40, whereas the X is something like 56/44 or 57/43. I'm sure that there were other things done, but I bet that the battery moving to the back played a big role.
DeeezNuuuts83 is offline   Reply With Quote
Old 05-15-2012, 04:01 PM   #55
I hear what you're saying but I really do believe it can make a difference.
I don't know the exact math since I do not know where the CG is but I'm assuming its somewhere around the space between the front seat passengers.
The AT is near CG and has less affect than something that is further out like a spare tire. It's a matter of how far from the CG you are on the "arm" of the lever.
Think of it like a lever similar to a see-saw. Remember how you can balance it by changing the length of the board from the fulcrum so the lighter person is further out on the board than the heavier one?
Also, you can put as much weight as you want on top of the fulcrum (CG) and it doesn't change the balance. That's why passenger weight will affect performance (HP) but will not affect balance.
Old 05-15-2012, 04:05 PM   #56
Bahraini86
Bahraini86's Avatar
Drives: Toyota GT86
Guys, u've been talking about the effect on CoG. But, are you sure that the vids of the JDM ones on track lapping or drifting been performed with the spare? Don't think so! I think the spare been added for legal commercial requirements
'73 240z Triple-Carbed '03 350z Supercharged (455whp) '09 135i Twin-Turbocharged (11.85@188km/hr)
Bahraini86 is offline   Reply With Quote
10.5" wide tire possible?!? Xiao Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 50 10-11-2015 11:00 AM
"back-seat-remove" option. Z_Rocks Scion FR-S / Toyota 86 GT86 General Forum 53 06-25-2013 04:24 AM
Plus 0 tire sizing Brzer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 01-30-2012 08:15 PM
Would you want a spare tire in your FR-S? iff2mastamatt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 120 01-12-2012 10:46 PM
NEW Bridgestone R10 Race DOT tire RRnold Other Vehicles & General Automotive Discussions 2 06-17-2011 05:58 PM
