Old 01-23-2015, 06:46 PM   #15
Akari
Drives: 2013 DGM BRZ
My guess would be you're feeling the rear differential at work. When you get on it hard while turning you can definitely start to feel it at work when you're at the edge of traction. It's much more apparent without traction and stability control on though.
This isn't going to affect the front wheels at all but it's easy to mistake it for something else if you're not used to a RWD car with limited slip.
Akari is offline   Reply With Quote
Old 01-23-2015, 09:04 PM   #16
nokia7190
Drives: Subaru BRZ limited WRB
1) check alignment. 2) check tires radial pull. torque steer happens on RWD -> hard accelerating car pull one side and gas off car pull the other side.
nokia7190 is offline   Reply With Quote
Old 01-23-2015, 10:45 PM   #17
babydriver
Hit the road and I'm gone
babydriver's Avatar
I'll admit that I now feel a bit embarassed. I checked the tires and found that the left front was three pounds lower in pressure than the other three tires. Obviously, the pull to the left was from this. I brought it up to the proper pressure and the problem vanished; the great handling that I have come to expect returned.
I forgot the first rule of solving a problem: check the simplest explanation first.
Slip, slidin' away.
The Following 3 Users Say Thank You to babydriver For This Useful Post:
Koa (01-23-2015), Tcoat (01-24-2015), Ultramaroon (01-24-2015)
Old 01-24-2015, 12:00 AM   #18
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
tire pressures, they get you every time.
The Following 3 Users Say Thank You to 7thgear For This Useful Post:
Cole (04-12-2016), meWant (01-24-2015), wparsons (01-25-2015)
Old 01-24-2015, 12:12 AM   #19
I still have summer air in mine and they seem fine.
Got one of these though just in case:
DAEMANO (01-24-2015), Drakiv (04-12-2016), go_a_way1 (04-13-2016)
Old 01-24-2015, 01:43 AM   #20
etc, etc... you get the idea.
Thanks, @DAEMANO.
DAEMANO (01-24-2015), go_a_way1 (04-13-2016)
Old 01-24-2015, 01:46 AM   #21
Thanks, @DAEMANO.
You mean you guys down there don't change your air????
Oh, wait, Washington State is ummmm ... nevermind!
go_a_way1 (04-13-2016), Ultramaroon (01-24-2015)
Old 01-24-2015, 04:20 AM   #22
meWant
Drives: '16 BRZ Limited
first the m4 at coffee and cars :P
now this twin
meWant is offline   Reply With Quote
The Following User Says Thank You to meWant For This Useful Post:
86kahl (05-20-2016)
Old 01-25-2015, 09:44 PM   #23
Ashikabi
Ashikabi's Avatar
Don't feel bad OP I wouldn't have guessed air pressure either
Old 01-26-2015, 05:53 PM   #24
coryandy
coryandy's Avatar
Drives: '14 SSM BRZ Premium
One of the great things about owning a car like this, is the ability to actually "feel" those subtle changes that one wouldn't notice in most other vehicles! Good catch on the tire pressure! Three cheers for Occam's razor!
"To be without silver is better than to be without honour." - Norse Proverb
coryandy is offline   Reply With Quote
The Following User Says Thank You to coryandy For This Useful Post:
Ultramaroon (01-26-2015)
Old 04-12-2016, 08:08 PM   #25
JFC
Drives: 2015 86, 2015 Evo X
Originally Posted by babydriver View Post
I have noticed that when I turn sharply to the right and punch it I feel something in the steering wheel that seems to be torque steer.
Im not suggesting your issues are the same as mine but i get the front pulling to the right on acceleration and it doesn't matter if im turning right, left or going straight. Under acc and anything above normal = pulling to the right, off gas change gears it straightens immediately.
Im in Aus so its right hand drive and looking around the internet the common theme i can see is if your rhd it will pull right, lhd it will pull left.
I am yet to try the vsc and traction settings to see if it changes anything, as i feel and as i mentioned the common theme leads me to believe its the elec steering setup.
JFC is offline   Reply With Quote
Old 04-12-2016, 09:05 PM   #26
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
OP's problem was an underinflated tire that has been fixed. What's your alignment settings? Cuz my car doesnt pull either way and I think I'm in the majority with that
Old 04-12-2016, 10:41 PM   #27
Tor
Tor's Avatar
Drives: Toyota GT86
My car pulls forward when I push the pedal. Should I have my alignment checked?
Tor is offline   Reply With Quote
The Following 2 Users Say Thank You to Tor For This Useful Post:
86kahl (05-20-2016), go_a_way1 (04-13-2016)
Old 04-12-2016, 10:47 PM   #28
Norville Rogers
Drives: Subaru BRZ
Yes if it's the brake pedal.
Norville Rogers is offline   Reply With Quote
The Following User Says Thank You to Norville Rogers For This Useful Post:
wparsons (05-19-2016)
Memory Steer Issue AxisPower Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 01-11-2017 01:29 AM
Enkei 17x8 RPF1 Gold with Hankook Ventus R-S3, Torque Steer?! issue solved enginrd Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 11-08-2014 01:00 PM
My review of the FRS (RW Steer discussion) AaronCompNetSys Scion FR-S / Toyota 86 GT86 General Forum 86 05-10-2013 09:07 PM
TC turning back on after turning it off Xdragonxb0i Issues | Warranty | Recalls / TSB 2 02-01-2013 04:19 PM
BeSpoke steer anybody to BRZ? trackmagic Electronics | Audio | NAV | Infotainment 7 05-21-2012 12:54 AM
