Old 01-23-2015, 11:04 AM   #1
babydriver
Hit the road and I'm gone
babydriver's Avatar
Anyone else have torque steer while turning right?
I have noticed that when I turn sharply to the right and punch it I feel something in the steering wheel that seems to be torque steer. It doesn't seem to happen when I turn left. Since the car is kind of low in the torque department, I am wondering if this is a sign of a problem.
I had the alignment checked about a month ago and it was well within specs.
Has anyone else experienced this?
Slip, slidin' away.
Old 01-23-2015, 11:15 AM   #2
Jesse36m3
Jesse36m3's Avatar
Drives: JDL Turbo BRZ
err torque steer is only applicable to fwd platforms. It can still happen in the sense .. but you won't get any feedback from the rear wheels through the steering wheel.
Try to describe what is actually happening.
Jesse36m3 is offline   Reply With Quote
The Following 6 Users Say Thank You to Jesse36m3 For This Useful Post:
CatDaddysBBQ (01-24-2015), DAEMANO (01-23-2015), go_a_way1 (04-13-2016), MisterSheep (04-13-2016), Wes (01-23-2015), wparsons (01-25-2015)
Old 01-23-2015, 11:34 AM   #3
babydriver
babydriver's Avatar
When I turn right at a moderate speed (say 20-30 mph) and then accelerate hard the steering wheel feels as if it is trying to twist to the left a little. I have to compensate. I've had cars in the past where this was a sign of a broken motor mount, but the FR-S only has 5000 miles on it. Are there any other possibilities to examine?
Slip, slidin' away.
Old 01-23-2015, 11:51 AM   #4
Pkush
I'm a noob with cars, but perhaps you're losing traction and TC is kicking in? Just a thought
Pkush is offline   Reply With Quote
Old 01-23-2015, 11:55 AM   #5
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
I'm at a loss. I have no idea why you're front tires would be fighting you only when you turn right.
Did you have your alignment checked?
-Jack Burton
Old 01-23-2015, 11:57 AM   #6
Gunman
Drives: 2019 Mazda Miata RF
Alignment is my first thought.
Old 01-23-2015, 12:00 PM   #7
Jesse36m3
Jesse36m3's Avatar
I feel like you are about to initiate a drift/powerslide .. Your rear end slides out but the front wheels stay in their contact path. That would indeed make your steering wheel turn to the left because that's where your wheels are pointed.
I may be misunderstanding what you're trying to say, but you pretty much described what happens whenever I slide my car around.
The Following User Says Thank You to Jesse36m3 For This Useful Post:
Old 01-23-2015, 12:02 PM   #8
tahdizzle
So elite I'm 1338
I don't think this is the case at all.
-Jack Burton
Old 01-23-2015, 12:18 PM   #9
DAEMANO
Time Traveller
The Following 8 Users Say Thank You to DAEMANO For This Useful Post:
ARTBRZ (01-23-2015), Drakiv (04-12-2016), finch1750 (04-12-2016), GotBRZ1691 (01-23-2015), go_a_way1 (04-13-2016), tahdizzle (01-23-2015), Tcoat (01-23-2015), WRB5titch (01-23-2015)
Old 01-23-2015, 12:25 PM   #10
tahdizzle
So elite I'm 1338
-Jack Burton
Old 01-23-2015, 01:42 PM   #11
babydriver
babydriver's Avatar
That occurred to me too, but I had it checked a month ago and it was well within factory specs. I may have to have it checked again.
Slip, slidin' away.
Old 01-23-2015, 01:45 PM   #12
babydriver
babydriver's Avatar
No, I don't think so because I have felt TC come on in the past. The first time it happened I thought there was a problem with one of the rear tires. (In a sense, there was. It was slipping!) This is different.
Slip, slidin' away.
Old 01-23-2015, 01:52 PM   #13
GotBRZ1691
GotBRZ1691's Avatar
Drives: 2014 Subaru BRZ Limited 6smt
Originally Posted by DAEMANO View Post
[IMG]http://idata.over-
Best post ever
GotBRZ1691 is offline   Reply With Quote
The Following User Says Thank You to GotBRZ1691 For This Useful Post:
Old 01-23-2015, 02:34 PM   #14
Chanpion
Drives: 13 FRS Satin
Torque steer doesn't happen in RWD cars.
Alignments off or the road's angled. There's no flat roads in the world, they all have a bit of slope for waste and rainwater drainage.
Chanpion is offline   Reply With Quote
The Following User Says Thank You to Chanpion For This Useful Post:
wparsons (05-19-2016)
Memory Steer Issue AxisPower Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 01-11-2017 01:29 AM
Enkei 17x8 RPF1 Gold with Hankook Ventus R-S3, Torque Steer?! issue solved enginrd Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 11-08-2014 01:00 PM
My review of the FRS (RW Steer discussion) AaronCompNetSys Scion FR-S / Toyota 86 GT86 General Forum 86 05-10-2013 09:07 PM
TC turning back on after turning it off Xdragonxb0i Issues | Warranty | Recalls / TSB 2 02-01-2013 04:19 PM
BeSpoke steer anybody to BRZ? trackmagic Electronics | Audio | NAV | Infotainment 7 05-21-2012 12:54 AM
