Old 05-13-2012, 03:34 AM   #15
Brian S
Drives: Hinda Civic
definitly something important to clarify, good thread..
Brian S is offline   Reply With Quote
Old 05-13-2012, 06:27 AM   #16
Getagrip
Getagrip's Avatar
Drives: SWP BRZ
Originally Posted by Scooby South View Post
ahhhh yes.... Ok then...I was wrong...sorry Everybody.. Cars 101 is the MAN...guess when I looked it up I was looking at the WRX one...my bad..:/...Ok sooo 48 it is.....thanks..
Bill..(hangs head in shame)..
Don't feel bad. I was convinced they we're the same wheels a couple months ago, too, until one day I took a closer look. But, it would make sense to is the same wheel casting for cost savings reasons. So, I'm baffled why they would make a different wheel that looks so similar and be the same dimensions.
SWP BRZ
Getagrip is offline   Reply With Quote
Old 05-13-2012, 06:49 AM   #17
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
Understand...Subaru's are like Tinker Toys...they do everything for a reason..on my 99 Wagon I have parts ranging from 1999-2009 on it.. meaning that they can use as many parts as possible for different vehicles..for instance... if you ever want to upgrade the brakes on the BRZ...you can use STi components (calipers, 04STi rotors, and 08 plus stainless lines)...Another instance would be the rear sway bar...Stk on the BRZ is 14mm...if you wanted a minor upgrade...a o8 plus WRX uses a 16mm...and the STi uses a 19mm...they are all the same bends..
Thanks for Clarifying ..Joe definitely is the man..I use his site for alot of things...
Bill (Feels better now.. ..)
Scooby South is offline   Reply With Quote
Old 05-13-2012, 03:12 PM   #18
Dimman
Kuruma Otaku
Dimman's Avatar
The brakes have been discussed elsewhere and due to the reverse mounting of the BRZ's brakes, and the differential piston bores and bleed location of the Brembos, the consensus seems that it is a no-go.
Because titanium.
Old 05-13-2012, 03:16 PM   #19
Scooby South
Conedancer
I understand....but they 'could' work if someone wanted them to.. meaning they bolt on...might not be optimum......I merely was using it as example..
Bill
Old 05-13-2012, 04:10 PM   #20
Scooby South
Conedancer
ok better example...06/07 WRX 4 pots..they have the same bore pistons.....Sorry...getting off subject...I apologize..
Bill
Old 05-14-2012, 06:04 AM   #21
WhiteGDB
WhiteGDB's Avatar
Drives: Civic Si sedan
Still reverse mounting though.
WhiteGDB is offline   Reply With Quote
Old 05-14-2012, 10:55 AM   #22
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
But not differential bored, so you just switch L->R and R->L.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
Scooby South (05-14-2012)
Old 05-14-2012, 11:35 AM   #23
PERRIN_Jeff
PERRIN_Jeff's Avatar
Drives: Matte Black STI
For 100% the official answer is....
17 x7" with a 48 offset. I just pulled one off the car and checked.
PERRIN_Jeff is offline   Reply With Quote
The Following 5 Users Say Thank You to PERRIN_Jeff For This Useful Post:
civicdrivr (05-14-2012), DandoX (09-15-2016), Dave-ROR (05-14-2012), Scooby South (05-14-2012), ZetaVI (05-14-2012)
Old 05-14-2012, 02:37 PM   #24
Scooby South
Conedancer
Thank you sir.. ...could you measure how much room is between the Front Strut and the wheel...Please....just want to verify fitment of some wheels I have....Thanks
Bill
Old 05-14-2012, 03:15 PM   #25
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
Drives: 08 Pontiac G8 GT,13 GBS BRZ Limited
Ditto on what Bill said. Measurements would rock. Hell if you test fit then that's even better!
2013 BRZ Limited- GBS - 6MT -VIN #0937
~~NYR SCCA # 18 C Street R (CSR)~~
"But there’s no mistaking the noise. This car is loud, and not in a particularly nice way. There’s no crisp exhaust note, no induction wheezing. It’s just the sound of petrol exploding in a metal box." - Jeremy Clarkson
NYC BRZ is offline   Reply With Quote
Old 05-14-2012, 03:52 PM   #26
Chenslee
Chenslee's Avatar
Drives: 2015 Halo FR-S
Dammit! I thought the stockers were 17x7.5.
Chenslee is offline   Reply With Quote
Old 05-14-2012, 04:44 PM   #27
Jeff Lange
Jeff Lange's Avatar
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
Jeff
2011 Lexus IS350 F-Sport 6MT with LSD
1986 Toyota Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
The Following 2 Users Say Thank You to Jeff Lange For This Useful Post:
Fly Guy (05-14-2012), ZetaVI (05-14-2012)
Old 05-14-2012, 05:05 PM   #28
ZetaVI
Gundam Meister
ZetaVI's Avatar
Drives: A Gundam
Good. Now we know.
Stock Rims Request Double4Free FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 0 03-03-2012 03:10 PM
deep dish wheel offset CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 02-19-2012 06:45 PM
Stock or JZ? Samdajiggaman Engine, Exhaust, Transmission 62 05-25-2011 06:12 PM
Wheel offset on watanabes? Decameron Scion FR-S / Toyota 86 GT86 General Forum 10 03-29-2010 05:20 PM
Stock suspension adjustability? #87 Scion FR-S / Toyota 86 GT86 General Forum 4 01-02-2010 04:36 PM
