| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: GT86
Improve throttle response
Picked up my GT86 today and enjoying it already, but one thing I'm not too keen on is the feel of the throttle. It seems to be a little slow to react, both when getting on the throttle and when coming off it.
Just to clarify, I'm not talking about the actual acceleration or power itself - I just mean when I press the throttle pedal there seems to be little delay before it feels like the car is actually trying to do anything and likewise when I come off the throttle it feels like it carries on for a split second. Just makes it feel a bit sloppy and slow to react. Is there anything at all I can do to improve this (don't mind spending money) ? Cheers Chris EDIT: For anyone else with the same issue, I installed these bushing inserts on the rear cross member and that helped a lot: http://www.whiteline.com.au/product_...DT922&sq=14657 Last edited by ChrisD; 08-24-2015 at 06:10 PM. |
#2 |
Car Nut
Drives: BMW 335d, Toyota Echo RS, FRS
Reduce rotating mass.
| The Following User Says Thank You to BRZZZZZZZZZZ For This Useful Post: | Yoniyama (08-16-2020) |
#3 |
Only way to fix it is with a tune.
The OFT does a very good job of improving the throttle response. |
| The Following User Says Thank You to jvincent For This Useful Post: | ChrisD (01-21-2015) |
#4 |
Turning is for Nerds
Drives: 35 characters is not enough
First car with a throttle by wire? You get used to it (it also improves slightly over the first few hundred miles), but it still sucks compared to cable throttles.
| The Following User Says Thank You to Decay107 For This Useful Post: | JesseG (08-29-2020) |
#5 |
Drives: GT86
Nah I've had plenty of fly by wire throttle cars before and yeah I'm used to that, but this just feels more noticeable than any others especially when getting off the throttle.
#6 |
Drives: GT86
#7 |
Drives: 2015 Asphalt FR-S
Also consider break in period. My car got a lot better after the initial break in period.
#9 |
Drives: 2013 DGM BRZ
If you literally just picked it up the ECU may be still learning and adjusting. I know after a tune or reset the throttle response feels horrible for the first few drives.
| The Following User Says Thank You to Akari For This Useful Post: | sato (08-23-2020) |
#10 |
Drives: GT86
Nah it isn't brand new - it has 7000 miles on it. I'll see what it's like after it has been remapped
| The Following User Says Thank You to ChrisD For This Useful Post: | JesseG (08-29-2020) |
#11 |
Stole my avy from zGrinch
Drives: 2015 Audi S3
Haven't tried it on the twins yet, but many new cars will reset the computer to stock and force a re-learning situation if you disconnect the negative terminal of the battery. Then the computer would learn your driving habits and should adapt.
As others have said OFT would improve this as well.
2015 Audi /S3 | Panther Black | DSG Gone...2014 BRZ, 2010 Lexus IS F-Sport, 2006 Mazda MX5, 1997 Mustang GT |
| The Following User Says Thank You to pinski For This Useful Post: | sato (08-23-2020) |
#12 |
Tunes are about $500 and more power. But for $200, and no power addition, you can get the AVO throttle enhancer. That's probably exactly what you're looking for.
#13 |
It's miserable IMO. Runs like a Geo Prism for 50 miles. Guess that's not the OP's problem though.
#14 |
Drives: '13 WSP BRZ
I'm sorry, but ignore everything else in this thread and get a K&N air filter. Problem solved.
2013 BRZ Limited 6MT, White Satin Pearl
2012 Triumph Street Triple R, Phantom Black "Treat all tires like they deserve to die!" -Chris Harris |
| The Following User Says Thank You to Chrono For This Useful Post: | mixedjuice (08-25-2015) |
| Throttle Response | CamryDS | Northern California | 27 | 03-31-2015 03:35 AM |
| poor throttle response | Djen | Engine, Exhaust, Transmission | 21 | 06-14-2014 01:22 AM |
| poor throttle response | Djen | Electronics | Audio | NAV | Infotainment | 5 | 06-18-2013 07:31 PM |
| Does the throttle response improve? | pr086 | Scion FR-S / Toyota 86 GT86 General Forum | 36 | 12-01-2012 01:06 PM |
| How's the throttle response? | SFTiofoso | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 08-14-2012 11:50 AM |
