Old 01-23-2015, 04:07 PM   #29
fst86frs
fst86frs's Avatar
Drives: FAT H8R Hot Lava FRS
The engine bay is very tidy, but I feel there is a sore lack of heat management with this setup.
Track days in Arizona showed other wise, I do have and upgraded radiator, stock fan shroud, tuned the fans to come in sooner, designed the intercooler to allow airflow to the radiator, accounted for an oil cooling system, and havent had any issues or any showing signs of melting, even thrown a code for running cooler than oem cruising down the highway and some of the cooler nights, everything is tidy, managed well, and accounted for even in the az heat in traffic
fst86frs is offline   Reply With Quote
Old 01-23-2015, 04:12 PM   #30
sw20kosh
Drives: 2013 Black FR-S
Nice! How big is your oil cooler? Oil cooler size makes a big difference.
Do you have a stock bumper beam crash bar?
Old 01-23-2015, 04:29 PM   #31
fst86frs
fst86frs's Avatar
Its a retrofitted oil/water cooler been working fine not sure if I will supplement with an additional when it gets further turned up and pushed harder. Also I do still have the stock crash beam that has trimmed and modified but still in there
Old 01-23-2015, 04:55 PM   #32
CSG Mike
CSG Mike's Avatar
The same was said for many, many setups until the drivers started getting faster. Do you have a % WOT figure for hot lapping in the AZ heat?
If you can make it to the Chuckwalla 86CUP event, I'll cover your entry.
Hyper4mance2k (03-06-2015), OmarGC (01-25-2015)
Old 01-23-2015, 05:36 PM   #33
fst86frs
fst86frs's Avatar
I havent come up with a % figure but when is this event? Link or info? I'd be down to go to chuckwalla!
Old 01-23-2015, 07:30 PM   #34
CSG Mike
CSG Mike's Avatar
http://www.ft86club.com/forums/showthread.php?t=80202
Old 01-25-2015, 12:27 AM   #35
SnapOv3st3r
Drives: 400whp Scion tC
Originally Posted by Koa View Post
lol served.
all you naysayers got served.
P.S. it's not all about peak HP/TQ numbers bros just an FYI
Umm...why did you quote me as a Naysayer? No one said it couldn't make power or wouldn't. You are confused about the comments.
SnapOv3st3r is offline   Reply With Quote
Old 01-25-2015, 04:05 PM   #36
Mikeez
Engineering Student
Drives: Scion FR-S 2015
Originally Posted by Freeman View Post
The owner is mute when it comes to power figures or a dyno plot of that set up. Seems like it's done more for the "whoa bro check this out" factor than performance. Just my opinion on that last part.
Twin turbo on a horizantal oposed engine does not perform well. Bigger turbo is a less laggy set-up than twin.
Twin turbo is not a performance oriented set-up for our car
There’s no time to stop for gas, we’re already late
Mikeez is offline   Reply With Quote
The Following User Says Thank You to Mikeez For This Useful Post:
Freeman (01-25-2015)
Old 01-25-2015, 04:21 PM   #37
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Which is what every tuner ive spoken to about a twin turbo set up has said.
Which is why it seems it was done more for the "whoa bro!" Factor.
Sent from my SAMSUNG-SGH-I317 using Tapatalk
Freeman is offline   Reply With Quote
Old 01-25-2015, 04:21 PM   #38
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
The '98 Legacy GT-B was an EJ20TT.
Not to mention every post 2000 Porsche turbo is a 3.8L H6 TT setup...
Twin turbos actually produce less lag than a single turbo, depending on configuration. If the single turbo is a gtx2867 and the twin turbo setup is a dual 3076 then yes the single would spool better.
Old 01-25-2015, 05:00 PM   #39
Mikeez
Engineering Student
3.8 and 2.0 is different. 4cl, 6cl is also different. For our cars, twin turbo is not a recommendation but you know better
Old 01-25-2015, 07:17 PM   #40
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
the EJ20T (subaru never quoted it being a TT) in the JDM spec Legacy's are still a 2.o 4 cyl sequential turbo setup... they have done it before .
Old 01-25-2015, 09:46 PM   #41
xwd
FAT is known for making more exotic one-off setups. They built other twin-turbo Subarus before and built a twin-charged STI a long time ago. Not really entirely practical but definitely cool setups.
The Following User Says Thank You to xwd For This Useful Post:
fst86frs (01-26-2015)
Old 01-26-2015, 12:18 AM   #42
Mikeez
Engineering Student
I'm not sure if I understood you correctly, are you saying that a twin turbo set has been done to the EJ20T? If so, the FA20 Engine has also had few twin turbo set ups...
I was just saying that there is no benefit for a twin turbo. Though, one turbo is a more benefit gain. The way I think of it is that, the flow will difract. I might be wrong.
Twin Turbo Kit ? SalM Forced Induction 77 07-03-2016 03:16 PM
what's the difference between twin screw, centrifugal, single turbo and twin turbo? warplane95 Forced Induction 86 04-17-2014 03:36 PM
Twin Turbo BRZ xn7485 BRZ Photos, Videos, Wallpapers, Gallery Forum 10 08-23-2013 08:13 PM
Twin Turbo kit? enjoi23 Forced Induction 15 12-03-2012 08:53 PM
